Question about HP Officejet 5610 All-In-One InkJet Printer
Cannot edit scanned document
Please show me what steps to take:- after scanning I would like to save the scan in Word and do editting. Thanks
    Problem Solver:
  • 12 Answers
Open HP Solution Cetner
Click on scan docment and then at the right side click on scan document settings then you receive a new there enable page "Retain Page formatting" and select the language as english then press OK.
Posted on Jul 07, 2008
    Novelist:
  • 106 Answers
its like this, the OCR or the SOftware installed in your computer is limited. If you're trying to scan a document which has a picture or with text that uses different fonts like monotype, or those that are not usually being use for normal documents, usually it wouldnt detect and it become distorted. Anyways, here are the steps that i want you to follow.
1. Open solution center. (click start, go to all programs, go to HP, then click on SOLUTION CENTER). or you can see SOlution Center on your Desktop.
2. Click on Scan Documents, then the Scan documents setting will open. Change the settings to these.
* SCAN TO: Microsoft Word.
3. Then, hit scan.
4. After scanning, the folder My Scans will open automatically, just go ahead and open the scanned document.
5. From there, you can start editing the text.
..remember, the scan a document is limited, it will not read all types of fonts. if the document is using a "times new roman" or "arial" the scanned document appears to be almost the same with the original. But, if the scanned document contains pictures or stylish fonts, that would make the document distorted.
Please let me know if you still have clarifications.
Thank you.
adonscott
Posted on Jul 04, 2008
I've got a all-in-one printer of HP LaserJet M1120 MFP. When I switch it on the screen shows "Scanner Error 20". And I cannot use the scan function. It can print when connected to computer. I've rea
Follow these steps to scan using HP software:Step one: Load the item to be scanned
  1. Make sure that the product is connected to the computer.
  2. Turn on the product.
  3. Load the item in the document feeder tray or on the scanner glass
Tip
Load the following items in the document feeder tray :
  • Single items
  • Items that are not easily damaged
  • Multipage, single sided items that you want to scan into one file
Load the following items on the scanner glass :
  • Single items
  • Items that are easily damaged, such as old documents and photos
  • Multipage, double sided items that you want to scan into one file
  • Option one: Document feeder tray
    1. Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first.
    2. Adjust the width guides to fit the item.
  • Option two: Scanner glass
    1. Open the scanner lid.
    2. Place the item with the print side down on the scanner glass. For the correct position, see the engraved guide near the corner of the glass.
    3. Close the scanner lid.
Step two: Scan the item Use one of the following methods to open the HP scan window:
  • Double-click the HP scan icon (c02436443.gif ) on the Windows desktop. note.png NOTE:If you have more than one HP product installed, double-click the HP scan icon (c02436443.gif ) for the product you are scanning with.
  • Click Start (c01827528.gif ), click All Programs , click the HP folder, click the name of your HP product, and then click HP Scan .
Click the scan option for the item you are scanning. note.png NOTE:Depending on your HP product, you might not have all the following scan options available. c02448891.gif
Save as PDF Use this setting to scan text documents that are not editable. Use the Save as Editable Text (OCR) option to scan text that you can edit. c02448892.gif
Save as JPEG Use this setting to scan pictures and images.
Hope this information will be helpful.
Let me know.
Regard
Oct 29, 2011 | HP LaserJet M1120 MFP All-In-One Printer
I have a problem after scanning, I cannot bring the document up in MS Word to edit. The document arrives on my computer screen but I can not edit it
You need OCR software installed in your PC
go to www.hp.com then type OCR application then download it in your pc
OCR Application File name: s.gif 23902_hpcom_OCR_120_003.exe [1/1, 54.84M]
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=oj-72836-2&jumpid=reg_R1002_USEN
Text Cannot Be Edited After It Is Scanned to a Word Processing Program
Issue After scanning into a word-processing program, the text in the original is not editable. Workaround The process of changing text from an image to editable text is called optical character recognition (OCR). Text should automatically be converted in the OCR process when the Send To destination is a word-processing program. If it does not, check the items in the following list:
  • Select Editable Text as the image type in Scan Settings . In Windows XP, this setting is automatically selected if Scan Document is selected in the Director program.
  • Scan at a resolution of at least 300 dots per inch (dpi) for correct OCR conversion. Check the default resolutions in the Scan Settings on the Resolution tab.
  • If portions of the scan are cut off, turn off the Auto Crop feature in the Scan Settings on the Scanning tab by clicking to clear the check mark.
  • Tables, text boxes, and spreadsheets might not be editable. The border around them makes the OCR program read them as images. Readiris OCR, which is included with the HP Officejet G and K series, can recognize these images. Instead of selecting the word-processing program in the Send To list, send the scan to Readiris. Use the Table Drawing tool on the right side of the window to change the type of image to a table, and then use the OCR. The text inside of the box should now be editable.
    NOTE: Handwritten messages might not be captured by the OCR process.
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | HP PSC 1315 All-In-One InkJet Printer
How do I scan and save to my computer
Dear Sir,
plz follow this step to solved your problem,
1.
Turn on your all-in-one printer and computer. Check the connections between the two machines.
  • Step 2 Lift the printer's document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.
  • Step 3 Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.
  • Step 4 Close the printer's document lid slowly so the document does not shift position.
  • Step 5 Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.
  • Step 6 Push the scan button. You may have to do this on the printer itself or on your computer.
  • Step 7 Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
  • Step 8 Edit the image as it appears on your computer if you want to make changes. Your scanning softwaremag-glass_10x10.gif might let you enlarge, resize or otherwise manipulate the final product.
  • Step 9 Accept the scan and save. Return the original document to a safe location.
  • Thanks For Your Time,
    Apr 08, 2010 | HP Photosmart C6280 Printer
    The drop down menu does not give the option to have the picture scanned/saved jpg format which is necessary for certain sites such as shutterfly
    Please follow the steps below to scan and save a Multi-Page PDF with Epson Scan.
    1. Launch Epson Scan from your START, (ALL) PROGRAMS, EPSON SCAN.
    2. If prompted, select your scanner model. Epson Scan will now launch.
    3. Click the drop down arrow next to SCAN, select FILE SAVE SETTINGS.
    4. Select PDF for IMAGE format. Click OK.
    5. Click SCAN. Click OK to proceed (if prompted).
    6. Once the image has scanned you will be prompted to click ADD PAGE or DONE.
    7. Click ADD PAGE to scan more documents.
    8. Once you have scanned all your documents, click DONE.
    9. Your documents will now appear in the EDITING PAGE window. Click OK.
    10. The multi-page PDF is now created.
    Jan 16, 2010 | Epson Perfection 4490 Photo Scanner...
    When I save a scanned document you increase the file size. Please. Thanks.
    Document size can be set before you scan.
    Your scanner software should give you options for type of document and resolution settings. If your documents are to large, set resolution lower.
    Example, Black and white or greyscale scans are much smaller in size than color documents.
    Saving files as jpg will compress the file for storage.
    If you have an image editing program you can decrease the size of the file after the scan.
    Dec 09, 2009 | Kodak Office Equipment & Supplies
    How do I Scan a doucment with my HP PSC 1315 All-In-One InkJet
    Sir,
    open HP director click SCAN DOCUMENT set scan for editable text YES set original contains graphics NO if it doesn't, YES if it does (no results in smaller file) if you want to create a PDF file, leave SCAN TO set to SAVE TO FILE if you want to create a word document, change SCAN TO to MICROSOFT WORD click SCAN click ACCEPT (bottom right) tell it NO if you're done, YES if you want to scan something else If you scan more than one thing all of your scans will end up in a single multi-page file rename & save file to permanent location as you would normally.
    Good Luck
    Aug 29, 2009 | HP PSC 1315 All-In-One InkJet Printer
    Can't scan multiple pages into single document - reinstalled drivers but still can't - used to be able to. How do I fix this?
    http://files.support.epson.com/htmldocs/…
    I think this says you need Professional Mode rather than Full Auto Mode.
    Under File Save Settings in the Professional Mode, you should see buttons for Add Page / Edit Page / Safe File.
    Basically, you keep adding pages then finish.
    If you already have multiple .pdf files that you wish to combine, Acrobat Professional (not READER) can do that.
    Good luck,
    - CarlD
    I copied the text but I think you won't be able to see the images here:
    4. Select PDF as the file type setting. The current Paper Size, Orientation, Margin, and Compression setting are displayed below it.
    5. If you need to change any of the current PDF settings, click the Options button. You see the EPSON PDF Plug-in Settings window:
    Select the settings that match your document and click OK. You return to the File Save Settings window.
    6. When you are finished selecting file settings, click OK. Epson Scan scans your page and displays this window:
    7. If you are scanning only one document page, or you don’t need to edit your pages, click Save File and go to step 10.
    If you are scanning multiple pages, click Add page and replace the first page on the document table with the second page and click Scan. Repeat this step for each page in your document. When you are finished, click Edit page and go to step 8.
    8. You see the Editing Page window displaying thumbnail images of each scanned page:
    If you want to include all the document pages in your PDF file as they currently look, go to step 9.
    If you want to delete some of the pages, click the odd pages or even pages icons, or click the individual pages you want to delete. Then click the delete icon to delete them.
    If you want to rotate pages, click the pages or use the odd pages, even pages, or all pages icon to select the pages. Then click the left or right rotate icon to rotate them.
    Note:
    The delete icon is not available when all document pages are selected.
    9. When you have finished editing your document pages, click OK. Your document is saved in a PDF file in the location you selected and you return to the EPSON Scan window.
    10. Click Close to exit Epson Scan. Source(s): http://files.support.epson.com/htmldocs/…
    Aug 22, 2009 | Epson CX8400 All-In-One InkJet Printer
    I have scanned a word document and now I can't figure how to use OCR to edit and save the document. I need a step by step answer. Thank you, Bill Garbo
    for ocr to edit
    use software lise sprint 5.0 fine reader
    it's very easy to operate.
    and scan in JPG format for editing
    Jun 23, 2009 | Canon Office Equipment & Supplies
    Scan a Document and Need to edit in Word 2007
    Most of the time a scanner by default, will scan a document in a tif or other image file format. That means that the scanned image is actually very similar to a photograph. In order to edit the text, you first have to convert the image using something that's called OCR software. OCR is a process that the software uses to look at a scanned document image and determine what characters are on the page. It's not always very accurate but that depends on the quality of the scan and on the OCR software being used. You must have received some sort of scanning software with the scanner. Hopefully it containes some sort of OCR software. Some scanners will save you this extra image manipulation by having a setting that allows you to scan directly to a word document. Usually in that configuration, the OCR software automatically knows to convert the scanned document image in order to automate the process. But either way, you first have to install the manufacturer's software. Hope this helps. Please remember to rate my answer. Thanks.
    Feb 26, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
    Scan and Edit
    i believe this is called OCR scanning, character recognition so that the text can be edited in text editors. I have not used works to know if it has a text capture feature but I'm aware of scanning software that offer OCR capabilities, i used to have that on my old scanner, i do not remember the name of the software but here's what google turned up for OCR scanning:
    http://www.google.ca/search?q=OCR+scanning&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
    second link shows free OCR Tools
    HTH
    Marc
    Jan 20, 2008 | Lexmark Pro X125 All-In-One InkJet Printer
    HP Officejet 5610 All-In-One InkJet Printer Logo
    477 people viewed this question
    Ben Johnson
