Washer does nothing but FILL!!
My Kenmore top-loader washing machine (c.1980s) fills to the correct level, but does NOTHING else... will not agitate, will not advance, will not drain, no matter what other dial positions I manually advance to..... Lid switch is tested and OK. What else should I look at?
  • dan777
    dan777 May 06, 2008
    Finally broke down and got the serviceman.... turns out oldfixer was somewhat right, though I was looking for isolated contacts just to the timer itself.... The serviceman fixed it almost by accident when he was fiddling with the entire wire harness plug going to the whole timer/selector assembly... Unplugged, plugged back in... wa-la!! (Apparently a common malady on many appliances -- esp the newer ones with massive harnesses -- the contacts gradually get fouled, come loose, something...) Money well spent tho, as I got to watch how quick/easy it was to open the entire cabinet, and even pull the whole motor out all in less than 60 seconds! (motor coupler was almost broke) -- and got LOTS of questions answered! :) Can EASILY do stuff myself next time....
    BTW, never found any off-balance switch on this particular machine, nor do I believe there is one...
    Genius:
  • 1,028 Answers
Suspect timer contacts bad but ck wire harness to motor just to be sure also if i remember correctly those may also have off balance switch that would cause problems but not sure if water would run in if they are bad ..sorry oldfixer memory ain't what it use to be
Posted on May 02, 2008
Kenmore 700 series top loader washer. I put it on the normal cycle, the washer fills and agitates for a few minutes (maybe 5) then drains only to fill back up and finish the cycle. Is this normal?
no
some cycle the agitator during the fill cycle to get better distribution of the clothes as it is filling and then shut of the water and proceed to the wash cycle
have a technician check out the program board
Jun 15, 2017 | Kenmore Washing Machines
Kenmore 80 series top loader washing machine 110 volt was plugged bu mistake into 220 volt outlet. Machine will no longer fill water or agitate but when put into spinning it will spin
First off I can tell you the water valve coils are probably cooked / burned out. With POWER OFF / unit unplugged you can remove one wire from each of the coils and check for resistance across the coils. No resistance = open coil = no fill. NO FILL = no agitate because the water level pressure switch is trying to sense the water level that never rises. If there is no water then there will be no agitation.
If you really want to see if it will agitate in it's current condition you can fill the unit with a garden hose on a low level water setting and fill it a little over half way to see if it will agitate. (You will have to remove the hose and close the lid)
If that works then the water vavle would be the culprit causing your condition. The wire wound in the coil windings of the water valve is smaller in thickness than a human hair and would easily fail if 220VAC was put across a 110V winding.
Feb 02, 2010 | Kenmore 24032\24036 Top Load Washer
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Kenmore 70 Series washing Machine won't stop filling with water
filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore washing machine won't stop filling with water
yes the water level switch controles this does the machine quit filling when you turn it off if so eather the water level switch is bad or the rubber hos attached to it has come off
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Washing maching won't continue cycle
Check that the front door or lid interlock switches are operating. If they are not, the machine will not start. It is a very common cause of non-operation, and simply opening and closing the door will usually clear the problem if it is just intermittent sticking.
Jun 05, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
