-   connecting via wirless
i dont no the key it say to enter and even wen i enter sumthing in there it just says its pending-   cookie1992
Feb 14, 2009
-   when trying to connect to wireless network after typing in the key word nothing happens, only showing "pending" on the screen
-   Guest
Feb 14, 2009
-   When I'm trying to get wireless connection after typing in the the key word it does not connect but says "pending "
-   Guest
Dec 28, 2008
-   have tried to hard wire it to the livebox as well as to connect remotely but keep getting pending messages! any ideas?-   Guest
Dec 02, 2008
-   I have the same problem, and im pratically sat on the bloody wireless box, so its not signal strengh... sometimes it connect, reboot, it then wont.. have to remove it from the network connections, bouce it, then try aand re join the wireless.. sometimes works, sometimes not.. its really hit and miss
-   fozzywozzy26
What type computer? Wireless network ? FROM the language you are using [" picks up connection"] It is wireless. You may be picking up "outside" signals. When they are weak, you may get something!,then u loose it. Thats why "pending & nothing happens"
I have an ASUS F5RL-X3 I can not access the recovery console using F9, nor can I repair it using OEM...
(More)
I have an ASUS F5RL-X3 I can not access the recovery console using F9, nor can I repair it using OEM WIN XP Pro disk. I have changed boot priority so that CD is first device however it goes to HDD. I just want to get it started in recovery or DOS so tat I can manually fix registry and run chkdsk /p/r. F9 does not work!
wont allow facebbook access , have set all the interbet settings to factory settings, cant do a...
(More)
wont allow facebbook access , have set all the interbet settings to factory settings, cant do a restore as not enough memory, taken of AVG as was told thats the porb, trying to sort out a friends one and its just not having it
I have an asus eepc and a few months back I installed Windowz xp in it. However, I cannot connect to...
(More)
I have an asus eepc and a few months back I installed Windowz xp in it. However, I cannot connect to the internet. How can I fix this problem?
and it seems to be a common complain. I found at least ten posts asking the same question here and I only looked at five pages.
Comment by Guest, posted on Dec 01, 2008
same problem with Eeepc. both for wireless and land line. it just stays on 'pending'. ( when you open the details, in the log it says, no DHCPOFFERS received. No working leases in persistent database - sleeping. runparts -- verbose/etc/network/ )
