Question about Dryers
Not spinning .no noise - Dryers
  • 172 Answers
Hi mdorm,
The two most common repairs for this would be either the thermal fuse has burn out, or your door switch is bad or broken.
Good luck to you and I really hope this helps to get you back to drying. mca0824
Posted on May 02, 2008
Noisy during spin cycle
Yes that is definitely bearing noise you here.
Jun 21, 2017 | LG Washing Machines
Noise at the end of spin as it stops.
he5t kenmore elite. i have noise coming out as it begins to was with a load in it if it spins fast no noise. when it spins slow i get noise. i thought it was the rear bearing but not in my case. it ended up being the belt was very dry, i spray wd40 on all over the belt, now noise is gone day saved.
Jan 23, 2014 | Washing Machines
Rattling noise in spin, spin problems becoming more pronounced. control panel lights flash but 0 error codes. unplug 2 reset, probl repeats
If this noise is happening while it's trying to drain water then you have something floating around in the lump. Coins are very common. If the noise is happening during a spin cycle and more pronounced during the final high spin cycle, you have bearing or spin tub issues. Time to go shopping.
Nov 07, 2013 | Frigidaire ATF6000ES Front Load Washer
I have a westpoint washing machine wen it is spinning it make a lot of noise serial number wtw 500. it is a 5kg. can you help me with this problem.
Thanks for choosing FixYa and welcome to the site. You need to check your spin bearing and the motor drive. If the noise is only during spinning, you need to check these. Anytime a washer makes loud noises during spinning, always check the spin bearing and motor drive.
Apr 24, 2011 | Washing Machines
Loud noise during spin cycle
what kinda noise, sqeeling, or clunking, mite be sumthing small that made its way behind ajatator an is causeing noise..or one of the springs that hold it broke..sorry i dont no what kind of noise.....
Jan 31, 2010 | Washing Machines
Washer makes a lot of noise during spinning
we need the brand and the model
but for starters, please check on the links below.
http://forum.appliancepartspros.com/washer-repair/4501-washer-makes-extremely-loud-noise-during-spin.html
http://www.thestuccocompany.com/maintenance/Washing-Machine-noise-during-spin-cycle-169980-.htm
http://www.askmehelpdesk.com/appliances/washing-machine-noise-during-spin-cycle-167960.html
Sep 10, 2009 | Whirlpool Washing Machines
Washing machine making crackling noise when spinning
check for some loose items underneath the unit. washing machines normally reverses its rotation when spinning. check if mechanical solenoids pulls the right levers as it starts to spin....
Feb 12, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Dryers Logo
98 people viewed this question
Top Dryers Experts
