Question about Dishwashers
Bosch dishwasher shv55m03gb washing tablet does not release
  • 487 Answers
Dispenser sometimes goes bad.
either you open it up and clean the whole dispenser or you have to buy an new one
LINK here you can find it
Posted on May 01, 2008
I own a Bosch home Dishwasher - Model SGV53E03GB-74 - where the wash tablet discharge cavity opens in the wash cycle but doesn't allow the tablet to drop, so the wash is ineffective and needs
Sounds like the dispenser door isn't opening. If it isn't being blocked by dishes, the dispenser door spring might be broken, the dispenser release solenoid could be faulty, or not getting power from the control panel. While you're waiting for it to get fixed, you can just put the detergent in the bottom of the dishwasher and run it on normal cycle. It also possible the dispenser door isn't opening wide enough for the puck to fall out. Make sure the door opens freely under it's own spring assist.
Nov 26, 2014 | Bosch Dishwashers
Which models are catching fire
I have checked your details and your d/w is not subject to the recall if you want to check yourself I have add the link
http://www.repairaction.co.uk/bosch
Apr 07, 2013 | Bosch Dishwashers
Bosch SHV55 noisy
Is it noisy during the whole cycle or just part of it?
Jan 27, 2013 | Bosch 24 in. SHV55M03GB Built-In...
Dishwasher keeps filling
1) test the inlet valve for defective or pen
2) test the overflow siwtch for open or defective see the diagram
God bless you
Jun 18, 2012 | Bosch 24 in. SHV55M03GB Built-In...
Where is the thermostat located on a SHV55M03GB
Exact location can be traced from the wiring to the heating element which is shown in spread diagram of a dishwasher. check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/169/identifying-dishwasher-parts.html
Mar 11, 2012 | Bosch 24 in. SHV55M03GB Built-In...
If i use combination tablets in dishwasher do i need salt & rinse aid, thank you.
The combination tablets are very convenient and do work well but you will still need to use salt and rinse aid for the best results. The reason for this is that every dishwasher has a specific time or times that it needs that chemical (rinse aid or salt) to be released. The tablets will release it but maybe not at the best times.
Aug 01, 2010 | Bosch WFMC 3200 Front Load Washer
My dishwasher (Bosch 24 in. SHV55M03GB) seems to be retaining water at the bottom after a cycle and will not drain. Will I require a repairman or is it something we can sort? Thanks
Have you recently installed an in sink disposal? This is where your dishwasher drain line should connect to. Just make sure you knock out the "blanking plug" on the disposal, because it is blocked off in case you do not use a dishwasher.
Otherwise, there is a small drain at the bottom of the dishwasher that pumps the waste water out-there is a chance that this pump has gone bad or just become clogged. Unfortunately, there is probably no way around fixing this without having the dishwasher removed from it's position. If you pull the dishwasher out, it will be a lot easier to check out.
Hope this helps.
Mar 01, 2010 | Bosch 24 in. SHV55M03GB Built-In...
Top Wash Arm not Spinning
water is not circlating, you need a circulation pump
Feb 24, 2010 | Bosch 24 in. SHV55M03GB Built-In...
Not releasing tablet and not filling or washing
Ensure that the dishwasher has sufficient electricity (e.g.: wall switch, plug, etc.), and that the water supply is on. Otherwise, contact an appliance service company.
Feb 22, 2010 | Bosch Dishwashers
Bosch dishwasher
your not supposed to be using tablets in the bosch dishwasher. the ball on the tablet gets the lid stuck. the sticker on the door recomending tablet is advertisment. your owners manual says to use powder only
Nov 18, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
164 people viewed this question
Top Dishwashers Experts
