It is makeing a nose when it spins - Washing Machines
    Scholar:
  • 58 Answers
If its a rattle could be a lose agitator
if front load then screeching or thumping is most likely out of round tub or wheels
top load thumps suspension springs
loud roars are always bearings
always give more details
model serial manufacture and top or front load
Posted on May 01, 2008
Sanyo asw 70st washing machine makes lot of nose while spinning
Can any one provide me the Instruction manual for Sanyo #ASW-70ST?
Feb 23, 2017 | Washing Machines
2005 ford taurus can spin front wheels by hand when its in park
Sounds like maybe a halfshaft (axle) problem. Maybe has a bad cv joint. If that's not it then possibly the spur gear in the ****** broke.
May 28, 2012 | 2005 Ford Taurus
Maytag Atlantis mav8551aww my washer is making a grinning nose when it goes into the spin cycle. what can it be ? its 7 years old, is it worth fixing?
Thanks for choosing FixYa and welcome to the site. More then likely, you probably have a bad spin bearing or motor drive. Since your problem appears to be within the spinning, I would check the spin bearing first. Anytime noise is associated with spinning, it is usually one or the other. It just depends which one is bad. The bearings are not a large financial setback. If the motor drive is bad, it can get a little costly.
May 05, 2011 | Washing Machines
How can you make your nose look smaller with make-up?
Use concealer on the bridge of your nose and use a power on top... I saw it on Oprah.
Use an eye shadow that is a little darker than your skin, and put it on the sides of your nose to make it look thinner. An eyeshadow with a slight green tint will help minimize the appearance of depth around the edges, thus creating a smaller appearing nose.
Buy a thing of powder that's two or three shades darker than the powder you put on the rest of your face, and brush it on the sides of your nose.
I used to do make-up and costume design for theater. The advice above is spot-on: you want a color a few shades darker on either side of your nose. To make your nose look even thinner, use a color a few shades lighter than your skin right along the top of your nose, down to the "ball" --the part that sticks out the most. If you're trying to create a curve to your nose, ie, make the bridge seem like it sticks out less, use the same color that you used on the sides and blend it--gently!--over the bridge, then apply the highlight color just to the ball and blend thoroughly. Less is more here: in Theater, we heap the makeup on so that the audience can see it under the bright lights. In the real world, you want to go very easy on it. If you use too much, or too dark a color, your nose will just look dirty.
Make sure the foundation and concealer you use is matt making your nose appear less shiny and less attention will be drawn to it, also make your eyes, cheeks stand out that way the attention will be drawn to your nose. I have a fairly large nose and just for the past year what I've been doing is taking blush, and rub it gently up and down the nose. but don't touch the sides at all, this will make your nose appear thinner and more narrow than big.
Added an illustrating related link. It's easier to understand by seeing a picture or video.
Another way is to draw attention away from your nose, all you need to do is to apply more make up to your eyes.
Nov 22, 2010 | Health & Beauty
Squeaking washing Machine during spin cycle
Hi
Loks that your machine is pretty old and hence the belt has hardened making a squeaking noise.
Good fix is get a new drive belt.
OR
Quick fix is you could put some oil on the drive belt..... it will work for now but not a permenant solution.
Regards
Berry
Feb 01, 2010 | Kenmore Washing Machines
HOW DO I CHANGE THE FUEL FILTER ON MY 2002 GMC YUKON XL I AM HAVING TROUBLE DISCONNECTING THE HOSE END
First - Safety is always the key to working with fuel:
1) Remove from the area of work anything that could ignite the fuel, 'High intensity shop lights, no smoking'
2) Work with a flash light or directional battery operated light if its dark.
Two tools to have in my opinion -
1) Pliers
2) Needle nose
1st - use the pliers to spin/break the hose end loose over the In and out flang of the fuel filter.
2nd - If you have a needle nose pliers which have a very narrow nose end.
Place the nose end all the way at the hose end that's over the fuel filter's intake/output flange.
You then can leverage the hose off by forcing the body of the needle nose up against the body of the filter.
Just like a teeter totter where the body of the filter becomes the /\ fulcrum of the teeter totter.
Hope this makes sense?
Blessings,
A/V Media Guy
Nov 21, 2009 | 2002 GMC Yukon XL
Husqvarna 350, the chain continues to free spin after trigger is released.
Is the chain loose?
ee42fee.gif Chain adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Oct 29, 2009 | Husqvarna Chain Saw 20" Bar
Have a roper ras7133kq1 top loader. It will fill with water and will do nothing else. when i manually set it to spin it makes a squealing nose and the water just drains out.
go to www.repairclinic.com and enter your model number. the first part you see is what is wrong with your washer's spin. replace that and you'll be good. this is found underneath between the motor and the transmission.
Apr 03, 2009 | Roper RAS8445KQ Top Load Washer
Maytag mah4000aww motor control board bad cannot tell which series it is serial 53312313yk
my front load washer is leaving water after done spin cycle can still ring water out of clothing....water is draining from hose and is spinning somewhat strange...like its not going through rinse properly sorta like its repeatedly doing same cycle pattern...spins for lil, stops makes running noses...spins sum more....soapy clothing...its 5 years old..but first time use this month finally connected it...when took bottom off to check hose connection noticed control board looked lil warped and brownish colored but not as meant to be..maybe its burnt out?
Apr 13, 2008 | Maytag Washing Machines
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
