Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader
It does not fill up with even alittle water is this normal
Washer should fill, remove hoses, check screens in hoses and or valves on machine for clogs. Verify water valves at the source are turned on. If all this checks, you need new valve installed on your washer.
Posted on May 04, 2008
Duet whirpool front loader is filling with water on its own
The washer fill valve is defective and will need to be replaced. The fill valve is right under the main top at the back the fill hoses attach to the valve.
Oct 07, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Ytek.netwe just moved into a house with a duet washing machine- a few years old. when we do a normal clean cycle, it doesnt appear there is that much water getting used. How much water should we see thru...
All front loaders use very little water as a opposed to a top loader that uses up to 45 gallons per load a front loader uses about 10,plus a front loader cleans clothes very well with that minimal water usage.
The major question is do the clothes seem to come out clean when you have used that washer?
Aug 20, 2011 | Whirlpool Washing Machines
Whirlpool Duet:drum fills up with water when machine is off.
Your problem is the water inlet valve has failed part # AP3128776 This is fairly common especially if you have hard water or well water.
Just enter that # at www.appliancehelponline.com
Mar 24, 2010 | Whirlpool GHW9400 Duet Washer
My duet front loader will fill with a large
there are two water valves above the soap drawer, that are sping loaded to stay shut when power is off. if the water pressure to the machine has increased, sat due to an increase in main pressure from the water board fixing a leek further up the supply, then this could force open the valves. try turning the stop valves at the inlet pipe end, away from the machine, down a quarter turn and see if this stops it.
Oct 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader washer-leaks into washer when not in use
Yes, but if something gets into the valve it may prevent it from sealing correctly. Unfortunately these valves are all molded plastic around the seal, so there is no way to repair it. You'll have to replace the fill valve.
Jul 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water supply
yes it is normal. It fills up during the washing proces
I had the same thought at first but it truns out ok.
Jun 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer fills with water by itself
sounds like a faulty water inlet valve, not seating properly after closing the valve.replacing the valve is the only solution to this problem, in the meantime you can turn off your water supply in between doing loads.
not a bad habit to get into!!!!
Mar 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
96 people viewed this question
Dan Webster
Dan Webster
Sal De
