Question about Sharp 25N-S100 25" TV
Sharp Model 25N-S100 - black triangle on screen
Sharp TV model # 25N-S100 - have had a black triangle on the screen for several days, now today that along with no color. Any fixes?
  • dinamicarrhh Nov 21, 2008
    I need the code control remote RCA for sharp modelo 25N-S100
    Thanks
    Luky ópez
    Guatemala. C.A.
    dinamicarrhh@hotmail.com
  • banyon Dec 26, 2008
    i need code for s5N-S100
I need the code for a sharp 25N-S100 - Thanks
Posted on Dec 26, 2008
  • 71 Answers
Turn off cc/closed caption
Posted on May 03, 2008
I have an old Sharp Model # 27A-S100 I have a Black Line running across the bottom of my screen from left to right 22 1/2" length and 3 1/4" in height
If this line does not go all the way across the screen then I will bet you this is an easy fix. Press the menu button on the remote control. The menu will hopefully show up over-top the black. Search your menu for the closed caption setting (usually under audio settings menu) and turn closed caption OFF. Hopefully this fixes your issue. Cheers.
Apr 24, 2011 | Sharp 27N-S100 27" TV
Value resistor 719 of chasis serial : qpwbf9254mezz,tv sharp 27" model: 27j-s100 or diagram. thank you for his help
I looked at the same chassis I have and the resistor has color bands green blue silver gold wich is a .56 ohm 5% 1/2 watt resistor
Dec 03, 2010 | Sharp 27J-S100 TV
Tv turns on cable is in tv,but no cable or anything black screen
First is the cable active? If so make sure all cables are connected propperly from the outside sorce to the tv. If all of the above are ok check the remote menu to make sure that it is acsessing the correct inport source:cable,antenna,hdmi,etc. Also with the change over to digital you may have to have the tv rescan all availlable channels.
Jun 14, 2009 | Sharp 25N-S100 25" TV
My Sharp 26sb24u randomly turns on and off
Good day sir hi, the symptom you just describe is a nightmare for us technicians, we call it INTERMITTENT problem. we cannot diagnose the device until the unit mulfunction permanently which is much more easier, but it can repaired.
What we do is measure voltages when the tv goes systematically bad. or if its modular, replace the entireboard.
The problematic section is the power supply section, but this can also be the horizontal output section. Check power transistors and capacitors. CHeck also the switching regulator IC, that controls the switching.
But a good service shop can find the fault easily if they have encountered the same symptoms, call a service shop if they have a solution on your TV problem and inquire about the service fee. call several shops until you get the best bargain. = )
Jun 06, 2009 | Sharp 25N-S100 25" TV
MY TV CONNECTOR AT THE BACK BROKEN OFF
you can hook it up thru av input..what i mean is the red white and yellow wires hook wires into the OUTPUT on box and the input on tv then change tv to the input u hooked them to..for example if u hooked them into av1 then turn tv to av or hiy input on remote
May 26, 2009 | Sharp 25N-S100 25" TV
Remote won't work and power switch pushed inside the television
No, sorry, not from this distance. But if I were actually there, I would try to put the switch back where it belonged, IF it was not broken!
May 15, 2017 | Sharp 25N-S100 25" TV
Digital or Not
The Sharp TV website has a number to call to answer your questions 1-800-BE-SHARP. They also can be contacted by E-mail (click on Sharp Support Center and scroll to the bottom of the page for instructions).
Jun 25, 2008 | Sharp 25N-M100 25" TV
Sharp 25R-S100 25RS100 SHARP 25" STEREO FRONT/REAR AV
Good day.
Try to check the crt socket. Also, check for the loose contacts along the Chroma IC. Like wise, there is a screen adjustment on the rear portion of the flyback. Try to adjust the screen.
Response is highly appreciated.
chris
Feb 24, 2008 | Sharp 25R-S100 25" TV
Accessing Menu Sharp TV
its very easy on the t.v and press on channel up or down on your tv. u will get the screen
Aug 25, 2007 | Sharp 25L-S100 25" TV
Sharp 25N-S100 25" TV Logo
248 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
