Question about LG DLE2512W Electric Dryer
Dryer will not heat
Just had my second LG dryer delivered in a week.It will not heat.Starts,runs,but no heat.The first one did the same thing now this one too.This is an electric dryer.
  • Anonymous Jun 17, 2008
    Mine just went our after 5 years. It gave off an electrical burning smell, now it won't dry anymore
    Champion:
  • 210 Answers
Or it could be that the thermostats are bad to start with.
Call for service.
Sgt 48
Posted on May 31, 2008
I had the same problem with my dryer.  I bought a brand new house and the problem was with the house and not actually the dryer.  I had the LG service people come out and look at it.  The dryer duct on the outside of the house was getting stuck and not opening.  We had to actually trim the metal so it would open.  With it being stuck closed, it would send the heat right back to the dryer and the sensors would tell it that the clothes were dry.
Hope this is helpful!
Posted on May 04, 2008
  • 172 Answers
Hi jillsimons,
If you have had two new dryers not heating it really sounds like it may not be a dryer problem but a home problem. I would first make sure you have the correct amount of voltage to the machine. It will require 220-240 volts to operate correctly. If one leg you your breaker is kicked or you have a blown fuse in your breaker box then your dryer will only be getting half the voltage it requres to operate. It will run but it will not heat. Secondly if you do infact have the correct voltage then this could be the only other possibilty.
The dryer vent would either be to long or blocked off. This will cause the dryer to blow its thermostats and the dryer would then stop heating until the thermostats are replaced.
I am sure one of these will solve your problem. So check your breaker box, kick them off and back on then see if you get heat. Then check your vents. If they are blocked clean them out and get you some thermostats. Or call for service, since the appliance is new they will not charge you for a service call. Atleat I would'nt. Have a great day and good luck to you, I really hope this was helpful to you. MCA0824@aol.com
Posted on May 02, 2008
My LG Model DLEX3360 dryer will turn on, run about 20 seconds and stop running -- but displays still says it is drying.
Dryer Thermal Fuse Replacement - LG Electric ... - YouTube
? 5:29
https://www.youtube.com/watch?v=b74Mt5sSgRI
Dec 21, 2012 - Uploaded by RepairClinic.com
Dryer Thermal Fuse Replacement - LG Electric Dryer Repair (Part ... The most common reasons for replacing the thermal fuse are when the dryer won't start or ... I have an LG GAS DRYER model # DLGX8001V and it will not ... My front load dryer won'tturn on. .... My LG dryer recently stopped working.Missing: seconds
LG Electric Dryers, no heat? Try this first... - Home Forums
ths.gardenweb.com > Home Forums > Laundry Room
Apr 1, 2006 - I own an LG Electric Dryer model DLE0332W. ... Serviceman: The part you need is a heat regulator and its going to run you about $20 and the labor ... Look into the hole to the left and you will see the Heater Unit right within reach. .... Came back a second time because it still wouldn't dry my clothes (maybe ..
Nov 24, 2015 | LG Dryers
Dryer starts then stops 10 seconds later for 1 minute then starts again
You dryer has several "overheat thermostats" located at various places inside your machine.
They are to prevent fires caused by overheating.
I suspect one of them is defective, or you have another problem which is causing one to shut your dryer off.
The dryer is shutting off to prevent a fire.
Be blessed
Feb 08, 2013 | LG DLE2532W Electric Dryer
I have an LD LG DLG5932W gas dryer. It is not heating. I removed the front of the dryer and got it running. I can see the glow plug glow and the flame starts but only for maybe 5 seconds and then goes out....
Well for starters VERIFY tons of air flow OUTSIDE of the building. To test, pull hose from back of machine, turn on and form opinion of air volume. Then hook back up, turn on machine, go outside and see if you have similar air flow. Commonly there is a restriction. This will cause thermal limiters to stop the heating.
Jul 29, 2011 | LG DLG5932W Gas Dryer
Runs but will not heat. Power outages in area over last few weeks.
If the dryer was running during an outage, even with a very brief flash there usually is a power surge when it comes back on. If everything else seems to work okay it's possible that the heating elements got fried. You can check them with a voltmeter. Also check to seek if the dryer has overlaod protection. Most have a reset. One other thing that could happen, the breaker is defective. That you can check at the back of the dryer where the plug cable attaches to the dryer.
Apr 09, 2011 | LG DLE2516 Electric Dryer
Runs but does not heat up, I removed the bottom from cover under the door and saw that when I turned it on the machine starts running, the thing that ignites the gas heats up to a bright redishish yellow...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 18, 2011 | Dryers
LG DLG 2526W dryer running but no heat
heatman101
May 22, 2010 | LG D2526 Gas Dryer
Brand new Lg dryer 2501, error code ''nP''
I had the same issue with two new dryers. The rep on the phone said nP can also indicate a power issue. It turned out one of the wires in the outlet had broken off. Rewiring the outlet solved the problem.
Mar 05, 2010 | LG Dryers
Front load gas dryer lg model dlg 5988w does not heat
This can obviously be several things, but I would first check the small safety thermostat. On the gas models, there is a small pin sticking out of it which can be pushed back in to reset it. It is located on the heater housing and is only about the size of a dime, with two wires on it. This will trip out easily if your vent was not clean, or is long or restricted in some ways (like using flex ducting)
If you need more help getting to it, let me know and I'll give you more instructions.
Dec 22, 2008 | LG DLG5932W Gas Dryer
LG Gas dryer will not keep heating
sounds like the heat sensor on side of heater pan is bad and needs to be replaced ,,, its mounted on side of pan the flame blows into and has 2 wires plugged onto it / larry
Dec 12, 2008 | LG DLG5932W Gas Dryer
LG DLE2512W Electric Dryer Logo
129 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
