Need repair kit for LR Code on Neptune Front Load Washer. Found it once a few months ago, but lost the printout and unable to locate the site again.
    Scholar:
  • 58 Answers
The part number for MAH5500 and MAH3000 is 12002039 you are going to want to bring your model and serial with you to where ever you buy it to confirm, but that part number is the most recent one, it contains the motor, motor control kit etc..which LR meaning locked rotor that would be the fix
Posted on May 01, 2008
My Maytag Neptune washer is not spinning and I tried only Spin cycle for 12 minutes and gave LR error message. Pl help?
Hi, the Maytag Neptune front load washer LR or Locked Rotor error indicates and issue with the motor drive system. The motor control board is located near the floor on the right side. See Neptune Disassembly help to remove the door and front panel to get access, if needed.
I would unplug machine, remove all connectors and reinstall a few times and retry machine in case of any oxidation on the connectors. Also, check the belt and make sure it has not popped off. There is a rear access cover you can remove to take a peek.
In addition, there is a motor drive test you can perform to see if the inner tub will rotate at 50 rpms. You should have a document with your machine that instructs how to perform this simple test and it could be located in the top console.
Depending on which machine you have... If the motor control board has failed then you may have to replace the motor and motor control board since Maytag redesigned them because they were having reliability issues with them and they decided to change the motor technology they were using. See maytag maytag Neptune motor conversion kit for more info.
I hope this helps...
Apr 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
We have a maytag neptune washer and it is suddenly not working and displaying a code of LU it kinda looks like>?
perhaps and lr??? LR--- means locked rotor assy. you will need to replace your motor control board and motor assy, comes as a kit not a bad repair (NEPTUNE REPAIR KIT) if thats indeed the issue you seeing that is
Oct 09, 2010 | Maytag Neptune Washer
Neptune MAH5500B Front Load Washer: what is the "LR" error on a Maytag Neptune washer...
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source..."Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 (ten being hardest) I'd call it a 3.5. If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job. It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear. Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer. The instructions don't ask you to, but I would remove the brace on the left to make life easier. This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board. My wrench was too big to get to the bolt to remove the harness from the motor. All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor. As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft. The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together. There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish. Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%$#$%
May 16, 2010 | Maytag Neptune MAH5500B Front Load Washer
Lr code appears. machine stops.
replace or, replace the lid lock switch,solenoid or, bent lock lever
Jun 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load has Lr on Time display
Im having the same problem what is the lr code and how do you get rid of it?
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Neptune Washer
lr is a code for a locked rotor assy, on the motor itself, depending on age of machine you might have warr on the motor(part anyway) check your user guide and warr info. probably gonna need to install a "neptune repair kit" which includes new motor and new motor controller
Nov 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer
LR == locked rotor, which translates to a bad motor and motor control board( usually depending on age sold a 1 set. Neptune repair kit. retails for about $200 part number 12002039
Oct 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Fills with water but wont wash or spin
The code LR stands for locked rotor you will need a new motor and motor control kit pretty expensive and only covered under you warrenty for a year!
Aug 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Getting error code#06 Lr Locked Rotor
I too had the Lr problem on my Maytag MAH5500B. We had it fixed once when it was still under warranty but when it appeared again this summer, I was told that it would cost at least $500 to repair -- in other words, get a new one.
With nothing to lose, I simply unplugged the unit, opened the front and reset (as in pull out and re-insert) the jumpers to the control unit on the bottom right. It's been working fine since and I run it at least twice a week. I noticed that the Lr error would appear when I interrupt the wash cycle once it begins. When the error message appears, I simply unplug it, wait a few minutes and start it up again.
It is after all, a computer...and all computer could use a reset once in a while.
Feb 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
