Question about Nintendo Super NES Console
Ac adapter connection
A portion of the connector where you plug the elcetrical adaper in is broken off. How do you repair this? tstarjbr@yahoo.com
    Champion:
  • 268 Answers
You are better of getting a replacement, but if you really want repairs most electronic goods stores can get it repaired for you, even gaming repair shops can have it fixed on the day for you
Posted on May 02, 2008
OW TO GET MY ACET ASPRE ONE IT STOP BLACK SCHREEN NO POWER
Step by step troubleshooting.
Verify power outlet is good
Verify power adapter is good
verify connection to computer is good
fully charge battery
test
=======do this
Check power source, plug known good light into AC receptical.
If AC cord has connector to power block verify it is properly seated.
plug adapter into AC outlet
Verify Power is present at power connector with another similar computer or voltmeter. (12V to 20V)
When plugged into computer, charge (not power) indicator MUST light either red, amber, or green. If not, connector on computer may be broken.
leave overnight or until charge light is green
turn on normally.
most likely causes:
- loose connector
- broken wire from power adapter
- broken power plug on computer.
- anything else is probably beyond ur capabilities to fix.
Aug 10, 2014 | Acer Aspire One PC Notebook
The I have a new laptop and cannot receive e-mails as they go through my desktop on outlook I would like for everything to be on yahoo. I am signed up with AT&T for my internet connection How can I...
You must have configured OUTLOOK on your computer to access your electronic "mailbox" that was created when you signed-up to use AT&T for your Internet access.
Only the E-mail sent to your '@yahoo.com' ID can be accessed through the "Yahoo! Mail" web-site.
So, setup E-mail "forwarding" through AT&T, so that all E-mail sent to your AT&T mailbox is "auto-forwarded" to your '@yahoo.com' mailbox. Then, use "Yahoo! Mail" in your web-browser to view your E-mail.
Jun 26, 2011 | HQRP Laptop AC Adaper Equivalent 90W AC...
I have dell 1318 notebook from last 7 days some times its not charging plz tell me solution
It would appear that you have a broken connection on the power connector on the motherboard of the laptop or a broken wire on the AC adapter. Repair of the connector on the motherboard could run about $125-$150 at a trustworthy repair shop. AC adapter replacement may be $25 over EBay.
If this information was helpful, please give a high rating. Thanks.
Apr 20, 2011 | Dell Inspiron 1318 Laptop Computer PC...
I have an ASUS eee netbook. Recently the power cord hasn't been connecting well to the computer and now it doesn't even register. It's plugged in but isn't charging. Is it the cord or the laptop?
You have a bad DC connector, which came loose from the system board:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
Here is a tutorial on how to fix a DC connector problem. You may want to have a tech fix it.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Nov 30, 2010 | ASUS Computers & Internet
Advent N270 netbook will not charge. Orange light comes on initially then goes off. Also when I wiggle the plug into the laptop the light flashes on and intermittently.
It sounds like either a bad connection on the motherboard or a broken wire in the adapter making intermittent connection.
1. With the power adapter disconnected, do you have a power light? This would indicate the adapter is good and the plug is questionable.
2. Check your power adapter output with a multi-meter.(be sure to wiggle the wires around) If the power fluctuates, replace the plug.
3. If the power is solid, replace the motherboard connector.
Nov 22, 2010 | Intel Computers & Internet
The jack end of the ac adapter (plug into the
The jack has probably been ripped loose from the circuit board by repeated use over time. The jack must be de-soldered, then epoxy glued to the circuit board. Once the glue sets, the original connections need to be replaced with short sections of wire to bridge the broken portions of printed circuit. A relatively simple repair if done carefully. Hope this helps!
Apr 30, 2010 | Korg X50 61 Key Synthesizer Keyboard
I keep the ac adaper in but the charger doesnt
you can see the problem if the battery in not charging or not loading some current. you can do this by unplugging the adapter on the outlet. if the unit turned off then the battery is defective. replace it. now if the problem is the adapter, you can see by removing the battery then plug the adapter to the unit and in the outlet. if the unit didn't turn on, the the adapter is defective. replace it.
Apr 10, 2010 | Acer Aspire 6930-6771 Laptop
Ac adapter connection inside laptop doesnt work, light for battery charging will not turn on and will not charge
You adapter may be faulty, check it with a multi-meter, the voltage reading for a functioning adapter should be slightly higher than the voltage that is printed on the label on the adapter.
If you do not get a voltage reading then the adapter is faulty and you need to get a replacement adapter.
If you get a reliable voltage reading at the adapter plug, then connect it into the laptop and wriggle this plug. If the charge LED blinks. then the power connector on the laptop is loose/faulty and needs repairing.
Apr 14, 2009 | Acer Aspire 5570-4820 Notebook
It seems that my laptop want go to ac (adapter) and shuts down
Most likely your problem is caused by a loose connection on the main board of the laptop. Even though it will plug in to the connection, the connection on the mainboard is either cracked or broken. Laptops are VERY hard to work on and you need to find a authorized repair shop for that brand computer in your local area to properly fix this problem.
Dec 22, 2008 | Acer Aspire 3000 Notebook
Alarm and power probelm
If you already took the printer apart, check the socket where you connect the printer to power, check that the connector soldering joints and contacts are not broke.
The circuit area near the AC adapter socket on the printer is the power board.
If there is a fuse check it.
If there is smell or trace of burnt, that means that a component, usually a capacitor, had blown.
If you do not find anything it must be the AC adapter terminal cable, or the connector , that has a broken contact.
To test it you need to get a multimeter and measure voltage from the AC adapter connector. Alternatively take the printer to a repair shop , tell them that you want to buy a power adapter for your printer, and ask to test a spare power adapter first. Many shops do not charge repair fee for this, as long as it can be done on the fly, and printer must not be left in for repairs.
Nov 07, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Nintendo Super NES Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
