Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
No picture, blue screen only
When the TV is turned on, all we get is a blue screen, with a slightly lighter blue circle in the center. Does this mean the lamp needs to be replaced?
  • 927 Answers
Good Day;
It sounds like you have a lack of signal; 1. reset TV by unplugging TV & signal sources from wall for at least 5 minutes then plug back in, 2. Turn all eguipment on such as cable box, dvd & etc, then change the inputs from your TV's remote, if still no pix,only blue.
Good Luck.
Posted on Jun 13, 2008
Sony Wega projection tv with cirlce emblazened in center of scree
The clown face you see is the cap that the repair man (clown) did not remove from the new optical block he/she installed. The optical Block will have to be either removed from the TV so that the cap can be removed OR a crafty individual could take the screws out from around the screen frame and mirror cover and pop it out using a broom handle with a wad of duck tape on the end. In any case, this is mistake that can easily happen (I have done it), but the picture should have been verified before it was returned to you. Make them fix it in your home. I hope this was helpful, best wishes.
May 05, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a green circle just right of center on the top of the screen that is about 5 inches in diameter.How do i fix it? I also have the "Replace bulb now message, and reset timer". How do I make that go...
To remove the lamp message turn on tv. Hold down the vol - button on tv and hold the 0 button on the remote at the same time for 5 seconds. "THE LAMP TIME WAS REST TO 0" will appear on the screen. As far as the green circle you will need to replace the light engine.
Sep 25, 2009 | Panasonic PT-61LCX66 Television
Blue circle in the center of picture
I need to know what color you got the circle in because one of your lamps went out and needs to be repaired this circle is only going to get bigger an bigger and shall i go on? Easy fix buy the new one and have it put in around $90 bucks plus labor.
May 24, 2009 | Hitachi 46F500 46" Rear Projection...
Blue circle of color in middle of screen
This is your Light Engine that is defective. They usually cost in excess of $700.00 to replace. Not the Lamp.
May 02, 2009 | Televison & Video
Lines on TV Screen
Depends on the TV model, if this is a rear projection TV with CRT lamps, that means that either CRTs are not aligned (fault on convergence board) or one or more CRTs had blown.
Jan 02, 2009 | Televison & Video
Red & green lamps shutting off leaving a blue screen
Could you show a picture of the distended cover you mentioned?
Were the light blue lines you were referring to, diagonal, or truly horizontal?
Oct 15, 2007 | Sony KP-57WS500 57" Rear Projection...
Blue area near center of screen
Uh Oh! blue screen of death. Your light engine has warped a little from overheating and is distorting the picture.
My suggestion to you is to get on the phone with hitachi and start complaining, then keep complaining until they agree to pay for it. You may have to get the problem diagnosed by a pro before they agree to pay for it though.
Oct 08, 2007 | Hitachi 50V720 Television
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
546 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
