I have a intertherm furnace M1MB077ABW I am trying to find a wiring diagram to show the hookup for the A/C as there is no Y terminal on the board, Do I just run a wire from my thermostat to the condenser and back to C on the board, and does this bring my fan to high speed?
  • riyoung May 01, 2008
    Thank you ,I understand about the fan center, the furnace that was sold to my friend is A/C ready and is suppose to have the relay built into the control board, I think that I can just run my wire from Y on the stat to the condenser then back to common on the board, the switching will be done in the stat through G bring the fan on.What do you think?
  • 828 Answers
You may find that you must install a fan control center. This has a transformer & relay for bringing on the fan for the cooling mode and will also have all the necessary terminals for your connections. Your stand alone furnace will more than likely need a higher VA transformer which is part of the fan control center.
Posted on May 01, 2008
  • James Helmer
    James Helmer May 01, 2008
    Do that and you have it right.
Need a wiring diagram for a EEH-012H intertherm
Request the wiring diagram from Hunter and, if need be, Intertherm.
Feb 12, 2018 | Hunter Heating & Cooling
I have an intertherm center heater. I just purchsed the new house and it finally became summer. I tried to turn the fan on only as I am used to in other homes. However, the fan does not come on. I looked...
the problem is because of the loose connections i think so ,if you have warranty for your device then go for it,because repairing by own may void warranty.And also without seeing ,we cant repair by trial and error method ,so better go to serivce center and service it
Jul 01, 2008 | Intertherm Heating & Cooling
I need wiring diagram for intertherm mac2454 furnace
Request the wiring diagram directly from Intertherm.
Dec 14, 2017 | Intertherm Heating & Cooling
We have a interthem 2460 a furace and we need to know where to find a wiring diagram to show us how to connect it to the electric
If there is not a wiring diagram pasted inside the furnace somewhere, request it directly from Intertherm. Be sure to specify model 2460.
Dec 09, 2016 | Heating & Cooling
We have the intertherm E2EH-015HA. The AC Coil drain was plugged and the water over flowed and burned out all the wiring. The only wiring diagrams we can find do not show how to complete the circuit for...
The G terminal on the thermostat most go to the G terminal on the control board, so the green wire that is attached to the G terminal on the subbase of the thermostat must go to the G terminal on the intergrated control board on the furnace. I will post a pic of how the wiring goesrobhvac47_8.jpg
Jan 18, 2011 | Heating & Cooling
Have an Intertherm thermostate in mobile home controlling gas hearing and elec ac. Blue wire to thermostat connects to the "A" terminal on the thermostat...Blue wire goes to a terminal on the...
If there are only two wires going to the thermostat? Then you will not be able to use a Digital Programable stat. Intertherm and Coleman furnaces do the switching different than regular furnaces. They use the switching from heat to AC at the furnace with the rocker switch. They use the thermostat to either break the connection or make the connection. They use a heating only thermostat.... Hope this helps
Jan 02, 2011 | Intertherm P3RA-048K Air Conditioner
Intertherm Heat Pump
Some of the old heat pumps made the reversing valve in the heating mode. On your new thermostat the orange wire will need to be on the B terminal. If it was color coded? I hope you made notes of how it was.
Jan 05, 2010 | Heating & Cooling
Intertherm MGH-056ABFC-91 won't kick on. Just changed thermocouple, gas valve, and thermostat this week. Changed fan motor, blower wheel, and limit switch last winter. Pilot is lit, thermostat is set. The...
At the furnace, jump the R and W (or T and T) terminals on the circuit board or gas valve. Make sure the door switch is closed with some electrical tape. By doing this we are forcing the unit to start. If it does fire, you have either a bad thermostat or a broken wire to the thermostat. If it does nothing, look for a bad fuse, check for 24 volts going to the gas valve, an open limit switch or 120 volts at the transformer.
Nov 02, 2009 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
211 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
