Question about Estate TEDS740JQ Electric Dryer
Wires burned I saw a spark from behind the dryer and when I got it apart there were two wires burned away from the plugs they had been attached to
  • 47 Answers
THEN IT IS TIME TO BUY A NEW DRYER. WIRES ARE USUALLY HARD TO COME BY UNLESS YOU CAN FIND AN OLD DRYER WITH GOOD WIRES ON IT AND PUT ON YOUR DRYER. GOOD LUCK.
RODNEY
Posted on May 16, 2009
Tore the saw down two wheeks ago got the parts for four the saw four got where the whires go on coil. And the switch stihl 021
I believe you have 2 wires apart from the ignition wire to the spark plug. The black one goes to the on/off switch and the yellow / green goes to earth and is normally attached to a screw near the ignition module - one that fits into the metal body or the engine lump.
Dec 24, 2016 | Stihl Garden
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Why is my kenmore dryer sparking and tripping the breaker?
You can cut the old wires and apply new connectors but you have to have the right tools to put on the connectors. A new cord is not that expensive and it would be easier than trying to repair the old one if you have never done it before. Good luck
May 04, 2014 | Kenmore Dryers
I have a Stihl 025 that I can't seem to start. The two things I have noticed after I took things apart is that there is a grey wire that is not attached to anything, and dosen't seem to have anywhere
Jon try check the wires coming from the ignition coil to the on/off switch. one is a ground and the other goes into the coil. When they are connected the coil is turn off and will not spark.
Dec 24, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
How do remove the spark plug wire harrness on the front of a 1990 buick century
Use a suitable spark plug wire tool to remove wire from spark plug being careful not to end up leaving the terminal from the wire on the plug. If the terminal is ripped away from the wire you will have to repair it by spreading open the crimps and reattach to wire and recrimp. Silicone spray works well to slide the wire further past the spark plug wire boot to make the repair.Always use die-electric or silicone grease on the inside of plugs wire boot before you attach to plug, it helps removal for next time and it seals the boot so spark dont leak from boot and makes a moisture barrier as well. Now to answer your question if the wires are in a loom holder you have to take the top part of the loom holder apart to get wires out of it . The loom holder usually just pops into slots on the bottom part of the loom holder. It shouldn't be too hard to figure out
Nov 01, 2009 | 1990 Buick Century
1992, 4.9L f150 has no spark. I have a new distributor, computer, ecc, coil, wires, plugs, checked fuses, cleaned connectors, new relays, have 12v at the coil, good ground and no spark at all? help.
Help,
I have a 92 F-150 XLT with a 5.0. The ignition switch block burned up so I replaced it. Now it will not get spark when I crank it over, but when I crank it and let off of the key, I get one spark jump from the coil; to the distributer. (I have a spark tester I placed on the cap to the wire) I have replaced the coil and the ignition module that is on the fender attached to the brain, I have replaced the ignition cylinder and key (It was acting up) and I took the dash apart to see the wire harness to ensure there was no burnt wires. (The wire connection to the ignition block is not damaged from when the switch burned.
Does anyone know if there is a part that tends to go bad when the ignition block burns up??
Help, Thanks, Todd
Oct 17, 2009 | 1992 Ford F150 SuperCab
Dryer just quit heating
First-***DISCONNECT THE ELECTRICITY***. Open the back of the dryer. The element will be in a flat metal tube running from the top to the bottom of the back of the dryer. There will be a few wires connected to it. Mark where these go for reassembly. The heater wires are inside the tube. The whole assembly comes apart quite easily to replace the element. It looks like a stretched out spring.
May 02, 2009 | Whirlpool LER5636L Electric Dryer
Changing from 3 prong to 4 prong cord
Mar 19, 2009 | Dryers
Washer and dryer do not work
wires were shorting each other out that go into plug - once took apart saw the sparks so just cut and shortened wires and reconnected them to plug
Jan 27, 2009 | Maytag LSE7806A Top Load Stacked...
What do I need to do if the dryer cord and terminal block has burned out?
Hello sir,
I think this is voltage problem. At the time of using u received high voltage of current so it burns.It can be repaierd. Just replace that particular part only. Go to authorized service center and replace only that burned part.
thanks
Don't forget to rate the solution
May 11, 2008 | LG DLE3777 Electric Dryer
Estate TEDS740JQ Electric Dryer Logo
79 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Mike
Are you an Estate Dryer Expert? Answer questions, earn points and help others
