Question about Linksys WRT54G (0745883555482) Router
Linksys Lnksys.com/easy can not detect my royter
  • 552 Answers
If you have installed the driver from the cd rom that came with it, you should be ok.
You will need to go to.......
click the start bottom left of your windows.
click control panel.
click network and internet connections.
click setup your home or small office network.
a new window will pop up.
this is the network setup wizard.
click next.
from there follow the instructions.
Posted on May 01, 2008
WRT300N is no longer detected
Hook up your ether cable to a port other than the WAN port.
Type this into a browser...
http://192.168.1.1
Linksys WRT300N Wireless Router. ... Default IP address: 192.168.1.1
Oct 01, 2009 | Linksys WRT300N Wireless Router
Lenovo laptop cannot seem to find the linksys wireless g. we have two WIFI at the office one is linksys VOIP (secure) and linksys wireless G (unsecure). why is it that lenovo laptop only sees the secure...
make sure that the linksys VOIP(secure) router is broadcasting it's SSID or signal, otherwise it will not reflect even if you refresh the wireless network. If the router is broadcasting SSID but the lenovo laptop is not detecting it, try to re-install the wireless software for the laptop using the software from lenovo.com, just click Support then Downloads and drivers.
May 13, 2009 | Linksys Wireless-G Broadband Router
I need to dwnload wireless driver without driver detective
hi...
THIS IS THE LINK FOR THE DRIVER IF YOU HAVE VERSION 1.0....http://www.linksys.com/servlet/Satellite?c=L_Download_C2&childpagename=US%2FLayout&cid=1115417109934&packedargs=sku%3D1115416826820&pagename=Linksys%2FCommon%2FVisitorWrapper
THIS IS THE LINK FOR THE DRIVER IF YOU HAVE VERSION 1.1(THIS PAGE HAS DRIVERS FOR BOTH VISTA AS WELL AS WINDOWS Xp)...http://www.linksys.com/servlet/Satellite?c=L_Download_C2&childpagename=US%2FLayout&cid=1115417109934&packedargs=sku%3D1123637884333&pagename=Linksys%2FCommon%2FVisitorWrapper
hope this will be helpfull...
vedhick
Jan 19, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
The cd wont work that i got with the wireless router
Yes you can install it without a CD you just need to call the Linksys tech support number and a tech will walk you through in manually configuring the router without the use of setup CD dial this number its free 1800-3267114 and yes your WII will work fine with it Lnksys will also be able to help you with that concern..
Hope that helps..............
Aug 06, 2008 | Linksys Wireless-G Broadband Router
Router not detected
May I suggest a quick and easy fix, maybe not so cost effecient UNLESS you can return the linksys router. If you are using DSL, then I recommend a D-Link router for your access point. Linksys routers are commonly not compatable with DSL modems. If you get the D-link, you should have no problems with plug and play.
Mar 18, 2008 | Linksys Wireless-G Broadband Router
Firmware
Here's the Linksys step-by-step guide for your router:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3686&lid=5531661879B01
Are you connected to the wireless router with an ethernet cable? Generally, you want to hook it up this way first so you can configure it. If you are hooked up with a cable open your web browser and type in the following address: 192.168.1.1 this should get you to the router's web page. The default login for linksys is username: blank, password: admin
See if you can connect to the router in this way. If you can then we can go through the next steps or you can try using the above link.
Good luck.
Dec 19, 2007 | Linksys Wireless-G WRT54GS Router...
Conection problem
If you are using the highest level of encryption available, your laptop may not support it.
back up the configuration file then reset it and set it up to be used without any encryption then see if that works.
If it does then the encryption is your problem, this is only the case when using WPA 1 or higher.
Dec 14, 2007 | Linksys Wireless-G WRT54G Router
Linksys WRT54G (0745883555482) Router Logo
74 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
