Do I still need an ouside ariel to tune in the channels on my dvd recorder despite having virgin media. I am currently using a hdmi cable and three scart leads to play a DVD and still cannot record anything
  • 476 Answers
You can only tune the channels if the recorder is connected to an aerial, however you can still record from the V-box connected to the recorder via scart, but you can only record the channel you are watching.
Posted on May 02, 2008
My TV will not stop switching itself off
Hi, The first thing to do is troubleshoot your TV independent to any other service provider that has a box that probably connects to your TV via a HDMI cable or old version scart.
Simply turn off your TV and turn off the socket that the TV is plugged in for 20 mins. Also turn of any Virgin media boxes.
After 20 mins turn on the TV. Do not worry if you get a message saying no signal detected. Wait and see if the TV stays on with no messages such as auto-standby. If the TV remains on with no problems then turn on your Virgin Media Box. The box will need to initialise ( about 30 seconds ) and then the TV should recognise the HDMI signal and you will see the Virgin TV.
If your TV turns off at any point during this process you have a fault with the TV, If when you turn on the Virgin box and no signal is detected you have either a cable connection problem or a Virgin Box problem, so using your TV REMOTE turn your TV back to ARIEL input to receive the normal television broadcasts via your Ariel that give you the normal freeview television that all modern TV's can receive, if you can get the normal reception contact virgin support who will troubleshoot your problem.
Nov 07, 2017 | Internet Computers & Internet
My Polaroid TV is connected to Virgin yet most channels are pixelated and the tv looks like it needs fine tuning, but i can't. Any help?
on the tv screen menu go to display and reset the a settings the larger the numbers the better the picture --apply and ok
Oct 22, 2017 | Polaroid 4241-TLXB 42 in. LCD Television
How do I , or in fact can I, tune the DVD recorder such that it can see the digital TV stations - all I get at the moment is analogue channels
can you receive digital channels through your tv (if it is a DAB TV)? The reason i ask is that you may not have a strong enough signal to receive digital channels. Try taking the dvd recorder to a friends house and plug it in there to see if it will tunethe stations in. IF it does try it back at yoursto see if it will pick up the channels if it breaks up the picture then you need to upgrade your ariel
Mar 11, 2011 | LG RHT397H DVD Recorder
I have a JVC RM-C60 TV. I'm trying to tune it in to my Virgin Media HD box using a standard SCART lead but having no joy. It's completely failing to find the cable channel (or any other for that matter)....
Tuning of the TV not required when using scart lead, just select external input that the scartis connected to, ie AV1,AV2 (EXT1,EXT2) etc. The problem is possibly to do with the Virgin box, it may be set to HDMI out in which case it will not output anything via the scart lead, you would need to connect via an HDMI lead (small socket on the rear of the unit looks a little like a USB socket). Problem is if your TV is a CRT television its unlikely to have this socket. Your Virgin box can be reset to output via the scart but you would need to contact Virgin for this process.
Feb 17, 2011 | JVC Televison & Video
I want to connect a Virgin HD box to my Panasonic TH-42PV500B TV currently connected to a Panasoniv DVD recorder On Scart AV1. How do I switch between Virgin and existing equipment which I would like to...
what you need to do is obtain an HDMI cable for your Virgin HD box. Leave the rest on scart (you can probably even add a another box now that you've freed up one port). Basically just press the button on your TV remote, saying 'Source' and you can flick through all your scart soxkets and HDMI ports. Simples.
Oct 24, 2009 | Panasonic Televison & Video
Dvd recorder hard drive DVDR5350H
This depends on how your video signals are delivered to the box, in most cases terrestrial TV signals received by ariel, cable are passed through the recorder, then to your TV, this means you can record 1 channel on the box and view another, it appears that this recorder only has 1 tuner so you cannot record 1 station and watch another on the output of this box.
with regard to freeview / satellite tuning, these are connected directly to the DVR and they only have 1 channel to view at a time, so unless you acquire a satellite / cable tuner which allows for dual channels or if you acquire a second cable/sattelite box from your provider it is not possible to record 1 channel and view annother
so this problem can be circumvented with other products, but the expense may be more than you expected, as most cable / sattelite provders will charge to provide a second box. also you will also have to be aware of interfeerance with remotes if 2 sat boxes are used. as the remotes are likly to be similar.
Oct 03, 2008 | Televison & Video
Viewing cable tv channels
Use an av output from your media box and plug it into the line input of your DVD recorder. It can record using the line input of the DVD recorder.
Aug 09, 2008 | Televison & Video
Panasonic dvd recorder dmr ez47veb
If your cable is connected with just a scart lead (in AV2) you just put the recorder onto the AV2 channel. You need to connect the cable decoder to the recorder via an arial lead to be able to tune it in but there is no need just use the AV channel.
Dec 03, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Electro Med Services...
