Question about Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor
It is a dell 17 inch monitor
Hi
i turned my computer on and the monitor just went black
it is not the computer because i just plugged up my old monitor and it works fine
i tried to see if i could fix the coloring on it but you can barely see because the monitor is just black
please help
  • 46 Answers
The logic board on the LCD panel itself goes out a lot on that unit. If you have everything but a picture then that is the problem. Rub your finger on the screen if you see light behind your finger but no picture then this is definently your problem. If there is no light then your inverter is the most likely problem. www.lcdrepair.us sells all parts for that unit.
Posted on Jun 21, 2008
Dell E173FP 17 monitor went dark and not working. I restart the pc it shows for only few second and went out again. I plug in one other monitor in my pc and it work fairly well. So something not right with...
Hi!
There are three possible cause why your monitor went black and start working..
1. If your monitor is dead set.. no reaction or lights turn on after power on.. then it needs to check if there is blown capacitor in its power supply section..
2. The high voltage ballast transformer of the backlight inverter is burned - it needs to be replaced so that it will not have a direct effect on the power supply section of the monitor.
3. The backlight inverters are all busted - the backlight was located at the upper and lower back edge of the monitor.. If these lights are busted then all that will be seen in your monitor is black screen.. It will need to be replaced so that image display will come out from your screen..
These 3 reason and its solutions can only be done by yourself if you have the knowledge, proper skills and the right tools to open the back cover of the monitor and replace the problem parts....
Otherwise, bring your monitor to a credible technician and if there is warranty,, avail of this...
Hope that answer your question..
Much appreciated if you rate this help..thanks..
May 20, 2010 | Dell E173FP 17" LCD Monitor
Monitor went to black. checked and changed all
Check our web site at: www.ccl-la.com/badcaps.htm We have a free repair guide for that model Dell monitor.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Nov 03, 2009 | Dell E173FPb 17" TFT LCD Monitor
I plugged it in and the screen came up for a second and then went black. I turned it off and turned it back on, the screen came up for a second then went black again. What could be wrong?
is the cpu running ,, with connection to monitor,, you can try restart,, and go to display properties,, screensaver,, there power button and change the settings,,,
Sep 27, 2009 | Dell E173FP 17" LCD Monitor
I have a Dell 17" flat screen ultrasharp monitor. It suddenly went dark and will not power up. Can it be repaired?
With the dropping price of monitors today; can get a good 22 inch lcd for less than $200 in most stores, it would probably cost more to have the old monitor repaired than just replace with a new monitor. Hope this helps.
Jul 17, 2009 | Dell E173FP 17" LCD Monitor
Dell monitor
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's most likely the problem. You can confirm that it's actually the monitor and not your computer or the cable by plugging in another monitor if you have one to try. If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old your monitor is, and how much you've invested into it, you may find it better to just replace it with a gently used one from ebay.
Jun 09, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FPc monitor. Screen is black, power button color cycles
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any
surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective.
What are the results please?
Feb 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Turn on the monitor
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Bottom third of screen went black
Vertical section problem
change all caps in vertical sec and replace vertical IC
Oct 10, 2008 | Dell UltraScan 1000TX 17 in.CRT...
Dell lcd monitor with vertical lines
You have a filter problem, check power supply for bad capacitors.
Mar 24, 2007 | Dell E173FP 17" Flat Panel LCD Monitor
Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor Logo
41 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
