Question about Janome 1600P-DB Mechanical Sewing Machine
Machine vibration I just bought the Janome 1600P and the Gracie Pinnacle Quilt Frame, the problem I am having is that the machine has started vibrating. I have oiled it and have done very little sewing on it, I contacted my dealer and they took it and looked it over and even came to my home and said it is normal and I want to know if anyone else is having a vibration problem, my machine is 2 weeks old and it did not vibrate when I did my first quilt.
    Problem Solver:
  • 6 Answers
Check to see if the machine is setting securely on the quilt frame .also check to see if the frame is setting level on the floor
Posted on May 06, 2008
I have a Janome 1600P DBX. The needle is installed correctly but the thread on top keeps breaking or skipping stitchings while free motion quilting? the quilt shop says it is not out of time. I have...
Is it a new needle? a dull needle or one with a burr on it can cause those problems that you mention.The kind of needle you use is also very important. I like to use a 70/10 or 80/12 jeans needle depending on how thick the thread is.
Apr 20, 2011 | Janome 1600P-DB Mechanical Sewing Machine
I'm using a Janome 1600 DBX on my Grace quilt frame. It keeps skipping stitches and breaking the thread. I put in a new # 16 Janome needle - made sure it was installed correctly, and tried 30 weight and...
The tension is not right and you are moving the machine to fast. Go back to your 50 weight thread top and bottom. Have you got a quilting foot on and the foot in the down position
Dec 01, 2017 | Janome 1600P-DB Mechanical Sewing Machine
I recently acquired a Janome 1600 with the Gracie II Frame. I am having trouble with the bobbin thread being too loose. How do I fix this.
Is the problem with the thread being wound too loose on the bobbin or is the bobbin thread too loose on your sewing? If it is the later, refer to your book on tightening the thread by turning the screw [very little at a time] on your bobbin case.
Oct 18, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Top thread keeps breaking on my Janome 1600P.
I had a similar problem and then realized that the thread on the top had a **** on the spool it was catching on.
Sep 23, 2009 | Janome 1600P-DB Mechanical Sewing Machine
I have a Janome 1600P QC drags on a Little Gracie 2 frame
Sorry for your headache. It is the frame. If it is not level, balanced, you have hell to pay. Also it there is a nick in the grooves of the carriage tracks this will cause a machine problem. You may be able to repair the frame, or level it about the old level the table trick, put something under that part.
Good luck
Sep 06, 2009 | Janome Sewing Machines
Skipping stithes
Try practicing on a test piece before moving on to the quilt. Batik fabric is beautiful! I would check the thread size and needle. I tried quilting with invisible thread and had the same problem. The minute I changed to 50 wt.thread and a new needle the problem disappeared. I've found that 40 or 50 wt. thread works best on my Janome.
Oct 19, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Frame quilting with janome 1600 db
am I right that the feed dogs do not drop on this machine?
Yes, this is correct....but you have to change the needle plate to a thicker one, so the feed dogs will be below the needle plate.
Feb 13, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Thread breaking
I HAVE THE SAME PROBLEM WITH THREAD BREAKING. HAVE TRIED EVERYTHING. FINALLY I GOT SOME UPHOLSTERY THREAD AND IT SEAMS TO WORK MUCH BETTER. NOW i AM HAVING TROUBLE FINDING THE NEEDLES FOR THIS MACHINE. NOT HAPPY WITH MACHINE AT ALL
Dec 09, 2007 | Janome 1600P-DB Mechanical Sewing Machine
Quilting
Janome now has a darning foot ie it looks like an embroidery foot with a spring designed for the 1600 models. It is metal with a ring where the needle goes down through it. I removed the plastic lens inside the ring and this seems to have resolved the problem.
I usually pull my threads to the top so I can see where they are and not getting tangled underneath.
There are several good groups on Yahoo groups which offer support for starting out on quilting
Oct 03, 2007 | Janome 1600P-DB Mechanical Sewing Machine
Janome 1600P-DB Mechanical Sewing Machine Logo
207 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
