Vacuums Logo
Posted on May 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
If the circuit board has a problem can it be fixed?
Anonymous
Level 3:
President:
  • Master 1,673 Answers
  • Posted on May 01, 2008
Anonymous
Master
Level 3:
President:
Answers
1673
Questions
Helped
704492
Points
3439
Don't know what circ. board your are talking about, but usually they get replaced and not repaired.
Need location to buy replacement circuit boards or parts lists for circuit boards
many components can be sourced from shops like Jaycar or the like
try the manufacturer for a complete board or a schematic of the board
1helpful
INTERMITENT POWER
Richard - yes you can buy the control board but its really not worth it. If you have the surge problem it's an easy fix for the cost of capacitor.
Riccar 1700 melted connector to circuit board...
It might be an easy fix but should be done by a qualified Riccar dealer.
Miele vacuum s5980 no power
your main circuit board is also your speed control the motor should not have a circuit board i don't believe. open your machine up all the way to the motor and cord reel. check voltage at cord reel should be 120 +/- 10. if voltage is correct then replace speed control board.
1helpful
My circuit board has a short on the soldering for the DC rectifier that supplies the carpet cleaning motor. Where can I order a new circuit board. Miele S251i
Just a suggestion, but you could try to re-solder the connection on the board. some of the circuit boards did not have enough solder on the board coming from the factory.
That being said, if the component is damaged due to the burning, I suggest you contact your local Miele dealer and have them order you a circuit board for the unit.
IF the unit is less than 5 years old as well, that part should be covered under warranty. Do NOT solder it, just have them replace the part.
Good luck
My Renny brush is not moving what do I do? I just had is serviced for $200 and brought it back once already, he is claiming now that it is the circuit board. I do not trust him to fix the problem, can I...
You have two circuit boards in th Renny, one is in the handle of the hose and the other is called a triac located next to the motor in the canister. There is a long and drawn out procedure in trouble shooting the problems with the Renny and if you don't know what to do, you will be in more trouble than you are now.
The best thing is to find a reputable Aerus/Electrolux dealer/shop and have them to find what the problems are.
Joe
1helpful
Bissel Proheat 2x circuit board
Use this link: http://www.4cleanerfloors.co.uk/cgi-bin/product.pl?PID=1278118_amp;brand=Bissell_amp;model=_amp;part=
I had the same problem. Ordered a PCB from Bissel it took 2 weeks to arive. I fitted it, then it blew again, turned out the brush motor was short circuiting. Ordered a new motor it took 10 weeks. I have now had to order the second circuit board.
Over 3 months to get this vac fixed - my advice is - don't buy Bissels!
Hoover Savvy Model U8181-900 Rewiring
The brush roll motor is most likely what caused the problem to the circuit board. You would look at about $100 or so for the 2 parts.
Jan 16, 2008 • Vacuums
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
