Question about Xerox Phaser 6250DP Laser Printer
Phaser 6250 I have the same problem you do where there is a high pitched whine and then I know there will be a jam. It is intermittent. Did you get yours fixed and was it the fuser?
  • 1 more comment
  • deejaybee Jun 02, 2008
    My 6250DP has the same whine and paper jam. It happens about 50% of the time. I had the repairman come and replace the main drive assembly and that didn't fix it. I saw this post about the registration clutch so he ordered that part but that didn't solve the problem either. So, we removed the new parts and I'm back to the original parts. Any other ideas? The repairman said the next repairs would be more costly like the Control board (over $400). Is it worth the money trying to repair? I just put in a new Imaging Unit and all new ink cartridges so I need to use a little while longer since I just spent all that money. Thanks for any ideas you might have.
  • Badhillon Dec 06, 2008
    I have the same problem you do almost every day there is a high pitched whine and then I know there will be a jam. What a waste of time and paper.
  • Richard86 May 11, 2010
    Where in the UK can you purchase Xerox parts?
Xerox 6250 Phaser: Randomly, every 3~10 copies on a multi-run, a jam occurs at the registration. The paper is not damaged. The image on the last copy that exits will be about 3 inches late, meaning there is 3 inches of blank space before the printint begins. In other words, the paper was fed by the registration rollers too soon. I cleaned the registration clutch, but did not change the symptom. Another symptom, possibly related, the bypass seems to feed the paper too many revolutions. It feeds without a problem, but then the feed roller makes one or two extra revolutions after the paper has stopped moving. Sometimes a paper buckling sound will occur, but there is no effect on the prints. Any ideas?
Posted on Sep 17, 2011
I saw this and figured i would give my 2 cents
i have seen this many times but it did not have to do with the registration roller but the fuser.
but it is not the fuser that is actually wrong, it may require a fix patch.
the patch name is 6250FMSFix.psx.ps.
this patch will need to run through the centreware of the 6250
oh yeah sorry the cause, since the fuser has it's own motor to power the movement of paper, it is supposed to run on the printer clockspeed but does not, the fuser tries to move the paper too fast and get jammed. hope this help some.
Posted on Dec 30, 2008
    Problem Solver:
Sorry, but I never got mine fixed. I'm still using it with the jamming. You get to know that whine before it prints so you can open the door and hope that it resets and the whine goes away. Sometimes it takes 3 or 4 times before it works. I wish I had better news for you.
Posted on Dec 02, 2008
  • deejaybee Dec 04, 2008
    Is that something you could send to me to see if that would fix my printer?
I had a similar situation about a month ago. The jam only occured when the printer was coming out of sleep mode. After replacing the same parts others have tried with no change, I was sent a snippet that Xerox put out to correct a voltage issue causing the fuser roller not to turn. After loading the snippet the printer has worked as new. Gotta thank Whitt at Item Inc for the info on the snippet.
Jim
    President:
  • 2,072 Answers
That problem is the registration clutch.
You have to order the registration assembly to get the clutch. It is located on assembly with the black and stainless steel roller, you have to pop out the imaging unit to see it.
But that WILL fix your problem. They changed the style of clutch also. It is more reliable now.
Posted on May 03, 2008
  • Rick Kasper May 03, 2008
    Here is the part number for what you need.
    116-1598-00
    You snap out the one plate on the right. remove the 4 screws and unplug and replug 2 connectors. It really is not a hard replacement at all.
How do I find the page count for the printer
Phaser 6250 Support - Xerox Support and Drivers
www.support.xerox.com/support/phaser-6250/support/enus.html
XeroxProduct support for Phaser 6250. ... with our support knowledge base directly, and troubleshoot itself. Automated Remote Diagnostic Tool - PhaserSMART™ ...
Oct 02, 2015 | Xerox Phaser 6250DP Laser Printer
Phaser 6250 DP keeps on jamming at Fuser.
Paper type set correctly? Does the paper enter the fuser? If not, the fuser drive has failed, replacing the fuser may correct it.
Nov 19, 2010 | Xerox Phaser 6250DP Laser Printer
Jam at registration roller?
I can tell you "exactly" where your jam is !
If you open the top cover and remove the imaging unit. Look straight down, and you will see a black rubber roller about 8 inches long. this is the registration roller. If you remove the four screws (two on the left side, one in the middle, and one on the right) and gently lift up your wrinkled paper will be right there. Since your are not replacing the registration assembly you do not need to remove the two connectors that attach to the main board from the registration assembly. Just remove the paper, reseat unit, and put back screws. There is a test to see if your unit has the fix that gives the drive assembly a little more power to aviod jams in the future. This is a software fix.
I believe it's available on the xerox website as a postscript snippet. xx.ps
Mar 17, 2009 | Xerox Phaser 6250 Laser Printer
6250 Jam
Go to the Xerox website and select the drivers tab. Select the 6250 and search for the firmware for > Firmware Updatethen follow instructions
Dec 04, 2008 | Xerox Phaser 8500/DN Printer
Papaer will not feed
High ITConsult And MarkoP
The high pitched whine and the paper stopping just before the fuser (the hot) unit is a known issue on the C3000 and C4100. If you are still searching for the solution to this issue, let me know, as I now have a working fix for the problem.
Reply to this post for further info.
Jul 10, 2008 | Epson AcuLaser C3000 Printer
Phaser 6250 "Ram error" (?)
TRY FIRST (Solutions without parts):
For a continuous RAM Error message, try cleaning RAM contacts and reseating RAM.
NOTE: Third-party or generic RAM is not covered by warranty or service contract and should be removed for troubleshooting purposes.
TROUBLESHOOTING TIPS AND HINTS:
Replace RAM. If problem is not resolved, replace the Image Processor board. Please Note:
Intermittent 6250 RAM Errors can be resolved by replacing the Print Engine Board and EEPROM, remembering to Save/ Restore in Diagnostics.
Apr 15, 2008 | Xerox Phaser 6250DP Laser Printer
High pitched whine
Ok maybe this may help .... there is a coil LL08 I believe... somtimes it creates a high pitch whine like you describe.. its stands up on the deflection board..it basicaly a large coil of copper wire....you can take silcon and put on the coil...in effect damping the ocillations...hope that might help
Mar 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Xerox Phaser 6250DP Laser Printer Logo
967 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
