Xerox DOCUMATE 510 Flatbed Scanner Logo
Posted on May 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Copying duplex documents
HOW TO SCAN DUPLEX DOCUMENTS
I need to know how to scan a duplex document; I just got office 2007 and am learning all over again,
Hjalmer Lamminen
Level 3:
  • Master 552 Answers
  • Posted on May 01, 2008
Hjalmer Lamminen
Master
Level 3:
Answers
552
Questions
Helped
236577
Points
1540
Go here for an online document to help you solve this scanning of a duplex document issue.
or type in
http://www.fixya.com/support/p258233-xerox_documate_510_flatbed_scanner/manual-6075
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
438
Points
300ci will not copy 2 sided documents
from the copy screen touch the duplex button on the display and choose 2 sided > 2 sided. if it is not available in the menu the duplex unit may have failed repeatedly and shut itself down in which case you would need to go into simulation mode and perform a u906.
tip
ERROR codes Canon 3525
Canon 3525 E000 Fuser problem E000 Heat E010 Main motor, motor board, clock pulse E010 Drive E030 Counter E030 Counter E050 Duplex side to side problem E050 Duplex problem with cross alignment E051 Duplex side to side problem E051 Crossway registration E200 Scan problem E200 Scan reverse sensor or scan E202 Scan return problem E202 Scan home sensor or home scan E204 Scan E204 Document sensor, scan reverse sensor or scale E210 Lens problem E210 Lens E220 Lens E220 Blank lamp open or lens home problem E240 DC controller E240 Bad DC controller E400 Document feeder board problem or document feeder interface problem E400 Document feed problem E500 Sorter E620 Editor E620 Editing problem
tip
ERROR codes Canon 3025
Canon 3025
E000 Fuser problem
E000 Heat
E000 Fuser problem
E010 Drive
E030 Counter
E030 Counter
E200 Scan problem
E204 Scan
E210 Lens problem
E210 Lens
E220 Lens
E240 DC controller
E500 Sorter
E620 Editor
1helpful
2answers
Duplex copying on xerox phaser 3300mfp
I have the same problem and was told by the telephone helpdesk that the machine cannot copy double-sided to double-side. The duplexing referred to is copying 2 single-sided documents onto one single sheet on both sides....Like whoever does that! This is misleading on Xerox's part . Colin B.
How do i get my hp officejet j6480 all in one scan both sides and print
To automatically scan and print, you need to use the automatic document feeder (for letter-sized documents) and have the HP Automatic Two-sided Printing Accessory installed.
Then to use the duplex printing feature, you need to set the printer properties to use the duplex feature. In Windows, open a document to print then click on File Print. Choose Setup and then Properties or Preferences (depending on your OS). Then click on the Features tab and set Two-sided Printing to Automatic. (This is a drop-down menu on the Features tab.)
You also need to set the scan settings for two-sided in the HP Solution Center. (If you just want to copy the document, you can set this from the Control Panel on the J4680.)
If you want to do this manually, you can scan each side of the pages. Then print them one page at a time. Then when the ink is dry, put the page back into the paper tray. (Note: this could result in paper jams.) The printer prints on the underside of each page put into the paper tray with the top of the page printing on the forward part of the page.
I hope this helps.
I am using auto feed on HP 4345 MFP printer, the issue is I have documents with one side printed but printer is scanning both side and printing. How can I change setting to single side from Duplex scanning...
Mr. Agarwal
you have to turn off the duplex scanning option under copy settings this will solve the issue
You can go to settings and look for Copy setup or copy settings i dont remember well but you get an option of DUPLEX COPY or DUPLEX SCAN you have to turn off this.
DO RATE MY SOLUTION PLEASE
Saleem
How to scan picture to upload on computer
First, ensure you are connecting the scanner to your computer. I'm assuming USB connection, and that you're using an operating system supported by this device.
Next, install the drivers and software for this device. Those should have come with an installation disc, but if you don't have that disc, you can get them from the PIXMA MP830 support site, here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
To scan a single document, place the document:
1. Place the document face down on the platen glass.
2. Open the MP Navigator 2.2 software.
3. Click Scan Photo/Document.
4. Click Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
  • Color Document(Simplex): Select this to scan one side of color documents.
  • Color Document(Duplex): Select this to scan both sides of color documents.
  • B/W Document(Simplex): Select this to scan one side of monochrome documents.
  • B/W Document(Duplex): Select this to scan both sides of monochrome documents.
  • Text(Simplex): Select this to scan one side of text documents.
  • Text(Duplex): Select this to scan both sides of text documents.
5. Click 'Specify' and set the preferences as required. Click here for detailed information
6. After making the setting changes, click 'Scan'
7. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning
The directions for Batch Scanning, or using the ADF to scan, are shown below.
  1. Place the document(s) in the Automatic Document Feeder (ADF).
    1. To scan using the ADF, remove any documents from the platen glass.
    2. Open the document tray.
    3. Insert the documents face-up in the ADF and then adjust the document guides.
      Note:
      When scanning using the ADF, the documents will automatically feed.
  2. On the Windows desktop, double-click 'MP Navigator 2.2'.
    1. Alternatively, on the Windows taskbar, click 'Start', point to '(All) Programs', 'Canon', then 'MP Navigator 2.2'.
    2. Then click 'MP Navigator 2.2'. MP Navigator opens.
  3. Click 'Batch Scanning'.
    * Color Document(Simplex): Select this to scan one side of color documents.
    * Color Document(Duplex): Select this to scan both sides of color documents.
    * B/W Document(Simplex): Select this to scan one side of monochrome documents.
    * B/W Document(Duplex): Select this to scan both sides of monochrome documents.
    * Text(Simplex): Select this to scan one side of text documents.
    * Text(Duplex): Select this to scan both sides of text documents.
  5. Click 'Specify' and set the preferences as required. Click here for detailed information.
  6. After making the setting changes, click 'Scan'.
    1. After the documents are scanned, a dialog box will appear indicating to load the next document.
    2. After the next document is loaded, click 'Scan'.
    3. Repeat steps 6a and 6b until all documents have been scanned and then click 'Exit' to end the scanning process.
  7. After all documents have been scanned, ensure the documents, in the preview area, are selected (have a check mark).
  8. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning.
    Save to PC dialog box
    Save as PDF file dialog box
  9. Make settings to save a file. (Click File save settings for details.)
  10. Click 'Save' after all settings have been selected.
Duplex copying on HP Photosmart C8280 All-in-One Can't see how to do two-sided copy apart from scanning both sides and printing two-sided! Old HP printer could do 1-1 1-2 2-1 2-2 etc.
Open HP Solution Center, click on Settings, click on Scan Preferences, select "Scan both sides of original when using duplex feeder."
or
Open Solution Center, click on Scan Document, and you should have a check box towards the bottom of the window which would say 'scan both sides of the original document'. check that box and start scanning.
How could i make a duplex copy, where do i have to go
Duplexor printing is the only feature which HP All-In-One printer offers, where you can print in both sides of the paper from your computer if you have multiple pages to print.
But SORRY you cannot make a duplex copy on the stand alone machine itself.
But still you can scan and print the same on the duplexor.
For Scanning Multiple pages in one Folder:
All you need to do is if the All-In-One Printer driver and software is completly installed in your computer, Then you should have a icon in your desktop as HP Solution Center / Go to
Start> All Programs> HP> HP Solution Center>
Then click on Scan document> The in the option where it says Where do you want to send the scanned documents> Click on the drop down and select PDF / Word then make syre you
have selected Show preivew Box> Then click On Scan>
After it shows the preivew> Click on I Accept> NOW IT WILL ASK IF YOU WANT TO SCAN ANOTHER DOCUMENT> Click yes on this and replace the document> and the click on
NEW SCAN> and follow the same steps to scan multiple pages, till you have finished scanning all and then> When it asks if you want to scan another document> Click on No.
And then print the same through the duplexor
Good Luck
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
