Question about EliteGroup P4VMM2 Motherboard
Power problem I have a machine with the p4vmm2 board and it acts like its going to power up and enough power goes thru to turn the monitor, fans on but not enough for a whole rotation then power is lost. I replaced the power supply and that did not work. I am at a loss. Please help
  • 101 Answers
Please do NOT TRY TO SWITCH ON your comp in same condition again as you would be damaging it further. Its not your power supply alone there EXISTS A SHORT CIRCUIT IN OTHER COMPONENTS as well . The SHORT CIRCUIT Protection circuit of your Power Supply senses this and switches off preventing further damage . Well you could try this - Disconnect power to all the componenets like HDD , CD/DVD , MOTHERBOARD and FDD etc.,. Plug in the AC input power to your Power supply and on the 20 pin connector look for green colored wire and black wire on the same connector and short these 2 wires ONLY with a metal paper clip or a piece of wire , if the fan in the PS works and spins at full speed till you disconnect or remove the short between the two wires (Green and Black) then your PS is Working FINE . Now connect each of the component's power connector only and repeat the same exercise you will be able to identify which component is shorted.
Posted on May 06, 2008
My pc with EliteGroup P4VMM2 Motherboard didnot turn on but the fan and of cpu are working but wont open! what shoul i do? pls email me @ nhatz_cruel@yahoo.com
verify that the monitor is working if you can. Is the hard drive lite lighting up, If not try removing and reseating the ram. if the hd lite in on then it would sound like the graphics card is out, try replacing it.
Oct 21, 2010 | EliteGroup P4VMM2 Motherboard
Screen is blank
Hello
The issue might be that your monitor is not getting enough voltage to turn on properly.
If the monitor is plugged into a surge protector, remove it and plug it directly into the wall outlet. If the monitor works fine, the surge protector is not allowing enough power thru it for the monitor to work correctly - replace the power strip.
If there is no change, then your monitor is going out.
Dec 03, 2009 | Philips Epic 17PF9936-37 17" Flat Panel...
E-machine wont boot up. It has power,feels like
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Sep 28, 2009 | E-Machines eMachines Desktop PC
Power light goes out but power remains thru the m-board fan runs
you need to replace the power supply. The fan sound is the fan for the power supply and not the computer. for cheap parts or used goto headgap's. They know what you need and probably even help you replace it yourself.
Jul 03, 2009 | Computers & Internet
Emachines t2899 will come on and fans run but screen is still blank
Actually, the monitor is fine. The problem is that the computer isn't booting. The power comes on and the fans spin, but the system board isn't starting. Try reseating the memory modules in their sockets and clearing the CMOS memory using the jumper on the system board. If the problem continues, try another power supply. Finally you may need to replace the system board.
May 13, 2009 | E-Machines T2899 PC Desktop
Mother board no display
Looks like the lights are on? Fans spin? Sounds like the harddrives spinning? The power supply is bad. has just enough power to light lights, and spin fans, but not enough for the processor. (No beep sounds, because BIOS hasn't done a memory count. It's not going to)
ALL the lights use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
The harddrive just sitting there spinning, uses about 5 watts.
Processors use 55 Watts to 125 Watts. Depends on the processor.
Not enough power to turn the processor on, the computer won't work. Computer isn't working there isn't anything to turn the monitor on. No Signal.
Apr 17, 2009 | Intel Motherboard
Monitor will not turn on after booting computer
if you have onboard video try a video card that fits in PCI or AGP slot or try a different video card in place of the one you use
with everything else seeming to be correct this seems like the only thing you have not done
Aug 03, 2008 | Intel Motherboard
Power Supply
Check all power cables plugged into M/board if these are correct
remove all hard ware
hard drives / cd player and anything else
except for video and memory and test to see if it boots. If it does, one of the removed hardware is faulty if it does not then you have M/board failure
Aug 02, 2008 | E-Machines Emachine T5026 power supply **...
Elitegroup P4VMM2 ATX mainboard
You can't fix it. I'm afraid it's a dead board.
erch.
Mar 17, 2008 | EliteGroup P4VMM2 Motherboard
Going to Sleep
Due to the power surge, it is highly possible that the monitor was given a boot by your computer on it's way out.
This will short out a very small transistor inside the monitor on the video board and in turn, then monitor cannot see that there is a signal so goes to sleep.
If you get brave enough to venture inside the screen, then check near the cable input. The transistors are only around 3mm and have 3 legs (two one side and one in the middle on the other).
If you find anything like that burnt (get a magnifying glass) then replacing the board is the easiest option. Just don't be tempted to wipe the board before you look at everything very closely, you may wipe away the tiny bit of evidence you are looking for.
Hope it helps =)
Feb 12, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
EliteGroup P4VMM2 Motherboard Logo
97 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
