Question about Gateway FPD2275W LCD Monitor
Envision Monitor doesn't turn on.
I know very little about computers/fixing problems & am hoping there may be a solution to my problem and not the end of my monitor.
When I arrived home today the power had apparently gone out for sometime during the day. My computer was on but I cannot get the monitor to turn back on, no lights or response to the power button. I checked all the connections and restarted but there's still no response.
thanks
  • 558 Answers
Monitor has sustained damage from the power fluctuation's from the outage I would report it to your power company they are obligated to replace any damaged equipment that may be damaged because of their failure to provide non outage service and then go take the monitor to a repair center they can determine if the boards internally were hit with a power spike and damaged, meanwhile while you send the report to the power company you can either buy a new one and then submit the price for refund from the power company
Posted on May 11, 2008
Hello when I turn on my monitor and computer this morning I have a black screen on my envision monitor and the green light keeps blinking do you know how to fix this
Unplug everything from the tower. Including power cord.
Press the power button for 5 secs.
Proceed to connect, power line, mouse, keyboard and monitor
That should reset the power or hibernation mode that you might have issues.
If everything looks normal, proceed to connect your remaining devices.
You must be aware that having a BIOS settings to boot from USB, DVD or USB-FLOPPY might prevent to boot into windows.
Feb 24, 2015 | Envision Computers & Internet
My Envision LCD Monitor screens turns gray once its power on. I have tried changing contrast will not work.
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Mar 27, 2014 | Envision G22LWK 22" LCD Monitor
Never turns on, power light flashes fast
The flourescent lamps on the sides of the LCD panel is burnt out. If you open the monitor and look at them, I will bed they will be blackend on one end. This is common and you need to find some new ones to replace. They are usually about $15 and plug into the HV little board that drives them. Hope that helps!
Feb 13, 2014 | Envision H22W 22" Monitor
I have an Envision G22LWK 22" LCD monitor that keeps turning off every 30 secs. How can I stop it from doing that?
is it turning off or going into sleep mode? If turning off, you have issues with the power supply. look at it and see if any capacitors are bubbled up on the ends and replace if you see this.
Nov 08, 2013 | Envision G22LWK 22" LCD Monitor
Will my Envision 19" monitor,
You will need to set the display resolution and vertical sweep rate on the computer to something the monitor can handle. The monitor works best at 1440 x 900 at 59.8 Hz vertical rate. If your laptop's graphics chip doesn't have this setting (available settings are listed in the Display control panel), then look on page 19 of the monitor's owner's manual to find something that matches a resolution listed in the control panel.
Sep 21, 2011 | Envision Computers & Internet
My laptop LCD screen is FUBAR and in order to use my computer I have hooked it up to an Envision 19" LCD Monitor. If I start Windows Vista in Normal mode , it does not recognize the Monitor. Pressing...
I would go ahead and boot into safe mode where you say it does work and then take a look. See how it detected it...ie look in device manager and see if it picked it up by it's true brand/type etc. Check the settings both of the display and on the envision itself. Check the resolution selection. It's probably picking it up as a lower res. but when it boots into reg windows may be trying to run at full res and perhaps that's what it won't do. Check to see what driver it's using. It may need the specific driver from envision and not the generic driver. It could also be a bad pin on the envision itself.
If you have another computer you can hook it up to, do that to make sure the envision is working. That way you can deduce which is the problem, the monitor or the setup in your laptop.
Jul 10, 2011 | Envision 19" Widescreen Flat Panel LCD...
I have a 5 year old envision monitor which has just started going blank every time I turn it on. After about 10 times of shutting it off and turning it back on, it stays on. What is going on and can I fix...
The internal power supply is going out. If you can solder then you should be able to do the repair. Check out our site at: www.ccl-la.com/capacitors.htm for information about the parts you will need to replace to get you monitor back running right.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 09, 2010 | Envision EN-7100e 17" Flat Panel LCD...
Monitor issue
Just sounds like the monitor cable is loose or bad or the input mode on the monitor is set wrong - set it to auto or step through the modes.
Aug 10, 2009 | Envision H191W Monitor
My Envision 7100 Stop Working
These are all some component failure problem in the monitor circuits. This may have been caused by faulty components or overheating of the components causing intermittent or permanent failure of some components in the circuits.This causes the feedback circuits to sense incorrect voltages or currents in the circuits and turn on the protection circuit. It may also cause total failure of the power supply circuit and a loss of power to the monitor. These units should be returned to dealers for servicing. Hope this helps you .
Jan 09, 2009 | Envision EN-7100e 17" Flat Panel LCD...
Envision Series / AOC 22 hdtv monitor
Probably blown capacitors, the 19" widescreen uses 6 16V 1000uF
Do you have a soldering gun? Its not that hard to fix, get the capacitors on ebay for $6-$8 with shipping.
Oct 31, 2008 | Envision 19" Widescreen Flat Panel LCD...
Gateway FPD2275W LCD Monitor Logo
156 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
