Question about Dryers
Maytag Performa PYG2300AWW Problem: How to remove the lint filter holder for cleaning.
  • 1 more comment
  • Minoono1 May 02, 2008
    Sorry, the solution provided by Coolguy008 is absolutely no barring on this model,
    I have been asked to follow the drawing of some very old dryer Model ASKO T721.
    I definitely cannot accept this solution. It has no barring on this model.
  • Minoono1 May 04, 2008
    Dear Mr. Coolguy008,
    With all due respect, I know and am well aware of the consequences of not cleaning the filter. Cleaning filter is not my problem. I do the cleaning of the filter on every Load cycle.
    This dryer is about five years old and no matter how good a filter is, there are still some fine openings around the filter and the filter screen itself that will allow some of the finer lint to pass through and deposit further down the passage towards the exhaust and could as you rightly pointed out be a fire hazard.
    That?s the main reason why I want to reach inside to clean all that lint deposit. To do that, I have to remove this part in which the filter sits. I do not know the name of the part nor how to remove the part. That?s where I need your help if you can.
    If you do not have an appropriate solution please do not waist your time and mine unnecessarily in going over this problem again.
    Thanks any way.
    May 04, 2008
  • Minoono1 May 05, 2008
    Dear Mr. Coolguy008
    Sorry about the previous Reply of May 4, 2008. somehow I missed the passage that you had sent which is:
    Comment by coolguy008, posted on May 02, 2008
    Alright please let me know if this info. helped you or not.And if it helped you out please don't forget to rate or accept the solution.
    ”There are 2 little clips that hold the top to the front panel (they are located in the crack, near the outer corners). Release them, and raise the lid. Remove the 2 screws that secure the front panel to the machine, and remove the entire front. The lind screen tunnel should now be accessible.”
    Now that seems to be the right solution. Ill look into it
    Thank you.
    May 05, 2008
  • 3,422 Answers
You will get some idea from the manual..
Please dont forget to rate the solution
Posted on May 01, 2008
  • 4 more comments
  • Priya darshan May 02, 2008
    ok,please give me a min. i'll get you some more info.
    be accessible.
    Lint filter has a lip handle that protrudes and lifts when removing clothes - causing lint
    I have got some tips for you:
    Cleaning the lint filter after completion of a dryer load is part of
    the regular care and maintenance of your appliance. This will not only
    ensure continued optimum performance, but will reduce the risk of fire
    in your home.
    When your lint filter becomes plugged, it restricts the outflow of
    heated air, which can cause your dryer to become overheated. This can
    increase the risk of fire starting in your dryer.
    The remedy of course, is to ensure the lint filter is cleaned out
    regularly, and that there are no obstructions to the outflow of heated
    However, according to Fire Chief Ken Benoit of the Terrace Bay Fire
    Department, another fire concern related to dryer filters has recently
    surfaced. Even though the lint has been removed and the filter appears
    to be clean, certain fabric sheets used in the drying cycle, can cause
    a thin clear film to develop on the filter, forming a barrier which
    restricts the air from properly exhausting from your dryer.
    A quick test to see whether this film exists, is to take your
    filter to a sink and run water into it, while observing whether the
    flow can easily pass through the mesh, or just pools in the filter.
    If the flow is unable to pass through - a thorough filter cleaning is required.
    Use a very soft nylon brush and warm soapy water to clean your filter,
    and repeat the above test - the flow should no longer be restricted.
    Repeat this cleaning every six months.
    Just a simple test and a few minutes of cleaning can go a long way to keeping your family safe.
  • Priya darshan May 04, 2008
    Ok,You can just rate me as thanx for trying and switch to other experts advice.
  • Priya darshan May 05, 2008
    I am glad to hear the this info. helped you.
Ignition works but doesn't stay on long enough to heat dryer
its either the hi-limit switch is weak on the burner tube,or the gas valve coils on the gas valve are weak and can no longer keep the gas valve open to supply gas,if they appear warm after operation they are most likely bad
May 24, 2012 | Maytag Dryers
My Maytag Performa PYG2300AWW dryer quit working today. 1st we noticed it wasn't dying clothes, then there was a smell. We thought the lint was clogging it up, so we vacuumed everything out. Now it won't...
This could be the thermal fuse or Hi Limit thermostat possibly a few other components. There is a video at that will walk you thru the troubleshooting procedure. It's a different model but testing and components are the same.
Mar 27, 2010 | Maytag Performa PAV2200
Maytag performa Keeps blowing Thermal Fuse. Vents are clean. Cleaned entire system. Seems to heat up as soon as dryer cuts off.Changed control thermostat as well. Can get one load and replace fuse.
something is still plugged with lint,if the vent line is long blow it out with a leaf blower to clean it out,you have to clean out the duct that the lint filter slides into,if the filter is on top remove the vent line,remove the back panel,remove the lint filter and the two screws in front of it and remove the four screws and clean out the duct,if the filter is in front take off the bottom panel,remove the filter and clean the duct,also vac out the inside of dryer where the motor is,when the dryer gets to hot the thermal fuse pops as a safety so you still have a block somewhere
Mar 19, 2010 | Maytag PYE2300AY Electric Dryer
Maytag performa dryer model pye2300ayw, what should the ohms reading be on the thermal fuse?
doesn't matter,it's either good or bad,when you touch the meter to it if it reads 1 and doen't move it's bad if you get any reading it's good,if the dryer is loaded with lint in the duct that the lint filter slides into and the vent line is blocked it will keep popping on you, clean out the dryer,number one cause for popping the thermal fuse
Feb 22, 2010 | Maytag Dryers
Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
Jan 18, 2010 | Maytag Performa PAV2200
How to replace heating element Maytag Performa gas dryer pyg2300aww?
Your model number indicates a gas dryer. It does not have a heating element. It has a glowbar igniter,a flame sensor and a gas valve. Either the glowbar igniter is bad or the flame sensor or the gas valve coils or the thermal fuse.
Jun 22, 2009 | Maytag Dryers
It is taking 3 full cycles to dry my small loads on my Maytag Performa PYE2300AYW. I have cleaned lint tray and trap. I need to clean the lint from the inside of my dryer - How do I do this?
The main area that you have to clean is the pipe leading from the back of your dryer to outdoors. Pull your dryer away from the wall. Unplug it. Unfasten the vent pipe. Now look into the back of the dryer exhaust and remove any lint you see there then look into the vent pipe and remove any lint. Finally go outdoors and remove any lint you see in the pipe or the pipe grill/cover.
Jun 04, 2009 | Maytag PYE2300AY Electric Dryer
My maytag performa gas dryer model # pyg2300aww gets warm but takes four cycles to dry.
clean your dryer vent going from the back of the dryer to outside also run a lint brush down where you put the lint screen in if this does not help replace your coils
Dec 29, 2008 | Dryers
Maytag performa model#pyg2300aww takes four cycles to dry
how long is dryer vent run ? does it go up or out to the side ? Sounds like the dryer vent is clogged. A long run on your vent will also cause this problem with a small amount of lint. Try cleaning out your lint screen on the dryer vent they can get pretty caked up with lint. If you have a long dryer vent run post back the length and direction and I will get you the maximum length for your specific run. You may need a booster fan if it is excessively long or straight up as through the roof.
Dec 29, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
5,894 people viewed this question
Top Dryers Experts
