Question about Brother HL-2040 Laser Printer
I have a brother HL-2070 laser printer and have just inserted a new toner cartridge. When I turn on the lase printer it is coming up orange light toner & will not print. Its as if its not recognising the cartridge. Even when I replace the old cartridge its still coming up the same. Hope you can help Fred Sheriff
  • 552 Answers
Have you tried shutting down and restarting after the cartridge was in?
Also at Brother there is a new driver download for your model, and other info.
http://www.brother-usa.com/SiteSearch.aspx?sk=hl-2070%20manual
Posted on May 01, 2008
What do you do if the toner light comes on after you have installed a new toner cartridge
Did you remove the toner protect strip to allow the new cartridge to expose the toner?
Remove the Toner cartridge and reseat it. After reseating it, wait for the printer to recognize the cartridge, then turn the printer off, then back on.
Oct 12, 2010 | Brother HL 2140 Laser Printer
Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Mar 11, 2010 | Brother HL-2070N Laser Printer
Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Mar 08, 2010 | Brother HL 5250DN Laser Printer
Drum and error light are on - got new cartridge - installed as directed - blue light will not stay on - printer will not print - red and orange lights will not go out
I can't recall the buttons on Brother laser printers but leaving the cartridge door open and pressing and holding down one of the buttons for about 5 seconds will clear the drum light error.
I've done this to clear the same error on aBrother HL5250DN laser printer.
If this doesn't work please post your printer's model number.
Sep 21, 2009 | Brother HL 5250DN Laser Printer
HOW DO I REMOVE SPEND TONER IN HL 2070 N and insert new toner
open front cover, pull out drum/toner unit, press lever to release toner, put in new one,and replace.......ta-daaa
Mar 04, 2009 | Brother HL-2040 Laser Printer
Brother Hl 5240 printer- toner light on
1) Turn off printer
2)Turn back on
3) Remove Drum and Toner.
4)Press Go for 1 second(it appears to do nothing)
5)Put Drum and Toner back in.
6)Press Go for 1 second(it appears to do nothing)
7)Close door.
Try that
May 30, 2008 | Brother HL-5240 Laser Printer
HL 2070n
Copier tech here. :P I just had to look this up. looked to the internet first, before going to find a manual.
open front door (the door for toner and drum units)
hold Go untill all four lights are on.
Release Go
Shut door
good to go.
Have a good night ya all.
Mar 28, 2008 | Brother HL-2070N Laser Printer
Brother HL-1440
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Brother HL-2040 Laser Printer Logo
220 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
