  • Anonymous Jan 28, 2009
    i have a hydro heating system that has made in usa by continental it heats by using a low voltage pump to pump water from my 40 gallon hot water heater through the indoor coil it heats fine but i cant get any hot water from tub or faucet unless the heater is on and i have a water heater that is only 6 months old what should i do and where can i get a parts list for this system which data plate says is made by continental please send me info
  • 828 Answers
Some Hydronic heating systems have a loop for hot water. If you only have hot water when the heat is working then your normal hot water heater is out of the circuit. Breaker off, or problem with the normal water heater. These can be ether electric or gas.
Posted on May 01, 2008
Boiler won't ignite for hot water unless heating is on.
If this is in a RV the propane monitoring valve may require more gas flow to turn on than the water heater requires. A central heating system requires substantial gas flow so when the monitoring valve opens to fire the central heating, there is enough gas flow to also fire the water heater.
Jan 26, 2016 | Water Water Heaters
Water doesnt get hot unless you run the sink first then the wster on shower get boiling hot then ice cold showers a few weeks old
So you have 2 heating elements in your hot water heater. A top and a bottom. From the sounds of it your top element has went bad however they are only about $17 a piece new and it is recommended you replace both at the same time. Thats why it takes you long run to get hot water the top water heater water is still cold and long run gets to the bottom and gives you hot water.
Apr 03, 2015 | Home
Why does it take two bowls of water before water gets hot on combi boiler
The water isn't maintained hot (unless the central heating is on) in a combi boiler. you will, therefore have to turn the water on, which activates the burner. The burner will then have to heat up the heat-exchanger which then supplies the hot water through cold pipes. Once the pipes are warm, you will receive hot water.
Jan 29, 2015 | Water Water Heaters
Not heating water
If all of the cycles are working with cold water, then the controller circuit is OK. If the hot water cycle fails, it can be the heating coil. Depending on age, some retire sooner than others and need to be replaced. Only a service tech. can do a test unless your experienced at continuity checks.
Mar 18, 2014 | Baumatic Dishwashers
Water Heater Issues
An electric water heater contains two elements (usually upper and lower). Normally hot water is maintained at a certain temperature to assure an immediate supply. When hot water is turned on at the fixture, the second element is turned on to boost the temperature. From your description one of the heating elements may be defective or set to incorrect temperature.
Apr 28, 2017 | Water Heaters
My Rheemglass Fury is not putting out much hot water
I believe that there are 2 separate electric heating coils in this unit (unless you are talking about the GAS unit). One of the coils either has a wire broken or the element needs to be replaced!
Dec 31, 2012 | Rheem Water Heaters
User guide needed for old Honeywell programmable heating control
It depends on your system some will only work with hot water on and heating do you have two zone valves?
Jul 18, 2017 | Honeywell TH4210D1005 Heater
Diswasher not heating water
check your connections under the sink. A dishwasher (unless it is a commercial one) is not built to heat water the water is supplied via the water heater via the sink angle stop. The dishwasher does however have a heating element inside used to dry the dishes. I would check the hot water side of the sink where the dishwasher is connected to see if the problem could be in that area. Check your setting on the machine. Good Luck on your repairs
Sep 15, 2009 | Dishwashers
Heating & Cooling Logo
155 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
