Question about Tefal Avante Deluxe 4 Slice Toaster
T-Fal Avante Bagel Tpaster - 4 slice
One side (2 slices) of my toaster will not lock when I press the lever down. The elements do not heat up. I recently moved the toaster and turned it on its side, so I am thinking that something came loose inside. I'm very partial to this toaster & would like to use both sides.
  • Anonymous Jan 23, 2009
    I also have the avante 4 lice toaster and left side won't lock down...will heat if it is held down..or sticking a wooden spoon in slot to hold down...but really isn't safe....this happened like 3 months after we had the toaster....don't make toast that often so it wans't over use...not really happy about it
Energized coil (Magnet) which holds down lever mechanism may be coated and in need of scraping for it to make full contact
Posted on Aug 31, 2009
The element is broken . Try to put the element back together. Mine was broken near the rivet under the slice who holding the element in place. Very hard to find. You need to pull on the element to see if it s loose or fix properly.
Posted on Dec 25, 2008
    Problem Solver:
  • 3 Answers
Just to add a note of caution. Be very careful pulling on the heating element, as they become very brittle and can not be flexed when they do.
Posted on Jul 13, 2010
Hi my girlfriend just gave me this toaster, and would like to know what the lighted buttons are for thanks
Since you don't mention the make or model number of the toaster or its age I can only make the following guesses.
It might be an electronic model. To test if this is the case, leave the toaster unplugged and push the lever of the toaster down. If it does not stay down it is an electronic toaster. If it stays down then it is NOT electronic.
The lights might be lighted push buttons.
If you plug the toaster in then put a slice of bread or two in and push the lever handle down and one light comes on then this is probably a dual purpose pushbutton. It indicates that the heating elements are on and if you push it will cancel the toasting cycle and the bread slices should pop up.
If there is a button beside the above button it could be for extending the toaster cycle time a bit longer to compensate for a thicker slice or a denser bread like a bagel. If you push it, it will light up to let you know that the cycle has been extended for this reason.
If there is a button beside this one, it could be for extending the toasting cycle to compensate for a frozen slice of bread or whatever, like a bagel or even a frozen waffle.
If you find the make and model for your toaster, it might be on the bottom somewhere, google it to see if you can download an instruction manual for it.
Hope this helps. Good Luck.
Jun 03, 2017 | The Kitchen Appliances - Others
Toastmaster B1042 toasts only one side of one slice and both sides of other slice
The is by design. The bagel side only heats on one side because of the bagel not needing to be toasted .
Jan 16, 2013 | Toastmaster Kitchen Appliances - Others
Received 2 slice toaster (kitchenaid) as a gift - from the very 1st time it was used, only the outer coils would heat up, so only 1/2 of each slice ever gets toasted!!! Anyone who could help solve this...
I think it is set to cook bagels. Check the control settings.
Most toasters have a bagel setting which only cooks the
sliced side of the bagel. This model is designed to accept bagels. Hope this helps.
Jul 22, 2011 | KitchenAid KMTT200OB 2-Slice Toaster
Tefal avanti hi speed 4 slice toaster one side not working, Not staying down Left side right side ok
When the push down lever hits the bottom it pushes another little lever which makes contact with the positive and negative terminals. over time, these terminals get ever so slightly bent, especially if you start pushing the lever down hard. what you have to do is take the toaster apart, get to the positive and negative terminals and pinch back into shape with some pliers. you should understand once you look at it. Then put back together. if it doesn't work then it's likely a component has gone so, unless you have a multi-meter and a soldering iron I wouldn't suggest doing this.
Oh yeah, unplug it before you do anything.
Jun 03, 2010 | Tefal Avante Deluxe 4 Slice Toaster
Dualit 4-slot toaster - is this how it's supposed to work?
your toaster is working correctly if both are off you are in BAGEL/BUN mode ( did i spell that wrong ? ) in that mode it will only toast the cut side .... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Dualit Vario Combi 2x2 65-Slice Toaster
T-Fal Bagel toaster makes buzzing sound
I'm not sure if this applies to your problem, but I found a great solution to the buzzing I've experienced on my GE toaster at the following link: http://applianceguru.com/forum1/18670.html
Jan 04, 2009 | Tefal Avante Deluxe 4 Slice Toaster
Tfal 2-slice toaster repair
look inside your toaster. there must be something inside it turn it down and see if something comes out.. if nothing is inside then try to see if the cord that you switched on is not broken. if you see a liitle bit scratch mark on it- switch off. You can get a electric shock. it is your favorite toaster so try to consult a electricion to fix the cord for you.
Feb 26, 2008 | Tefal Avante Deluxe 4 Slice Toaster
Bagel setting stuck on.
Mechanism slight is the problem and spring give way.
Rdgs
alan
Dec 15, 2007 | Tefal Avante Deluxe 4 Slice Toaster
Tefal Avante Deluxe 4 Slice Toaster Logo
914 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
