posted by swampy25 on May 01, 2008
door lock light flashes, I had a power cut earlier which interupted the cycle, any ideas?
Solution #1
posted on May 01, 2008
Power interuptions are never good. If all your controls work and the door wont lock you are going to want to replace the door switch or latch whatever your manufacture calls it. Unplug it wait fifteen minutes (make sure door is shut) plug it back in (also reset breaker is cant unplug) if this dont fix it, either a control board short, easiest and cheaper repair is door switch/latch
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
GE Profile WPXH214F
GE WDSR2080D Top Load Washer
Bosch Exxcel WFO 2264 Front Load Washer
Kenmore 22422 Top Load Washer
Kenmore Oasis HE 27082 Stainless Steel Top Load Washer
Kenmore 93702 Top Load Stacked Washer / Dryer
Kenmore 43052 Front Load Washer
Can you Help with these Washing Machines problems?
Frigidaire GLWS1749A Top Load Washer
washing maching will not change
My washing maching will not... Answer This...
GE Profile Harmony¿ 4.0 Cu. Ft. Capacity...
A problem
A problem
I can't really explain what is... Answer This...
Frigidaire FEX831CS Top Load Stacked Washer /...
door won't open at end of all...
AFter the wash is done on the... Answer This...
Bosch Classixx WFC 2465 Front Load Washer
Bosch Classixx
Bosch Classixx
I have a four year old machine.... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
