Question about AT&T High Speed DSL Modem
Wireless router I need a wireless router strong enough to feed a laptop 100' away in my home. standard cable wireless modem won't do it.
  • princebe Jun 05, 2008
    i have the 2wire but when i am on the other end of the house my signal is still low. should i buy a signal booster and if so which one?
    Problem Solver:
  • 29 Answers
Yuu could run a ethernet cable through the house to a point close enough to that side of the house and drop in an AP (Access point) and let the AP handle the connection. least then you would have a stronger wireless connection in the general area. if the signal got too weak away from the 2wire all you would have to do is switch to the AP in the general area and then go from there. The AP would use the ethernet cable connection to the 2wire.
Posted on Jun 16, 2008
  • 36 Answers
I think 2wire routers are good in providing signal strength. Contact the 2wire vendor regarding your requirements.
take care
Posted on May 09, 2008
Inconsistant wireless signal in house
Have you checked that the signal on your new cable modem/router is strong enough to reach your wireless devices? You may need to re-site the cable modem to get better coverage in your home. Your old one probably worked fine in the same position but that doesn't mean a new one will. There are a few things you can try to get the best of the range it has. Internal walls and furnishings all play a part in reducing the effective range of the router. Most routers will give you at least 50 metres indoors. Keep the router as high and as far away from walls as you can, this will greatly improve the range. Try to ensure the router is not screened by large near by metal objects such as steel PC cases, these will absorb wireless signals and reduce the range.
Jan 18, 2014 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Poor signal with WiFi on my zeepad
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
Strong signal but can not connect
If you have a wireless router and it is connected to the DSLor cable modem then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Feb 21, 2012 | Computers & Internet
I cant hook up my d link 150 up to my toshiba sattelite laptop. i have dsl modem and i dont wanna mess it up.
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
Apr 09, 2011 | D-Link Wireless N 150 Home Router 4Port...
If my pc has a strong internet signal - why can't I go online?
its a wireless signal may have to move it around to get your signal things such as walls ,appliances distance can cause signal loss
May 18, 2017 | Linksys Bundle: BEFW11S4 802.11b Wireless...
Have two computers but only one will get internet access
The tech is right, you can only have 1 modem on your residential line. The 2-wire router/modem should
have 4 ports in back to share with other computers AND a wireless signal too. You can run an
ethernet cable to your bedroom or get an adapter (either USB or PCI card) to connect to your router and
share the modem. If you go wireless, the 2-wire router is by default an encrypted signal. The password
is on the sticker, usually all numbers. Look at manual for changing configuration.
Jul 09, 2009 | Gateway Wireless-B Router (wbr-100)
Need to get wireless on my laptop,
No, the SB5100 is just a cable modem, not a wireless router. You will need to keep your sb5100 but you will need to purchase a wireless router if you want wireless on your laptop. If you can also plug your laptop into the sb5100 via an ethernet cable for your internet connection. Linksys and Belkin and others make wireless routers that you can use for your wireless connections.
May 01, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Want to hook laptop up to home computer via cable modem
You need a router or a wireless router to do that.
If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
Nov 19, 2008 | Computers & Internet
Di-604 & di-524
Ethernet will travel over 2 pairs from the basement to your space that has to be less than 100 feet away. You can run it over flat cable, but not get 100 base T, but it is still going to be as fast and quicker than a wireless bridge and regeneration.
If I understand what you're trying to do, it will acutally take 3 routers or 2 and a wireless access point. The key would be to set up one router as a wireless and the other as a bridge. That gets your ethernet signal to the back of the router. Now, you need a wirelss access point or 3rd router to make it be wireless in your space.
Most modern premisies are wired with 4-pair cable. Even if they didn't make home runs from your space to the basement, there ought to be at least 2 spare pairs in the house cable. Those 2 pairs can feed ethernet to your space where you just have to plug in a router and configure it as an access point, or let it be a wireless router for that matter with or without being a DHCP server. In my wildest dreams, I can't even think of a 5 story structore being more than 150 cable feet away, well withing the 300 feet allowed for ethernet.
Let us know what you finally do.
Carl
Oct 18, 2008 | D-Link AirPlus DI-524 Wireless Router
Belkin Wireless G wont connect to cable modem
If you switched ISP then you have tor reconfigure your router according to the settings of your new ISP.
Aug 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
AT&T High Speed DSL Modem Logo
314 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
