How do I enable security on my Sinksys Wireless-G Broadband Router Model WR7546? It works fine but without security someone keeps knocking my printer offline. Clem Arnold
  • Dude9998 May 01, 2008
    My problem is, I don't recall getting an enstructional booklet with my Linksys Router.
    Genius:
  • 3,422 Answers
Is your router linksys WRT54G?i'll give you the manual and everything will be explained step by step with the diagrams.
Waiting for your reply.
Posted on May 01, 2008
  • Priya darshan May 01, 2008
    ok,just CLICK HERE and you will get the instruction booklet.
    Please don't forget to rate or accept the solution as fixya.
    Genius:
  • 1,447 Answers
When you go to your Sinksys configuration utility, it will either give you option to select security mode in which you can put a pass key by WEP or other option.
  • 2 more comments
  • Edgar Allan Pagayona
    Edgar Allan Pagayona May 01, 2008
    Appendix B: Wireless Security
    Linksys wants to make wireless networking as safe and easy for you as possible. The current generation of
    Linksys products provide several network security features, but they require specific action on your part for
    implementation. So, keep the following in mind whenever you are setting up or using your wireless network.
    Security Precautions
    The following is a complete list of security precautions to take (as shown in this User Guide) (at least steps 1
    through 5 should be followed):
    1. Change the default SSID.
    2. Disable SSID Broadcast.
    3. Change the default password for the Administrator account.
    4. Enable MAC Address Filtering.
    5. Change the SSID periodically.
    6. Use the highest encryption algorithm possible. Use WPA if it is available. Please note that this may reduce
    your network performance.
    7. Change the WEP encryption keys periodically.
    To ensure network security, steps one through five should be followed, at least.
    Security Threats Facing Wireless Networks
    Wireless networks are easy to find. Hackers know that in order to join a wireless network, wireless networking
    products first listen for “beacon messages”. These messages can be easily decrypted and contain much of the
    network’s information, such as the network’s SSID (Service Set Identifier). Here are the steps you can take:
    Change the administrator’s password regularly. With every wireless networking device you use, keep in
    mind that network settings (SSID, WEP keys, etc.) are stored in its firmware. Your network administrator is the
    only person who can change network settings. If a hacker gets a hold of the administrator’s password, he, too,
    can change those settings. So, make it harder for a hacker to get that information. Change the administrator’s
    SSID. There are several things to keep in mind about the SSID:
    1. Disable Broadcast
    2. Make it unique
    3. Change it often
    Most wireless networking devices will give you the option of broadcasting the SSID. While this option may be
    more convenient, it allows anyone to log into your wireless network. This includes hackers. So, don’t broadcast
    the SSID.
    Wireless networking products come with a default SSID set by the factory. (The Linksys default SSID is “linksys”.)
    Hackers know these defaults and can check these against your network. Change your SSID to something unique
    and not something related to your company or the networking products you use.
    Change your SSID regularly so that any hackers who have gained access to your wireless network will have to
    start from the beginning in trying to break in.
    MAC Addresses. Enable MAC Address filtering. MAC Address filtering will allow you to provide access to only
    those wireless nodes with certain MAC Addresses. This makes it harder for a hacker to access your network with
    a random MAC Address.
    WEP Encryption. Wired Equivalent Privacy (WEP) is often looked upon as a cure-all for wireless security
    concerns. This is overstating WEP’s ability. Again, this can only provide enough security to make a hacker’s job
    more difficult.
    There are several ways that WEP can be maximized:
    1. Use the highest level of encryption possible
    2. Use “Shared Key” authentication
    3. Change your WEP key regularly
    WPA. Wi-Fi Protected Access (WPA) is the newest and best available standard in Wi-Fi security. Four modes are
    available: WPA-Personal, WPA2-Personal, WPA-Enterprise, and RADIUS. WPA-Personal gives you a choice of two
    encryption methods: TKIP (Temporal Key Integrity Protocol), which utilizes a stronger encryption method and
    incorporates Message Integrity Code (MIC) to provide protection against hackers, and AES (Advanced Encryption
    Standard), which utilizes a symmetric 128-Bit block data encryption. WPA2-Personal only uses AES encryption,
    which is stronger than TKIP. WPA-Enterprise offers two encryption methods, TKIP and AES, with dynamic
    encryption keys. RADIUS (Remote Authentication Dial-In User Service) utilizes a RADIUS server for authentication.
    WPA-Personal. If you do not have a RADIUS server, select the type of algorithm you want to use, TKIP or AES,
    and enter a password in the Passphrase field of 8-63 characters.
    WPA2-Personal. Enter a password in the Passphrase field of 8-63 characters.
    WPA-Enterprise. WPA used in coordination with a RADIUS server. (This should only be used when a RADIUS
    server is connected to the Router or other device.) WPA-Enterprise offers two encryption methods, TKIP and
    AES, with dynamic encryption keys. Enter the RADIUS server’s IP Address and port number, along with a key
    shared between the device and the server. Last, enter a Group Key Renewal period, which instructs the device
    how often it should change the encryption keys.
    RADIUS. WEP used in coordination with a RADIUS server. (This should only be used when a RADIUS server is
    connected to the Router or other device.) First, enter the RADIUS server’s IP Address and port number, along
    with a key shared between the device and the server. Then, select a WEP key and a level of WEP encryption,
    and either generate a WEP key through the Passphrase or enter the WEP key manually.
    Implementing encryption may have a negative impact on your network’s performance, but if you are transmitting
    sensitive data over your network, encryption should be used.
    These security recommendations should help keep your mind at ease while you are enjoying the most flexible
    and convenient technology Linksys has to offer.
    For more detailed information on your account and the website, click your computer’s
    Start button, select the Linksys Wireless Guard folder, and then click Linksys
    Wireless Guard Help.
    Master:
  • 555 Answers
A manual and guides for your Linksys WRT54G router can be found here.
    President:
  • 1,944 Answers
You need to enter the configuration of the router and change the security.
I need a simple set-up manual for model # WRT54GS router
Your Internet service provider is comcast cable company.
You need to open the setup page of the router and change the Internet connection settings manually.
Connect the computer to the router and modem to the router.
Open the setup page of the router using 192.168.1.1
Click on MAC address clone. Enable it and click save settings.
Power cycle the router and your main computer will be online.
Then you can change the wireless settings manually.
Click Linksys router setup steps
Jan 04, 2012 | Linksys Wireless-G Broadband Router
How do I go back and set up a security password so the neighbors can't use my wireless service? Router has been set up for years.
Go to your IP Adress (printed below your router, usually 192.168.0.1) enter the user credentials (commonly admin/password) and go to router security. If this is to complicated or you don't remember credentials, reset the router or tell the neighbors that you will sue them
Aug 08, 2011 | Linksys WirelessG Broadband Router with...
Cisco wireless g router. Works fine. I want to
Well there are some steps in order to secrure your Cisco wireless G router:
1.Make sure you provide username and powerfull passworke like not less then 7 letters, it should inculde numbers, character,s and symobls.
2. Use Advanced Security: Wireless data encryption (WEP), so the hacker will not able to hack the wireless key.
3. enable Firewall
4. you can you internet access filter featuer , so u can block access to websites or any ftp sites.
5. remmber to backup your router
Jun 09, 2010 | Linksys -Cisco Wireless-G VPN Broadband...
I have someone using my wifi and would like to know how put a password?
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Apr 29, 2010 | Linksys Wireless-G Broadband Router
HP laptop not recognizing Linksys Wireless B Security Key..
The WEP encryption is consist of 10 characters for 64 bit hex, 128 bit hex is 24 characters and WPA is 8 to 63 characters. So it seems that you have a vista computer? The compatible encryption for vista is WPA, sometime using WEP it is not working properly. So I might advise you to access the configuration of your router (192.168.1.1) and change the wireless settings of your router to WPA-Personal.
Mar 09, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Need help dynex security sync wireless
according to the manual that i have, the model if the router that you have, DX-E401, is just a broadband router and doesn't have wireless capability. if that would be the correct model of your device, there's no way that you can enable the wireless encryption since it doesn't have wireless capability. but if you are really using a wireless dynex router, follow the steps below on how to access the router's page and enable the security.
access the router's setup page by typing http://192.168.0.1 on the address bar of your web browser (i.e. internet explorer, firefox etc). by default the username is admin, then leave the password blank.
you will be prompted with the router's page, now go to the wireless settings and look for the encryption field and enbale wpa from there.
if you are not sure whether your router has wireless capability or if you are using another wireless router just give me the exact model and brand then ask me
ciao!
Oct 03, 2008 | Dynex DX-E401 Router
Securing my network
1) Make sure "broadcast ssid" is disabled.
2) Ensure WPA is enabled.
3) Write down the hexadecimal codes it gives you, and enter them in every wireless device you wish to authorize.
Sep 16, 2008 | Linksys Wireless-G WRT54GS Router...
No wireless
first make sure wireless enabled and find out what channel the item your trying to connect to is the same as the router and set both accordingly. I had same problems with security cameras i turned security settings off for wireless and switched everything to channel 6 on router and cam and wet with 806 and works fine had to restart router not reset.
Aug 07, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Wireless-G2.4
Hi Norma - you have to enable wireless security by enabling either WPA,WEP, etc. After doing the key for that in your router you will have to enter that key in your wireless pc also. This will secure your network and let the moovhers fend for them selves. If you can give me the model# of your router and the make and model# of your pc I would be happy to tell you exactly how to do it. Thanks.
Jeff
May 24, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
