Have a mackie speaker & a laptop-how can i use microphone with this setup
  • 979 Answers
Do you also have a preamp?
Posted on May 01, 2008
Mackie srm450 v2 no top end.
Check the aspect of the crossover filter for the speakers, inside. Sometimes they fry.
Apr 14, 2014 | Mackie SRM-450 System
Jackpot00 my yahoo messenger voice doest not work
Run the Call Setup Assistant. This tool is built right into Yahoo! Messenger.
To run the Call Setup Assistant:
Click the Messenger menu.Select Preferences.In the Preferences dialog box, click Calling & Devices.In the Calling & Devices dialog box, under the "Test Audio" heading, click Open the call setup assistant.Click Next to go to the "Microphone Setup" page.Choose the microphone you want to use from the pull-down menu, then speak into that microphone.Click Next to go to the "Speakers Setup" page.Choose the speakers you want to use from the drop-down menu, then adjust the volume with the slider on the page.Click Finish.In the Preferences dialog box, click Apply and then click OK.
NOTE: Colored lights on the page indicate your microphone or speakers are working.
Nov 03, 2011 | Dell Inspiron 530 Desktop Computer...
Mackie SRM 450, the main speaker has stopped working but the tweeter is OK, there is nothing coming from the speaker at all, no hiss, or clicks.
It could be 2 things:
*Blown Speaker or,
*Fried power amp output stage of woofer, since this speaker operates as a bi-amplified system it has separate amps for woofer/tweeter...
Aug 17, 2011 | Mackie SRM-450 System
I have a mackie cfx12 mixer with mackie powered speakers.At a gig tonight i set up as usual and had strange highly amplified sounds coming thru speakers from microphone when reverb was on-the effects had...
Make sure you are using BALANCED interconnection cables to the speakers, either XLR or TRS connections. ALSO make sure all interconnected equipment such as the speakers AND the mixer are powered from the SAME receptacle at the venue... yes you have to run extension cords... the pro's do it so they don't have hum and other noise and don't damage their equipment.
Aug 14, 2011 | Innovative Concepts Corporation Odyssey...
I. Have a profx12. I am running just into laptop.i want to use my jvc receiver to playback recording instead of listening through headphones. Is this possible.
it should be if you hook something up to an input channel like w the band i was in i had to hook my turntables up to a microphone jack on an open channel . so yeah if u plug lets say a cd player plug the output of that into the input of the mackie and make sure you have your speakers in the output of mackie all set up and it should work no problem. We have the same mackie
May 28, 2011 | Mackie ProFX12 Professional Compact Mixer
Can i have a breakdown as to what would be hooked up where for the recording with this mackie mixer?
thaqts a little vague, what equitment do you have to hook up to it, specifically. i need makes and model numbers for everything you plan to hook up, microphones, amplifiers, speakers, effects processors, compressors, corssovers or varieties of electronic and acoustic instruments.
wiothout specifics, all i can say is "plug mics into whatevver mic imputs, and keyboards into whatever input, and your amps/speakers to the main outputs"
you are asking for quite a lot, try to be more specific about your external equiptment, and try to narrow your question down a bit, and i will be happy to help you out.
Nov 26, 2010 | Mackie 1202vlz3 12 Channel Mixer
The Amp on Mackie SWA 1501 sparked and burned today
I don't think the amps are available from Mackie any more. You can have it fixed: www.alivesoundcenter.com
Nov 26, 2009 | Mackie SWA1501 Subwoofer
I need a replacement amplifier for my mackie SRM450v2 speaker. do you know where I could get this?
Probably from Mackie customer service. My brother-in-law's cousin has the powered speaker system and I think they repair or advance replaced his for about $200.
Now, for about $600 you might look into a different system :-)
http://www.thefind.com/instruments/browse-kustom-pa-system
Carl
Nov 11, 2009 | Shure Beta 87A Professional Microphone
No sound
on what unit are you connecting the mics. mixer or directly to amp or powered mixer?
Jun 22, 2007 | Shure Beta 87A Professional Microphone
 Grubhead
Grubhead
