Question about Canon PowerShot A540 Digital Camera
Open a Canon A570IS
I'm looking desperately for help opening a A570IS. I got to replace the front face.
Can you help, please?
I've done the entire "screw job" but the front and the back are still together on the top. There is still something under the "shiny" silver like plastic on top.
Any comment is welcomed.
Best regards,
Blackscorpy
It will come off with a little care and force. it kinda just snaps in there. hold the camera with the lcd facing you and pull up on the back side and eventually it will pop right off. ive opened my PS many times before and it hasnt broke taking that off :)
Posted on Jun 18, 2008
Facing 2F1F IN IPF750 MACHINE REPLACED MAIN PCB,PURGE
HELLO ,
IF YOU'VE REPLACED THE PURGE UNITAND STILL CAUSING THE TROUBLE, CHECK THE WIREING!
HOPE THAT HELPS!
Sep 10, 2011 | Canon imagePROGRAF iPF8000 Printer
When I take a picture it displays white in the daytime and in the nights it takes pictures but has a few horizontal lines
Sounds like the aperture is stuck open and not able to adjust for different light conditions.
It can be difficult to see, but look down into the lens from the front and turn on the camera. Do you see a small circle open and close in the very center of the lens? Try pressing the shutter button half way (not all the way or the flash will go off in your face) while looking into the lens. See any movement? Try this in light and dark conditions.
The lens assembly will most likely need to be replaced. I took the liberty of looking up the repair price on the usa.canon.com website for you and it looks like they may repair it for a $58 flat rate!! Call 1-800-OK-CANON and ask for repairs.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 25, 2011 | Canon PowerShot A470 Digital Camera
I have a paper jam on my very old canon fax machine...Canon Super G3. The paper is held up in the rollers and has torn...how can I release the rollers so that I can get the torn piece of paper...
To remove the paper jam, follow the procedure---
1. Open the front cover.
2. Remove the cartridge.
3. Open the face up cover and push down the green paper release levers on both sides of the face up paper output.
4. Hold sides of the jammed paper and carefully move it inward then gently pull out.
5. Remove if any paper bits present near the rollers.
6. Don?t pull the paper upwards but straight between the rollers.
Please check page#62 for details in the manual---
Canon Super G3 Fax
Apr 01, 2011 | Canon Office Equipment & Supplies
I have canon 6085 very bad print and code error e012
Hello sir; Looks like the drum motor have problem, open back cover find out drum motor and look around have any gear broke if everything fine then replace motor that is necessary.
Jun 13, 2009 | Canon NP 6085 Copier
Canon A570IS lens frozen half way-no power
I have a a570 IS that the lense locked out on. fixing it was going to be the same price as buying new, so I took mine apart and after two tries, i fixed it. I would be willing to take a look at it for a heck of a lot cheaper than Canon can if your willing.
May 22, 2009 | Canon PowerShot A570 IS Digital Camera
Sharp ARC-172M how the drums get out?
open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum out towards you....done.
Apr 21, 2009 | Sharp AR-BC260 Color Copier
What is Front Cover?
This is the cover which is facing you, pull it without opening any screw, you will see where to pull or read the instruction manual. Even when replacing toner you have to open this cover.
Mar 23, 2009 | Canon ImageRunner 1600 Copier
CANON iR C2105!! no display on the LCD!
try adjusting the contrast, open front door and look under the panel there should be an adjustment screw for the contrast, if it doesnt work I suspect it is the panel itself that is bad.
Sep 12, 2008 | Office Equipment & Supplies
Open a Canon 570 IS
Just keep pulling on the back plate with the lcd towards you. The shiny thing will eventually pop off. It doesn't feel right while you're doing it. It feels as if you will break it. But I just kept taking the back off and it just popped off the shiny thing.
May 01, 2008 | Canon PowerShot A570 IS Digital Camera
Canon PowerShot A540 Digital Camera Logo
62 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
