Question about Whirlpool GSC9455 Top Load Washer
Will not drain after the wash cycle, will not enter the rinse cycle
My washer stops after the wash cycle will not drain, if I advance the cycle knob manually the machine does not respond. Please help
  • 9 more comments
  • SharonEF May 21, 2008
    Thanks so very much 4 answering my question. The washer does not make any noise, so hopefully it is just the program switch and not the pump. Although it sounds as if the pump is the easier job!! God Bless! SharonEF
  • Anonymous Jun 02, 2008
    could very well be the lid switch
    check the lid switch
  • Anonymous Jul 06, 2008
    My washer will fill up with water, but will stop after that. Also the belt keeps slipping, and you have to manually, keep putting it back on to complete a load. Please help!!??
  • Thawed Jul 15, 2008
    I have a similar problem, but:
    will not spin/agitate
    will not drain
    leaks water ... took it apart and it is leaking around the pump shaft
  • deuceofheart Jul 26, 2008
    Ihave a whirlpool washer that will go through the wash cycle and will not drain or rince even if i advance the knog manually please help
  • loldup Aug 07, 2008
    My Westinghouse washer stops after the wash cycle, will not drain. Timer control keeps running and than it goes into a spin cycle with water in the washer. As the water swirls around it eventually gets pumped out and the spin is normal. Same happens after the rinse cycle. Any help would be appreciated.
  • aking786 Aug 07, 2008
    the wash cycle works fine, the water fills the tub and it washes the clothes but it is not draining the water nor spinning. could the hose be blocked and if so how do you clear the hose
  • bullrock Nov 11, 2008
    Hi, I have the same type Whirlpool UCII 8 cycle 2 Speed Motor Washer. It fills normally, starts washing, then when you'd think it would start to drain, it shuts off. I hear a gurgle for just a second, likes it's starting to drain but it's only for a second, then nothing. If I advance the dial to rinse etc... nothing happens. The lid switch is working properly.
    Any help would really be appeciated!
    thanks Ronnie
  • Anonymous Dec 20, 2008
    whirlpool lsr7133kq0 will not drain or spin
  • Anonymous Mar 21, 2014
    while the machine is washing the settings change and the machine respond to the setting not complete its cycle
  • Whirlpool Master
  • 5,568 Answers
In my opinion, you will need someone on site to find whether the program switch has failed or it is only the pump itself.
The former is quite expensive but the pump shouldn't cost more than $20-30 plus labor.
When you write 'does not respond,' do you mean it makes no noise at all or just doesn't pump?
If it makes no noise, it is likely the program switch.
If you can determine that it is the pump, this is often a fairly accessible and simple job not requiring a lot of tools.
Keep a mop handy though . . .
Posted on May 01, 2008
    President:
  • 1,294 Answers
Plug off the wall. First take out as much water as possible by lowering the exit hose to ground level, then remove wet clothes. Next dismantle your filter (be prepared for waste water to collect completely & not falling into the machine electricals) to remove any blockage; you can even examine your pump to check if anything is caught in the impeller to prevent pumping. Refit carefully. Exit hose to fit at correct height in standpipe
Posted on Mar 08, 2009
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
Washer will not advance in the rinse cycle,water just runs continuely.
check the drain hose it should be only 6 to 8 inch in your drain line if drain hose is all the way in the drain line correct it and you will be fine.
May 21, 2009 | Washing Machines
Frigidaire top load washer won't rinse
this can be two issues. One could be the control knob. there could be a malfunction here. secondly, you may have a faulty water valve assembly. the relay or solenoid may need to be replaced. i would start with the control knob.
Mar 13, 2009 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Won,t drain on rinse cycle
    Ok mc we need a timer at this point. You see the timer doing several steps different than before.
    Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    It sounds like the lid switch is bad.Does it act as if the lid is open even when closed? A common problem is that its mounting method fails (breaks off) after some time. Quick way to test is:
    Find the plastic striker in the lid and under matching hole in the washer's top you should be able to find this switch. Try to operate (close) that switch with your finger or a screw driver and operate the washer while holding it down. If now it works, the switch is the culprit. Available on-line around $30.
    Aug 23, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
    Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
    Whirlpool GSC9455 Top Load Washer Logo
    944 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
