Question about Kitchen Ranges
Have a coleman range 2202k608 propane. psi. required to funtion properly ?
2 Suggested Answers
  • 3 Answers
SOURCE: coleman instastart propane stove regulator wanted
Check to see if Coleman has an attachment to replace the regulator, so that you can use a five gallon cylinder with your stove and your own regulator.
Posted on Jun 29, 2008
Why does my coleman stove regulator leak gas from the hole on the top of the regulator
Its a safety feature of the regulator. The regulator is designed with a pressure release valve. This has happened to me twice: once with a carbon dioxide tank for my kegerator and once on my propane stove. In both cases I left the regulator (designed with a max pressure rating of X psi) attached to a full bottle in the sun. The heat caused the pressure to exceed the limit of the regulator and the release valve popped. A welding supply store may be able to reset/replace the mechanism but in my case I just bought a new regulator for about $15.
Aug 14, 2011 | Coleman 2 Burner Propane Stove 5430E700
Try this site for the conversion factor: . 1 Water Column [inch] = 0.0361 pound/square inch (PSI) (to a reasonable number of significant figures).
I hope this helps.
(However, your stove and tank must be very different than mine. We didn't need to adjust the inlet input for the max PSI, just make sure that the incoming pressure was in the standard range for LP. New stove installed last month after old one suffered a failure of the oven valve.)
Jul 13, 2010 | Sears 61301 Gas Kitchen Range
Connecting the LP Fryer to the propane tank
The gas valve has a regulator on it....but there must be a regulator at the tank that steps it down from tank pressure to operating pressure. Operating pressure for LP is less than 1/2 psi. If you are using this for a trailer....a 40 lb tank would be best.
May 25, 2010 | American Range AF40 Deep Fryer
Can the burner inlet air be adjusted on a coleman DFAA066BBTA oil fired furnace ? if so how do i set it ?
Sure can. To do it properly, you should perform a smoke test after each adjustment. This requires a special tool. This may be why noone has answered your question yet. There is a band on the left side of the burner that can be opened to allow more air in. The flame should be bright orange/yellow. And again, perform a smoke test after you adjust it.
Jan 10, 2010 | Coleman Propane Forced Air Heater...
Any pressure switch in the same range will work. R22 Rage about 350 cutout 275 cut in. R410A 550 cutout 450 cut in. Most F22 Head pressure ranges about 225 to 275 depending on the Ambiant temp. 410A about 350 to 425 psi. Keep in touch Johnstone supply handles Coleman evcon go to ther website or call there toll free number in your area and give them the model number and they can match it or cross it over to one that will work. Rus
Nov 25, 2009 | Heating & Cooling
Want to connect to a 20lb propane bottle. what do I need?
you sure can go to academy in the camping supplies and you can get all of the parts to do it there
Apr 13, 2009 | Kitchen Ranges
Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
Mar 14, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Coleman propane space heater
Google "Coleman" and go to "Propane Heaters" you should see a "contact us" or some such type in your problem along with when you bought the product they will be more than happy to help you.
Jan 29, 2009 | Coleman Propane Forced Air Heater...
Coleman instastart propane stove regulator wanted
Jun 26, 2008 | Grilling
Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Dec 19, 2007 | Coleman Propane Forced Air Heater...
Kitchen Ranges Logo
62 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
