Question about Carrier 52CQ315 Air Conditioner
Incorrect Wiring for Thermostat
Our Carrier 52CQb315 air conditioner was installed incorrectly so we can only get heat. Per a Carrier Tech, there are only 5 wires run to the wall mount thermostat (the O terminal for the reversing valve is not connected.) They mentioned this could be corrected by correcting the wiring in the main unit and controlling the tempature with a remote control. Can this be done or is there a better solution? If so, where can I find a remote control.
  • 828 Answers
Do it right. Have the wiring changed so it works as it is supposed to. The remote control would make controlling the heat a manual operation. I don't think you want this.
Posted on May 01, 2008
7.5 ton carrier heat pump gets stuck in heat and stat will not turn it off. Reversing valve ok, what should I be looking at the thermostat or wiring? Help!! Btw I am a AC tech.
Since you are an AC tech you have probably already checked for stuck relay(s) My experience has been with AC units but not heat pumps-so I am only making a practical guess.
Feb 29, 2012 | Heating & Cooling
Carrier 6 wire, installed programmable hunter ther...
Is this a heat pump? Look in the thermostat. You should have something like the following.
Red wire to R terminal
Green wire to G terminal
Yellow wire to Y terminal
White wire to W or W1
Blue or Orange wire to the O or B terminal
Brown wire to C terminal.
Let me know what you have in the thermostat. The wire colors are not always the same.
May 21, 2010 | Carrier 38BRC048 Air Conditioner
Brought new thermostat wired it up as stated but keeps on tripping out
Hi; Need more info what is tripping out. Sometimes the old tstat has a different wiring code than the new . Is the unit a heatpump or elec heat or gas heat with cool...alpharome416.
Feb 19, 2010 | Carrier TSTATHCP Programmable Thermostat...
Furnace runs constantly since blower motor was replaced
Sounds like they wired it direct to line voltage , it should run through a sequencer or fan relay to cycle on and off , your seq./relay could be stuck closed to but unlikely being it was just repaired , call the service company back before you do anything they are responsible.
Apr 11, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Wiring Hunter Thermostat to 6 wire Carrier fa4bnf036
you probably purchased a 4 wire thermostat which we call heat/cool you stated you have 6 wires which signifies a heat pump you have to purcahase a heat pump thermostat and then write down the color of the wires to there related spots example...yellowe-y red-r white- w and so forth also before you do this kill the power the voltage typical for residential is only 24v's but if the wires touch you could blow a fuse
Dec 15, 2008 | Carrier 38BRC048 Air Conditioner
My Heat will not work on my upstairs unit. I am getting an E2 error code on my carrier thermostat. what does that mean?
the e2 code on a carrier comfort zone thermostat is indicitive of the external safety sensors which are located on your units ductwork in the attic. the e2 code are the hpt/ and lat sensor codes. the hpt is the heat pump temperature sensor and the lat is the leaving air temperature sensor. you can pull off the cover of the panel and behind it will actually give you all the fault codes associated with you carrier tsat.each sensor has a certain ohm rating and if its out of the range it will fail. now as to the reasons for failure, the indoor coil could be dirty, filters dirty, refrigerant charge incorrect.
Dec 03, 2008 | Carrier Heating & Cooling
Manaul Heat Control
24VAC Heat/Cool Single-Stage Heat Pump A common heat pump system has the following wiring & connections:
Description Color Terminal Code 24VAC Return Red R Call For Auxiliary Heat White W1 Force Fan On Green G Compressor Yellow Y or Y1 Changeover Orange C/O or O
May 01, 2008 | Carrier 52CQ315 Air Conditioner
Carrier Weathermaker gas 8000 will not ignite
1. check indoor unit wiring.
2 check sensar of thermostate.
3if not change thermostate
Mar 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier 52CQ315 Air Conditioner Logo
206 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
