Question about Refrigerators
The compressor is extremely noisy. You can hear it when you are far from the refrigerator.
  • 4,102 Answers
Hi, the best thing to try is give the fridge a push from side to side only slightly this should solve the problem its usually due to it touching a cupboard or board at the back.
So work it side to side first see if that stops the noise if not then pull it out a bit.
The only other option is to replace the compressor as they cant be repaired only replaced.
Hope fully your problem is just the position of the fridge, let me know how you get on ok
Posted on May 01, 2008
KFFS20EYMS01
Have you removed the cover on the rear of the refrigerator so you can test by listening there with the cover off? There also is a fan located next to the compressor and behind the rear wall of the freezer compartment.
Appliance 911 Sea Breeze
Nov 03, 2015 | Refrigerators
Brand new fridge extremely noisy now. What's occurring?
Some compressors can be very noisy, but it really depends on the type of noise.
Mar 07, 2015 | Refrigerators
The compressor is extremely noisy, yet it works perfectly. How do I cut down on the noise?
Unfortunately these compressors need airflow over the casing for cooling. New comp or try a white noise box.
Sep 25, 2013 | True GDM-10 Refrigerator
My Amana bottom freezer model # BB20VSE, serial # 0006289684, mfg # P1321301WS has become increasingly noisy when the compressor(?) turns on. This started over a year ago and now is extremely loud. Thank...
Ah this is an indication that your condenser has become dirty, or blocked, or the fan motor is not working or the air flow is restricted.
The noise is generated when the compressor cycles off and sudders to a stop
Mar 24, 2011 | Amana ARB9058CS Bottom Freezer...
Inconsistent cooling, no ice, noisy fan motor.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Feb 25, 2011 | Viking DFSB483 Side by Side Refrigerator
Compressor fan is extremely noisy
sounds worn, would get a new fan fitted, as would cost alot more if the compressor overheats and gets damaged .
Dec 11, 2009 | Jenn-Air JCD2295HES Side by Side...
GE side by side gss23qg gss23qs: Freezer is not working, building up frost, ans is noisy.
If you hear the compressor (underneath the refrigerator) running okay, you need to check around the compressor and see if the compressor fan is turning. If this fan does not turn, heat is not removed from the refrigerant coils as it should be. This greatly lessens the cooling ability of the system.
If this fan is not turning, you will have to replace the fan motor.
Oct 15, 2009 | Refrigerators
True T-49 side by side is noisey
is unit cooling? if not suspect a deficient compressor. if it likes makes a rattling noise really loud suspect compressor wear hope it can help.
Apr 18, 2008 | True T-49 Side by Side Refrigerator...
Noisy Fridge!
Have you ever cleaned the coil under the refrigerator? If the coil is very dirty the compressor will run very hot and when it finaly shuts off its banging is a sigh of relief. Pull the bottom panel off and vacuum inside as far as u can reach. They also sell brushes for cleaning them.
Apr 08, 2008 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
GE Stainless Steel Side by Side - Loud Huming and Whoosh noice
you should not hear it from that far away. It sounds like it may be compressor related. The only thing you could check to make sure is remove the lower rear cover and check the condensor fan and listen to the compressor to see if thats where the noise is cmming from. Check the fan in the freezer too.
Aug 06, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
