Question about Refrigerators
  • Anonymous Mar 25, 2014
    I have sausage that is 9 years old
  • 828 Answers
Check your temperature. You may be running it to cold and dehydrating your products. The snow is moisture pulled out of the products.
Posted on May 01, 2008
The freezer keeps building up ice and the food defrosts.I removed everything and defrosted it with a hair dryer. Worked well for about 2 ;months now the same thing has happened. It's a side by side mode;...
the one in the garage need a fan motor maybe . the defrost problem would be the heater or the defrost terminator or the a d c adaptive defrost control . . therminator is most common is in back of freezer behind plate and above the cold coil . defrost will have to be done to get to it ..
Dec 23, 2009 | Refrigerators
Is it good to keep food in plastic containers in the freezers to separate them
yes it is if for example meat in a closed container does not get the freezer burn vegetables also if they are just kep in bags it gives the food a taste of old ice
Oct 27, 2009 | Refrigerators
No ice
IPour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 12, 2009 | LG LFX25960ST Stainless Steel French Door...
Has just one termostat on bottom, freezer won't keep ice cream frozen, although it does keep meat and ice froze
OK send me the model number as found in photo below. You may have a circulation problem that I will be able to look over closer when I have model number. Sea Breeze
May 25, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Frozen foods collecting ice crystals in my freezer
Your freezer is getting too warm during the defrost cycle, causing condensation in your veggies and eventually freezer burn. Likely your door seals are leaking as well after 17 years which introduces even more humidity into your freezer, but I'm assuming your talking about sealed bags of veggies? You need to decrease the temp in your freezer. Get a thermometer and make sure you average around zero degrees. The cause? When is the last time you cleaned the coils at the back of the fridge. Or if they are sealed, perhaps you need to have it serviced. You can try moving your freezer setting to a colder setting it may take care of the problem.
May 20, 2009 | Traulsen Refrigeration 48'' Wide x 24''...
Warm on inside edges of front refrigerator doors, not very cold inside....and freezer is hard as rock. Setting on freezer is 3 and refrigerator was 3, but now we've turned up to 6. Definitely not normal....
The fridge gets its cold air from the freezer--it could be that there is ice build-up restricting air flow from the freezer. See if you can see any ice there...Is it possible to defrost the whole unit for several hours (even over night)?
Mar 16, 2009 | Jenn-Air JFC2087HRP Side by Side...
Follow up to question: meat & veg tray freezing food on new side by sid refrigerator
with very littlle ice cream I would set freezer temperature to -2 degrees and leave the humidity seting where you have it remember to let the unit run for 24 hours to stabilize then you can make another adjustment. By the way you are not being a pest I don't mind helping you at all, I am a service manager and answer quesitons allo day long.
Jan 09, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
