Question about KitchenAid 24 in. KUDG25SH Built-in Dishwasher
Loose Door Handle
How can I tighten the door handle on the KitchenAid Dishwasher
  • gogoaltman Jul 08, 2008
    interested in this one as well
  • efvaldez Sep 01, 2008
    Removed the exterior gasket and noticed steam percolating between the door and the cabinet-brace. The percolating steam would collect and trickle down the sides of the door until a puddle would collect under the door. I squeezed the door by using a clamping-device that pushed the door closer to the cabinet-brace. the perclating water stopped and the puddles are gone. Clearly using a larger internal gasket and a tighter door latch would ensure no more leaking. Can the door latch be adjusted to close the door tighter? If not is the only solution a larger internal gasket? Thanks in advance
Door tension
Posted on Nov 22, 2008
3 Suggested Answers
  • 944 Answers
SOURCE: Loose door handle
Here is the link to the installation manual; pages 14 and 9 of the manual (16 and 11 of the pdf) describe how to remove the toe panel, and the door facia panel. You should then be able to access where the handle is attached. Hope this helps :)
Posted on Jul 15, 2007
SOURCE: loose door handle on ge profile dishwasher
Take the inside panel off.  The 2 screws near the latch only need to be loosened.  Once the handle is off, you will find an allen bolt inside the shaft of the handle support.  Tighten and you are done.
Posted on Dec 31, 2008
My Dishwasher door won't latch?
Its probably loose. pull the unit out and tighten it or fix any broken parts.
Aug 19, 2014 | KitchenAid KUDK03ITWH Full Console...
Loose handle
Open the door and loosen the self threading screws around the sides of the inner door panel. Once this has been achieved lift the inner panel up so that you can access the door handle screws. Tighten these fasteners and reassemble the door panel.
Jan 24, 2014 | LG LDF6810ST Stainless Steel Built-in...
I have a kitchenaid electric range and the oven door handle is loose. Can I remove the door and open it and tighten the handle?
My son came and pulled the door straight out not up and we were able to take it off and take it apart and tighten the handle and clean the inner glass. It now looks and works like new.
Thank you
Aug 07, 2009 | KitchenAid Kitchen Ranges
Loose door handle on ge profile dishwasher
Dec 20, 2008 | GE Profile PDW9880NSS Stainless Steel...
Loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Dec 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Kitchenaid Dishwasher Latch Broken
Nov 02, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Jul 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Handle loose on Refrigerator
To fix this you will need an Allen wrench small one there are 2 set screws on the inside part of the handle (on side toward the center) you wil need to tighten these to fix your problem
Feb 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid 24 in. KUDG25SH Built-in Dishwasher Logo
468 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
