Radio reception is there a way to easily boost radio reception in my home for an ordinary mini stereo? My current radio has the hangy down wire for an antenna. The car receives understandable sounds but the house only does if you stand there and hold the wire! - and don't move!! I was told to get an fm booster but can't figure out how to connect it if I got one.
  • slvbrennan Jan 21, 2009
    Getting the FM antenna's no problem.  It's connecting it to the tuner!!  Could anyone suggest where to get a connector??
    Sergeant:
    Champion:
  • 319 Answers
Use a dedicated FM T-strip antenna avialable from Radio Shack or even Wal-Mart
Posted on May 07, 2008
I have an RCA model 1285 mini stereo. It has bad FM reception. It only has a wire coming out the back for FM reception. How can I add an antenna ?? Most antennas require two contacts!
Actually most use the AC Ground as the other "phantom half" of your antenna... Of course YOU will not get access to that circuit because errors there could cost your life.
You COULD try stripping back some of the insulation and extending that single wire to a longer wire?
Wire placement will be a factor too so try moving that longer (and stock wire) around for BEST reception.
Here is a link with some insight:
How to Get Better Reception for My Single Wire FM Antenna Techwalla com
I tried to find a "service manual" and schematic to help more, but I could find none... these items are mostly throwaway now because the cost of labor and STOCKING specific parts is too expensive!
Anthony
Dec 24, 2017 | RCA Audio Players & Recorders
2002 Grand Caravan factory stereo will not tune in radio stations (no reception). How do I troubleshoot to determine if it's the antenna or the tuner?
Remove the radio unplug the antenna use any electric wire pill the end of the wire turn on the radio try to. Stick the wore in the hole of the antenna. If it's tune you need a antenna if not you need a radio.
Oct 05, 2013 | Cars & Trucks
I installed my Sony CDXGT250MP today and am able to listen to the cd played or Aux output but I have no radio reception?? I connected all of the wires and did have three left over in the wiring in the old...
The orange/black wire should be a dimmer, the blue wire should be power antenna, the Blue wire should only be hooked up if your antenna goes up when you turn the car on, also goes down when car is off. OR you could possibly have an aftermarket antenna that needs power to boost signal. There should be a thick black wire that is pluged in somewhere on the back of your radio.bassmekanic.gif
Nov 06, 2010 | Sony CDXGT250MP
I MOVED THE STEREO TO ANOTHER LOCATION. NOW I CAN'T GET SOUND OUT OF THE REAR AND CENTRE SPEAKERS. ALSO, DO I NEED A WIRE FOR AN ARIAL. I CANT GET ANY RECEPTION ON THE RADIO.
yes, you need an antenna for reception. then select dolby surround "hall or Phanthom" and you will get all speakers to work.
Mar 06, 2010 | Sony MHC-ZX70DVD System
Will I get good reception in a metal factory building I get spotty fm reception with my current radio
With old radios it worked to connect the antenna to some central radiator or (metallic) water pipe. Some old wire was used to connect it;
Feb 22, 2010 | Grundig S350 AM/FM/SW Radio
Awful AM reception on Sony ICF-CD513 kitchen radio
You may have to use foil or other metal to extend the antenna artificially. I found years ago that even wrapping my hand around the end of it boosted the signal (though I'm sure you're not willing to listen to a radio while holding the antenna the whole time). I once sat a TV antenna on top of a portable CRT with its own internal ferrite antenna, and the video signal was about 80% there, audio 100%. This may be an inconvenient method, but it will guarantee at least most of the audio quality you want.
Jan 30, 2018 | Sony ICF-CD555TV 7 in. Portable Television
JVC detachable face with auxillary input
You may have a bad antenna or antenna cable.
FM signals are measured in microvolts and are easily influenced by poor antennas or a mashed antenna cable.
Aug 12, 2008 | JVC AM FM CD DET FACE CAR STEREO
No antenna, no radio reception
If the model number is SC-AK630, please confirm. The antenna should still be available from any Panasonic part distributor. Please confirm the model and I'll get you the part number and cost.
Dan
Jul 29, 2008 | Panasonic SC-AK630 CD Shelf System
I NEED AN ANTENA FOR PANASONIC SA-PM32DB
If its a one wire or two wire FM/AM antenna your needing just use a length of regular stereo speaker wire or electrical wire at least 5foot in length. Should do the trick nicely.
please rate answer.
Mar 18, 2008 | Audio Players & Recorders
Better fm reception
Is it just a single wire?
If so, purchase a cheap FM antena. It looks like a "T" when spread out (4' to 5'). That should help.
You can purchase an "amplified" antenna, but if your area reception is really bad (such as in a valley) the antenna would just amplify the noise as well. Look for web based radio in this case or if you have cable there are stations on it.
Jeff
Jan 11, 2008 | GPX HM3817DT Shelf System
464 people viewed this question
 Grubhead
Grubhead
