Question about Cameras
Have inserted memory card. camera does not work.
Two (2) different memory cards use to work in Canon A40, now they don't. Original memory card which came with camera still does work so it is not the camera....any ideas?
Posted on Nov 05, 2008
When memory card is inserted the camera wont work
You can insert CF memory and some memory stick cards when you use a special adapter. When you use a memory tick, make sure it is compatible, because the memory stick is the most incompatible memory card, if you have not the correct one.
When you use a CF memory card, check all contacts. Not one contuse pinn in the camera should be belt a little. Use a bright light and a loupe to check.
Feb 13, 2014 | Sony Alpha DSLR-A350 Digital Camera
I cannot get memory card into camera
Your camera uses "xD-Picture Card" memory cards.
To insert the memory card, you have to open the battery cover and you see a little room, where the card goes in. There should be a gold marking indicating where the contact area on the card should be when inserted.
Don't try to insert any other kind of card.
I saw a xD-Picture Card adapter, where you could insert a micro SD card, but I'm not sure your camera can work with such a adapter.
Jan 19, 2014 | Fuji FinePix F460 Digital Camera
Pictures show up on memory card in camera, but computer won't recognize the card - either inserted directly or by USB
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Aug 11, 2012 | Nikon D40 Digital Camera with 18-135mm...
I put my memory card in my camera and it has a message that says no memory card. What do I do
I suggest you to turn off your camera and then turn it on. Or you can also re-insert the memory card.
Thank You.
Aug 02, 2010 | Canon PowerShot SD1000 Digital Camera
Sd card cannot be read & internal memory of camera cannot be read
Which Kodak camera model?
It may not support a large SD (SDHC) memory card.
Remove the card and remove the batteries.
Turn ON the camera (I know, no batteries) for one minute.
Turn OFF camera and install batteries.
Do not insert the memory card.
Does the internal memory work?
If so, insert memory card.
If it's ok to format the card, do so.
If not, then use a USB adapter and copy the memory card to your [My Pictures] folder.
Format memory card.
Oct 01, 2009 | Kodak Cameras
What does no card mean? Thank you.
"No card" means that either
  1. You have not inserted a memory card
  2. The memory card is not formatted, or
  3. The memory card is damaged and therefore can't be read by the camera.
How to insert the memory card:
  1. Open the camera’s battery door by sliding it downwards.
  2. Insert the SD card into the slot as shown inside the camera’s battery compartment. The SD card can only be inserted one way.
  3. Press the SD card completely into the camera and then close the door. Open the door and press on the memory card if you wish to remove it.
Note: There is only one way to insert the SD memory card into the slot. Do not force the card into the slot. This may damage both the camera and the SD memory card.
Before you can use the card, it has to be formatted:
  1. Insert the memory card into your camera as described above.
  2. Turn the camera on by pressing the power button.
  3. Use the multi-select button to select the "SET" option.
  4. Press the right arrow button to set "System" then press down key to select "Format".
  5. The default option is ‘Format’. Select this option by pressing the OK button.
  6. Select "Yes" to format the card.
If all this does not work it might be that your SD card is damaged. Try to replace it with another one. If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 08, 2009 | VuPoint DC-ST300-VP Digital Camera
New camera will not turn on when memory card is inserted
What type of camera are you using?
Is the memory card brand new? the memory card is probably  corupt, try formatting it on a computer and trying again.
How big capacity is the card?
The camera may not be able to handle the card if it is a HC (high capacity) card, but it depends on the camera.
Will the camera work with other cards?
Sep 10, 2008 | Cameras
Memory card is not working
Memory cards can be defective. Its not big deal. try to use another memory card.
Jul 31, 2008 | Cameras
Camera wont work when memory card is inserted
I suggest you try to use a different memory card. If it doesn't happen again then it's probably a bad memory card.
Mar 06, 2007 | HP Photosmart M417 Digital Camera
"Memory card is unusable"
This error message means that the memory card is slow, corrupted, or unreadable. Turn off the camera then insert a new memory card.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
