Brother CMF-240. to instal i nwindows Vista the cd to instal is not workin in Vinta program.
  • Ajerez May 01, 2008
    the printer is in perfec conditions the prroblem is to instal and instal i Vista
    program.
    Genius:
  • 3,422 Answers
I'll let you know if there are any drivers available for your model..
Posted on May 01, 2008
  • Priya darshan May 01, 2008
    CLICK HERE to download the vista driver and please don't forget to rate or accept the solution as fixya..
  • 13,433 Answers
Yes you need the vista software One moment
  • Ekse May 01, 2008
    cmf-240 is not a valid model, do you have more info on the printer?
    Guru:
  • 1,894 Answers
Are u sure it supports vista?
How to turn on &off blue-tooth in hp 6910p
i've compiled everything for you and highlighted your answer
Special instructions for the HP Compaq 6910p
BEFORE WINDOWS INSTALLATION 1) MAC addresses The MAC addresses of the Ethernet (cable) and the wireless interface (WiFi) are written on a label on the side of the box. They are also written on a label at the back of the notebook. They must be registered in the CERN network database via http://network.cern.ch (using another computer) before starting the Windows installation.
2) Wireless switch on
When you start the installation, verify that the wireless light (with an antenna symbol) above the keyboard is on (blue light) in order to install properly the wireless drivers. If not, touch that antenna symbol with your finger: it is a sensitive button.
WINDOWS XP After Windows XP installation 1) Keyboard_Filter_01 As by default users are not in the Administrators group, a window titled "Found New Hardware" may tell you: "You must be member of the Administrators group on this computer to install this hardware: Keyboard_filter_01". In that case ignore that message and first regain administrative privileges by using the NICEAdmin application to add your account in the Administrators group. For that click on the Start button, select All Programs then NiceAdmin then Change Account Status. On the popup window click on Add Me, enter your login password and click on the green button (with an arrow). Then Reboot (a logoff/login is not sufficient). This time, the installation of the Keyboard_Filter_01 driver will be done silently.
Don't forget to use NICEAdmin again to remove yourself from the Administrator group in order to improve computing security after your next login. But don't log off until you have installed all your programs (for example the Bluetooth software explained below).
2) WiFi To setup a wireless network connection, you must be within range of a wireless Access Point. Check also that the wireless interface is switched on (blue light above the keyboard).
When Windows detects a wireless network for the first time, it should prompt you with a Wireless networks detected message in the notification area of your taskbar. If so click the notification message. If you are not notified, click on the Start button, point to Connect To and click on Wireless Network Connection. In either case, you should see the dialog box Choose a wireless network. Select CERN and click connect. On the warning "You are connecting to the unsecured network ...", click on Connect Anyway. Wait until connected to close that dialog box.
3) Bluetooth
If you need to connect to Bluetooth devices, HP provides a software to manage your connections. To be allowed to install this software, you must be registered in the Administrators Group of your computer. For that you can use NICEAdmin: click on the Start button, select All Programs then NiceAdmin then Change Account Status. On the popup window click on Add Me, enter your login password and click on the green button (with an arrow). Then Log Off and login again.
Check that your notebook wireless interface is switched on (wireless button above the keyboard with blue light on). The Bluetooth installation package is located in "C:\SwSetup\HP Bluetooth software v5.1E 26Mar07". In that folder, double click on Setup.exe to start the installation.
After the installation, you can use NICEAdmin again to remove yourself from the Administrator group.
4) DVD player
If you need to play DVD videos you can install the WinDVD player provided by HP for your portable. First right click on the CERN CMF (Computer Management Framework) icon in the system tray. If the CMF icon is not present reboot your computer and wait some minutes. Choose Add/Remove CMF Packages. On the CMF page tick the install box for the package WinDVD player for HP and click on the Save button. Then a CMF balloon should appear proposing to install WinDVD. Click on the balloon (or double-click on the CMF icon). In the CMF windows select WinDVD player for HP and click on Start Now. After some minutes CMF should display a balloon telling The installation of the package *WinDVD player for HP* completed successfully.
WINDOWS VISTA After Windows Vista installation 1) WiFi To setup a wireless network connection, you must be within range of a wireless Access Point. Check also that the wireless interface is switched on (blue light above the keyboard).
Click on the Windows Start button then choose Connect To. Then select CERN, click on Connect and then on Connect Anyway. When the window announcing Successfully connected to CERN appears, put a checkmark in Save this network and in Start this connection automatically. Finally click on the Close button.
2) Bluetooth
To activate the Bluetooth, press the wireless button (antenna symbol above the keyboard) to get a blue light on that button. Then click on the HP Wireless Assistant window which appears in the bottom right corner of the screen. If the status of Bluetooth is not on, click on turn on. Close the HP Wireless Assistant.
3) DVD player
Nov 13, 2010 | HP Compaq 6910p Notebook
Instal MFC-5840CN from original CD
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/dlf/000000/002800/dlf002879.html?reg=us&c=us&lang=en&prod=mfc5840cn_all&type2=1&os=74&flang=8&dlid=dlf002879
This is the full software and driver setup for Vista 32 bit if you have 64bit you will have to change the OS selection on the Brother.com site.But This is the software you want, just unplug the printers USB cable until the setup asks for it or completes first.
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_index.html?reg=us&c=us&lang=en&prod=mfc5840cn_all&type2=-
1&os=74&flang=English&dlid=
This page has all software related to the printer for vista, please copy and paste the second link in your adderess bar if you need to use it.
Mar 23, 2009 | Brother MFC-5840CN All-In-One InkJet...
My brother 240-c wants to send all of the documents to one-note, that is not what I want to do, I need to print them, My operating system is vista
One Note is a crappy little program that comes with Vista. Your problem is located in the printer setup. Click on control panel, go to printers. Your Brother 240-c should be shown there. Right click on the icon for the Brother and click the item called, set as default. Now when you look at the printer icon, it should have a check mark beside it. If it does, the Brother is now your default printer. Now print some stuff. I hope this fixes your problem. Thanks for using Fixya!
Jan 26, 2009 | Brother Multi-Function Center MFC-240C...
Mfc240 all in brother printer
i need the install utilities cd to program my mfc-240 machine
Sep 06, 2008 | Brother Multi-Function Center MFC-240C...
Hey there, I was trying to
I guess I found a solution for the problem.
I also got this error message after installing ControlCenter3. Failed to start ControlCentre3 - re-install software, with the error No CC3-001-00001907. The numbers at the end can change, but that's not important.
I have two laptops running vista. I got this error with the 1st laptop. Then I tried it with the second laptop, it worked fine. That made me think: On the first laptop I had tried to install the ControlCenter3 from the CD, but it turned out that the CD did not support Vista. Then I got the vista driver/ControlCenter3 package from the Brother website. This is the one that did not work on laptop one. What I then guessed was, that I had some ugly remains from the installation of the old driver (not for vista). I started cleaning the registry. First of all I run the driver uninstall program from Brother (free from their website) then I cleaned the registry with CCleaner (freeware). Still that was not enough. I started the regedit program and started searching for the term Brother. It was still there in about 10 or more places. I deleted all records that were connected with my brother printer (a DCP-130C). Then I run CCleaner once more. Then I installed the vista driver package (from brother website). Restarted and voila: it worked. ControlCenter3 workes fine now. I started the ControlCenter3 update (also on brother website) and finally with the scanner utility put the scanner resolution limit up higher. That's it.
Before working with the registry make a backup, please.
This procedure should also work for other brother printers using the controlcenter3. It should also work for other systems than vista.
Cheers, hope this was helpful.
Edi
Jul 15, 2008 | Office Equipment & Supplies
BROTHER MFC 240 PRINTER
go to brother.com website and download vista drivers and software for the 240
Jun 01, 2008 | Microsoft Windows Vista Ultimate Edition
Brother MFC240C in stallation
The solution for this one's an easy fix. All you have to do is go to brother, click on Product Support, select your country or the nearest one to you, then where it says please enter your model name type in mfc-240c and hit enter. Click where it says MFC-240C and then go to downloads, select drivers, then your operating system, and then your language, and finally, click search. It will bring you to the page with teh drivers for your printer. In the downloads area, you can also download the manuals, the software for your printer, etc.. It's all quite well laid out. Let me know if you run into any problems.
~adamvan2000
Mar 19, 2008 | Brother Multi-Function Center MFC-240C...
Printer installation
i need a installer in my printer ( Brother DCP 130C) any can help me plz...
Mar 16, 2008 | Brother DCP 130C All-In-One InkJet Printer
I lost My installation cd, I need to install on my windows vista os
download drivers from brother homepage of your country:
http://welcome.solutions.brother.com/bsc/Public_s/index.html
Jan 02, 2008 | Brother MFC 420CN All-In-One InkJet...
42 people viewed this question
jasbo
jasbo
