Question about Whirlpool LGV4634JQ Gas Dryer
Dryer Wont Spin
My gas Whirlpool dryer has heat, but the clothes do not turn.  Please help.
Thank you, kelly
  • post man May 14, 2008
    i saw the broken belt . how do i take foo the froht in order to replave belt?
    Scholar:
  • 58 Answers
Most likely a motor, If machine runs but not turning, either belt broke, if direct drive, motor
Posted on May 01, 2008
WGD5530SQO WONT DRY CLOTHES BUT TURNS ON SPINS N DOES NOT WARM UP N GAS LINE FLOWS
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 25, 2011 | Whirlpool WGD5900S Gas Dryer
I have a whirlpool dryer and for some reason it has quit getting hot so it's not drying my clothes. Also my dial wont turn. When I turn the dial to start a load it never moves from the begining...
heatman101
Jun 24, 2011 | Whirlpool Dryers
Whirlpool Gas Dryer Model # LGR7646JQ0. Bought it used, warranty useless since the shop I got it from went out of business. Everything works fine. The drum turns, the timer works but the thing doesn't heat...
Hi and welcome to FixYa. I am Kelly.
Your power for the burner assy goes on a series circuit from the timer to the high-limit thermostat to the operating thermostat to the thermal fuse to the gas burner assy, thru the motor centrifugal switch to the door switch. EACH of these must be functioning for the burner to light.
This manual will help with some of the how to do it as far as component access, removal and replacement of parts.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794
Also this link has loads of information on what to check.
http://fixitnow.com/wp/2006/09/19/how-to-check-the-burner-components-in-a-gas-dryer/
The 3 most common failures are
Igniter:
Gas Valve
High Limit Thermostat
Compnents : http://fixitnow.com/appliantology/gasdryer.htm
Note the LINKS!
Here is a 9 min video that pretty much covers everything you need to check: http://www.howcast.com/videos/371390-How-To-Troubleshoot-a-Gas-Dryer-That-Wont-Heat
Thanks fo choosing FixYa.
Kelly
The
Aug 20, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer wont spin
There can be many reasons why your dryer will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 20, 2010 | Whirlpool LGR5636L Gas Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
My gas dryer stopped heating it is a Kenmore 70 series. I am getting good gas flow but dryer will not heat.
Try this link I hope it helps, I know it helped me a ton!! ps don't forget to rank my help. Thank you and have a nice day!
http://fixitnow.com/wp/2004/11/13/mailbag-how-to-troubleshoot-a-gas-dryer-with-no-heat/
May 07, 2009 | Whirlpool LGR3624JQ Gas Dryer
Whirlpool gas dryer wont heat up
Hi!!! you seem to have a problem with the coil boosters..located above the gas valve..Its shown here .Good luckk..8035205.jpg
Jan 21, 2009 | Whirlpool LGR6636 Gas Dryer
Clothes dryer doesn't spin
The way most domestic clothes dryers are made, it's usually hard to determine that the heating part works without the drum turning.
But, chances are, the drum belt is broken.
Please give the specific model number of your unit for a more complete response.
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool gas dryer will not heat up?
How do I take apart a kenmore gas front load dryer, to get to the fuses, heating element etc. Model # 417.91042000. Please Help... Thank-you
Nov 10, 2008 | Whirlpool Dryers
Gas dryer lgr4634eqo GAS
check the thermal fuse located at the back of the dryer for continuity and let me know how you make out
Sep 13, 2007 | Whirlpool LGV4634JQ Gas Dryer
Whirlpool LGV4634JQ Gas Dryer Logo
76 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
