Question about Roomba Robotic Floor Bagless Vacuum
No suction Hi i have a red roomba, and it has no suction anymore.
  • 2 more comments
  • mornachew May 02, 2008
    Hi thanks for your quick reply.
    Yes clean them all the time and wipe down.
    I felt the back of the roomba when it was on and thier was air coming from it - so the back motor is working - but its just not picking anything up anymore.
    Yes to the cleaning the brushes and the connections - i feel the little motor at the back working.
    Still not picking up though
  • bmalison Jun 10, 2008
    My red roomba no longer "sucks" in any debris. Brushes, filters and chambers are all clean. Vaccuum is only a few months old. Seems to make an odd noise and brush apparently does not turn
  • rosslyn1037 Oct 22, 2008
    We just bought a 4150 model Roomba not even two months ago, and now it is making a high-pitch squealing sound and there is no suction. I empty the dust bin and clean the brushes after every use, which is about every 2 days. We have 3 cats that it is cleaning up after. I ran it without any brushes to see if it still made the noise, and it didn't. So I figured that maybe the brushes and filter need to be cleaned with soap and water. I wiped out the dust bin and the body of the Roomba with a lightly dampened cloth. After doing that and allowing everything to dry overnight, I put everything back together, but sadly, we hear the noise again, and no suction. So I don't know what is wrong. Tomorrow, we will call iRobot. We are thinking that maybe the vacuum motor isn't working anymore, and only after 2 months of purchasing it. Are the more expensive models, such as the 560 better quality, or are they all the same under the hood? If anyone can help me, that would be great. Thanks.
  • 3 Answers
Roomba does much of its cleaning by the brush and roller on the bottom, but an important part is the little fan at the back of the debris bin which provides 100% of the 'suction.'
First, take off the vent cover on the back of the debris compartment and start Roomba on a mission. You will see the little turbine spin (if it's working) and probably a little dust cloud will come out.
It may not be working at best efficiency, however, because dirt gets sucked into the housing and blocks much of the air flow. Now that you know what the fan/turbine looks like (it's quite small, only the size of two stacked silver dollars), peer down into the larger opening of the debris bin and view the turbine from the other side. Chances are there's some crud stuck down there which is impeding air flow. (There's a hollow part of the turbine where the air is sucked into before being expelled out the back, that's probably filled with pet hair/dust/etc.) Clean that out using a long knife, chopsticks, or anything else that can reach down in there. Bang the dust bin down (lightly) to dislodge any more hair that's up there and continue cleaning until it's all gone.
I've had 3 Roomba's and they all get hair stuck up there. I only have to do this once a year or so (multi-cat and dog household here!) but it makes all the difference in the world.
Posted on Jun 21, 2010
  • 97 Answers
Roombas are a vary "low suction" device. The major amount of debris is picked up by the brushes. I assume you a re using the brush cleaning tool, removing the brushes and cleaning them. The other part is the dust bin which contains a small turbine motor. The connections can become dirty and the motor will not run. Make sure you keep the dust bin clean with a damp cloth especially at the contact points on the bin and roomba unit.
Posted on May 01, 2008
  • Paul Cernech May 07, 2008
    If every thing is working as you said, then my suggestion would be to buy a new brush kit and filter and see if that helps.
2 Suggested Answers
bobfiala
  • 28 Answers
SOURCE: No suction on my red roomba
Make sure you have a filter installed, then change or clean it. Without a filter, the fan will get clogged.
If that doesn't help, clean the fan and the exhaust port, and verify that the fan is working.
If the fan is working and the filter is clean, then your appearent lack of suction is probably due to the fact that your brushes are not turning, and therefore not collecting debris. That's a whole different problem, one I also have, but haven't solved yet (though there are suggestions on this site).
Posted on Nov 14, 2008
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
Status light is red, why? I have a Roomba Discovery.
Hi.
If the red light is solid, that means that the Roomba is near to full discharge. If the light is flashing red, then the Roomba is completely out of charge.
If the Roomba is fully charged, then there may be a fault.
Here full list of light codes:
Pulsing Amber - Charging
Green - Fully Charged
Amber - Partially Discharged
Red - Almost Fully Discharged
Flashing Red - Fully Discharged"
Here manual
See also
Roomba DISCOVERY MODELS' DIAGNOSTIC TESTS
May 24, 2010 | Vacuums
Roomba Discovery SE Bagless Robotic Vacuum: My Roomba battery charger has no lights and does n...
use a multimeter to test if it is actually putting out a charge. Is this a regular roomba charger with the green led on top? And it just doesnt light up anymore? If so then the pack is dead. replace it.
May 16, 2010 | iRobot Roomba Discovery SE Bagless Robotic...
Backs up spins in circles, then red light flashes and beeps
Sounds like either the battery is bad or not being charged properly with subsequent loss of programming.
Jul 23, 2009 | iRobot Roomba 500 Series Virtual Wall...
No suction on Roomba 560
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module. If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
Jun 02, 2009 | iRobot Roomba 560 Robotic Vacuum
Red sensor
If your Roomba's red "check robot" light comes on, the Roomba should also give a hi-lo warning tone, then a number of beeps. Check the number of beeps with the chart toward the end of your manual-- it should tell you what to do.
May 29, 2009 | iRobot Roomba 560 Robotic Vacuum
Brushes cleaned thouroughly and wheels as well. Does not appear to be suction.
Start troubleshooting here. If that doesn't help, call customer support at 1-877-855-8593. Be sure to have your Roomba with you when you call.
May 21, 2009 | iRobot Roomba 530 Robotic Vacuum
May 01, 2008 | Roomba Robotic Floor Bagless Vacuum
Roomba Robotic Floor Bagless Vacuum Logo
1,968 people viewed this question
Top Roomba Vacuums Experts
Lonnie Arks
D. E. Hev
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
