Get a "F51" code on my Maytag Bravos washing machine and the lights blink-up when code is displayed.
  • raddhikadevr Jan 24, 2009
    i have a kenmore elite oassis showing f 51 error.to takes in 1/2 minute water and stalls.i have tried all cycles and nothing happens.can somebody please help.
Go to http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567036.pdf
It shows what the codes mean. It's been fixed by people (when machines are out of warranty!) by taking the control panel, and reseating wires on it and the motor.
You are by no means the only having the problem:
http://worldofwashers.blogspot.com/search/label/f51
Posted on May 01, 2008
How to replace bearing on maytag bravos washing machine
is it loud in spin if it is then change the bearings
Feb 02, 2014 | Whirlpool Washing Machines
I have a Maytag Bravos MVWM750WQO washer. A F51 code came up and I called a repairman in he said it was the bearing and would be $406.59 to repair. Not sure if its worth it since its only 2 1/2 year
Well the failure is Motor RPS Failure. Depend how he consider the charge for parts+job.
I am sorry. Try to locate another tech service.
God bless you
Aug 01, 2012 | Maytag Washing Machines
I am getting a F50 code on my bravos, what does this mean
go to the makers website for a user manual there usually free to download and you should find an answer eric
Dec 23, 2017 | Maytag Bravos 4.5 Cu. Ft. Washer
MAytag Bravos Quiet Series 300 washing machine starts to fill, stops and shows code F51
F-51 RPS senses rotation when basket ought to be stopped.
It is probably loose or worn out.
Video How To
Oct 22, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
I have a Maytag Bravos washing machine that has just recently become really noisy when it goes into high speed spin. I have lifted the cover and found no items or debris. When I spin the tub by hand it...
Hi.
F51 is motor position sensor error. From manual:
F51: Motor RPS Failure
F then 51 flashes when there is a motor rotor position sensor (RPS) failure or lower harness problem.
The motor position sensor failure may be the result of a problem between basket and motor.The parts below the basket must be inspected. There is need to remove the basket to check parts in there. I can give you the procedure to remove the basket if you want.
Aug 20, 2011 | Maytag Bravos MTW6600T Top Load Washer
Maytag washer -- what does the code f51 mean?
hello, you need to install part #W10183157. it comes with instructions itnot that hard to install. it should correct your issue. thanks and please rate me :)
Jun 08, 2011 | Maytag Bravos MTW6600T Top Load Washer
My Maytag 300 quite series has a code F51 what does this mean?
Hi and welcome to FixYa, I am Kelly The F51 code is a motor rotor position sensor (RPS) feedback error. In other words the control board is not sensing any motor rotation. It is fixable but will result in the replacement of failed parts. (Sensor or electronic control board) The control board is not cheap. Hopefully you only have a failed sensor.
Thanks for choosing FixYa,
Kelly
Feb 16, 2011 | Maytag Bravos MVWB400V Washer
My maytag bravos shows a F51 on the display?
RPS failure.
This happens when overuse of detergent causes the motor to over work itself.
I have a manual and more HERE
Jan 30, 2011 | Maytag Washing Machines
I have a Maytag Bravo top load glass washer and a f51 code. Top wont open and machine has stopped
Defective hall sensor most likely, The cabrio bravos and Oasis machines are all basically the same.
MORE here
Dec 19, 2010 | Maytag Bravos MTW6600T Top Load Washer
Washing Machines Logo
626 people viewed this question
Top Washing Machines Experts
