I have a RCA TV and I would like to have the RCA DTA800A/800B Converter Box and do you know what stores are going to handle these Thanks
Most likely u know this by now,,,,but walmart carrys them,,,,,most of them anyways,,
Posted on Oct 23, 2008
  • whiteshadoww Oct 23, 2008
    get the rca 800b1 not the 800a
  • 2,326 Answers
Click here for more info.
Posted on May 01, 2008
Venturer. How can I use it with an RCA STB?
If your Venturer remote is universal, you can use its code search feature to find something that can handle some or all functions of your RCA STB. If a search through all codes stored in the remote fails, you may have to try another universal remote such as an aftermarket RCA.
Apr 06, 2016 | Televison & Video
they sell those cable adapters almost every where tv antennas & cables are sold even home improvement stores like home depot and Menards
Sep 22, 2015 | RCA Televison & Video
I have an RCA TV converter box, model DTA800B1. I don't have the box or instructions, I am attempting to conneect it to an RCA TV with a built-in DVD player. I would appreciate the code that the TV...
There are a lot of possible RCA TV codes programmed into the DTA800B1 remote.
Try the following three digit codes: RCA 000, 001, 005, 072, 073, 074, 075, 076, 077, 078, 135,
138, 140, 144, 150, 156, 159, 162, 163, 169, 171, 178, 229, 246, 249, 260, 274, 275, 293, 302 in order.
To program the remote. Turn on your TV manually and press PGM (to the left of the zero in the number pad section). The LED should light and stay lit. Type in the first 3 digit code and press OK (in the center of the arrow keys near the top). See if the gray volume up/down keys work to change the volume. If it doesn't work press PGM again and enter the next code.
Note that the converter box remote will only turn on and off, switch the input from Channel 3 or 4 to AV in, adjust the volume and mute the TV. It will not control any of the DVD functions. Your original TV remote will not control the converter box.
The manual for the DTA800B1 is available here: .
I hope this helps.
(who has the DTA800A which is the model without the analog pass-through.)
Sep 17, 2011 | RCA Televison & Video
While watching tv, we lost sound. We thought it was the tv but when we use the wii or netflix through the wii, we have sound. We are using a Zenith tv digital converter as well as have things routed...
Reboot the digital converter box by unplug,replug it back like 10-20 mins later.If u still getting the same problems no sound,tries by checking out the RCA cable connections,tries take out the red wire and check for damages and plug it back in or tries changes another RCA cable set all to gether.After new set of RCA cable should be working 100,if not the digital converter box is the problems,than now must change the digital converter box,this box no longer on sale by those big box stores.If u require to change the digital converter box tries websites like, to buy those converter boxes.
Feb 17, 2011 | Televison & Video
CAN I connect 2 one converter box and how.
If you're using a box that has an RF (antenna) output on channel 3 or 4 to the TV, you can insert a splitter and feed two sets. A splitter looks like this:
It takes the signal in on the single connector side, and splits it between the two output jacks on the other side. You can find splitters at TV retailers, Radio Shack, and even at Home Depot or similar stores in the electrical section. Run a cable from each of the output jacks to the antenna connectors on the two TV sets. Each TV will need to be tuned to the converter box output channel, and both sets will get the same program (whatever channel you have selected on the converter).
If the converter box has audio and video output jacks and the nearest set has an AV input, you can connect that set with the same kind of cable you use to hook up a DVD player (RCA plugs on the ends) and select the AV input to see the converter box signal. You would run a cable from the RF output connector of the converter to the second set's antenna jack. Then you wouldn't need the splitter, and the set using the AV inputs would get better quality picture and sound. Again, each set will get the same program as determined by the converter.
Hope this is what you need to get going. Thanks for using Fixya!
Dec 17, 2010 | RCA Analog (RCA) to Digital (VGA)...
1998 RCA TV Model F27242GY How do I connect a VCR/DVD player to this TV? Do I need to use a RF modulator or converter?
If this particular model does not have your typical RCA jacks in the front or back, Yes you will have to purchase an RF converter box. This is a common problem for the older conventional TV. Visit your local electronic store. Thanks for asking and show a few hands of support!
Nov 04, 2010 | RCA F27242GY 27" TV
Insignia Digital to analog converter menu doesn't come up
When my Menu did not come up, I found it on the AUX channel (one below channel 3). I was able to go through the set up, but found only one digital channel available. Hope this helps!
Nov 10, 2008 | Televison & Video
Haier / Celera TV & RCA Converter Box remote code
hi guys,
pgm-->tv code-->ok-->you are done
try this link for codes.
hope you got it.
Jul 18, 2008 | Televison & Video
Digital broadcast compatible
I have a 1999 RCA TV model # F27645. I wanted to know if I am going to need to get a digital converter box?
Feb 13, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
