Question about Proview PL926WBi 19" LCD Monitor
Proview 19# model PL926Wbi
Screen stays black blue light flashes on and off. I've changed computers and the routing cable to no avail. can u help me?
  • Anonymous Jun 01, 2008
    Same problem flickering then died. Only stays on for 10-15 secs.
Thers Sounds like the problem I'm having /had exactly. When I opened the case I found that like others the 470mf capacitors on the power board had gone bad. (See the post from Delphiuser)
The capacitors are probably from a Chinese company called Xandu and I'm currently looking for a replacement capacitor to fit the circuit. Its a 470 mf cap with a 25 volt rating .
Posted on May 04, 2008
My proview pl 926wbi comes on with a black screen and a no signal message then shuts off.
Check that the cable is firmly connected and plugged into the right connection on the computer. Make sure that the monitor is reading from the right input, (i.e. if it's a blue connection it should be set to VGA/Analog, if white then it should be DVI/Digital) or at least set to Automatic.
This can be configured on the monitor by pressing its' Menu button.
Feb 28, 2011 | Proview PL926WBi 19" LCD Monitor
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
Proview Monitor PL926 Wbi The power indicator
Repair estimate will be according to problem.
Nov 13, 2009 | Proview PL926WBi 19" LCD Monitor
19" proview LCD monitor light and signal
How old is this thing? Mine is about 4 or 5 years old... junk it!
Mar 25, 2009 | Proview PL926WBi 19" LCD Monitor
Pl926wbi 19"proview monitor,screen goes black every 3 seconds,
Bad capacitors on the pcb boards internally unsoldering ad replacement is indicated.
Feb 17, 2009 | Proview PL926WBi 19" LCD Monitor
Screen goes black
The video adapter board is what controls the monitor. If you are going to replace a board that would be the one.
Dec 27, 2008 | Proview PL926WBi 19" LCD Monitor
I NEED HELP PLEASE!!!!!!! PROVIEW 19" MONITER.
Does the led on front of the monitor stay blue or does it become amber ?
If it becomes amber, then you are not getting a signal.
No harm in trying this : You can try to see if it is a contact problem.
With the monitor unplugged.
Use a small paper clip to run in and out of the blue vga plug holes a few times each to make sure they are not plugged or gummed up.
If that doesn't help and you know that your video cord is good, then I am afraid to say that more than likely there is a problem with yor video card.
If it stays blue then the signal is there but the screen isn't fully lighting up, leading to a failing power-inverter board or a bad bulb.
powerseller
bammbammfran
Oct 12, 2008 | Proview PL926WBi 19" LCD Monitor
ProView 19'' Widescreeen LCD Monitor problems
It guess it is upon the logic board is having problem.
Feb 10, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
195 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
