Do i need a didgital converter for my SDTV model #27F634T or does it have the digital tuner already and I can use an antennae to receive analog or digital signals?
    Novelist:
    Champion:
  • 216 Answers
Greetings mockus5,
If your unit is the RCA 24F634T, then yes, it does already have a digital tuner and is capable of using an antennae to receive digital and analog signals. No converter box would be needed.
Thank you,
Dorothy
Go Ahead. Use Us.
Posted on May 01, 2008
Using a digital antenna to channel scan for broadcasted channels
It is no different that channel scanning for cable or analog over-the-air channels. You simply ensure that you have selected the digital tuner of the set prior to scanning. Some older flat panel sets do not have integrated digital tuners. A digital antenna alone will not allow these sets to receive digital broadcast channels. A converter box is needed to convert the digital broadcast signals to analog for the tuner in the set. Also, sets that do not have digital tuners may not support the resolution rate of digital TV broadcasts. Most digital HD broadcasts are 720p and a few are 1080p.
Jul 28, 2016 | Televison & Video
I have a RCA D52W20 rear projection HDTV. This TV was purchased in2005. I cancelled my cable and I just hooked up a digital antenna but the TV isn't finding any channels. What do I need to do? I was...
HDTV indicates the number of lines that are shown by the TV. (HD means that at least 720 lines can be displayed in a given picture.) To receive OTA signals, you need an ATSC tuner (digital) of sufficient power (with a clear path to the transmitter) these days. The RCA D52W20 was released in 2002 and only has an NTSC (analog tuner). You will need a digital-to-analog converter to receive OTA TV (unless any low power analog stations remain in your area).
Please note that the basic digital-to-analog converters that were available with the government coupon back in 2009 were SD (480i lines of pixels used) units. HD d-t-a converters exist but are more expensive.
I hope this helps.
(the phrase "digital antenna" is meaningless; check with tvfool.com or antennaweb.org for the direction of local transmitters. TVfool.com will give more information on the type of antenna (indoor, outdoor, amplifier) that you will need to receive channels in your area. Antennaweb assumes an external antenna but is very conservative in the stations that it will indicate that you can receive. Antennas are given a color rating based on how far away the transmitter can be to get a watchable signal. Since digital signals are either enough for the tuner to interpret or you get a "no signal" message, you often need a stronger signal than was needed to receive a watchable analog channel.)
Sep 27, 2011 | RCA Televison & Video
I have a nspdp42 plasma and i cant affort cable and want free tv. is there a analog to digital converter in the unit already? the model # is 801rmd2237770 Thank you
The Insignia NS-PDP42 Plasma HDTV has a built in ATSC/NTSC/QAM tuner.
In short, yes, it does have a digital converter built in, but you will need a antenna capable of receiving digital broadcasts. You can find these at Walmart for $15 to $60.
Mar 05, 2011 | Insignia 42" Flat-Panel Plasma HDTV
Tv comes on cannot get a picture nor sound. followed instructions in manual regarding source , enter , picture, enter , channel, enter.etc., I can get to the menus but nothing else. It is not on cable...
If you have an antenna, you are trying to receive off-the-air broadcasting. Remember that a couple of years ago the US switched to digital broadcasting and analog stations went off the air. Your TV does not have a digital tuner, so you need an digital-to-analog adapter if you want to receive anything.
The US government had a program before the switch to help pay for the adapters, but that's long past now. Radio Shack sells them as do other retailers, and you can find them online as well.
The adapter picks up the digital broadcasts and converts them to a channel 3 or 4 TV signal that the analog tuner in your TV can receive. Some models of converter also feature video and audio jacks so you can connect it as an AV source like a DVD player. Once you've hooked the antenna to the converter and the converter to the TV, you'll be able to watch your local channels again. Maybe, that is.
The trouble with digital broadcasting is that signal strength makes a huge difference in reception. With analog, a weak signal would still give you a fuzzy but watchable picture. A weak digital signal may not even be detected, or you might get a picture that breaks up (pixelation) or freezes on the screen. You don't say what kind of antenna you have, but unless you're in or very close to a large city or near the station's transmitter, simple rabbit-ears may not be enough. Many people found after getting an adapter that they needed a better antenna, even something on the roof. In some areas (valleys, remote areas, places surrounded by many tall buildings, for instance) people found they could never get any channels. If you do in fact have a digital converter already (you didn't mention one), this could be the reason you can't get anything.
Hope this helps you figure out what's wrong. Thanks for using Fixya!
Dec 04, 2010 | Craig CTV-41331 13" TV
Do the new Insignia TV models need a converter or are they already digital ready?
the are digital ready with a qam tuner. what this means that you can either connect a cable line directly to the back and receive channels or connect a digital antenna and receive channels as well.
May 04, 2010 | Insignia Digital-to-Analog Converter for...
Does this tv have a digital tuner? i thought it did because it said hdtv on it when I bought it in 2004. but I just bought a digital antenna and i'm getting nothing but snow after i scan for channels. is...
Sorry to say, your HDTV-Ready - Requires separate receiver to view HDTV signals. SDTV (Standard Definition) - has built-in digital receivers/decoders and do not require the purchase of any separate components in order to display digital signals. It provides lower image quality than EDTV or HDTV, but higher image quality than analog TV. SDTV is displayed using an aspect ratio of 4:3. I hope this helps and good luck.
Please remember to vote fe52ba2.jpg if this was helpful in any way. Thanks.
Oct 31, 2009 | Hitachi 46F500 46" Rear Projection...
Does the JVC AV27230 require a digital to analog converter?
if you are going to continue using the rooftop antenna, then you will nee to purchase a digital converter box. Those television sets are only analog. You do have an option to get Directv or Dish network and you will not need a converter box at all. Directv and Dish network are 100% Digital and the receivers work as converter boxes for that product only.
Jun 16, 2009 | JVC AV-27230 27" TV
Hitachi 57G500A DTV & upcoming analog to digital changeover
To answer your direct question, yes it has a digital tuner. To answer your real question, NO it WILL NOT receive the new ATSC (digital) broadcast stations. The tuner itself is a digital one but works only for analog signals. The changeover in February will change the broadcast signals to a new digital format that will require a converter for your set to continue to function. Please note that the converter is only required if you receive your signal from rabbit ears or a rooftop antenna. If connected to cable or satelite, no change will be seen and no converter is needed.
To simplify:
Over air reception = need converter
Cable or satelite = no converter
Dan
Jan 28, 2009 | Hitachi 57G500 57" TV
How do I tell if my tv is analog
Hi Dru,
Good news, your 42 inch Phillips has a built in digital tuner, all you need is an antenna.
Please post the model of your other Tv and I will check on the tuner type.
I have provided a link to a site that has good info on antenna types and the channels you will be able to recieve.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if this was the information you requested and please rate this solution.Lone99star
Jan 25, 2009 | Philips Magnavox 42MF521D/37 Television
Does my tv have a digital tuner (RCA Model E13320, 2/2001)?
The digital tuner has nothing to do with the new signal you will be receiving in February of next year. The new video signal is a digital signal. The old video signal is analog. Your television receives the analog signal and converts it to what you see on television. You need a converter box to convert the new digital signal back to an analog signal your television can convert.
Jerry
Nov 07, 2008 | Televison & Video
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
