Question about Kitchen Ranges
How to replace oven orifice from nat. gas to lp gas
  • 331 Answers
SOURCE: Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Posted on Aug 15, 2007
SOURCE: sooting of pans in oven
If you adjust the toggle type mini lever to a lower pressure so that the flame is just under licking up through the bottom of the oven and then adjust the air mixture to eliminate all but about an inch of yellow flame it should get rid of the soot.
You want to be sure that the flame is not pulling away from the middle bar where the gas comes out ( a little pull away is ok) and that there is not too much yellow flame. Find the happy medium and you should be good to go.
You may have to adjust the lever and the air mixture a few times before you get it right.
To adjust the air mixture you will need to remove the cover plate at the bottom towards the back, then loosen (no need to remove it) the one phillips head screw holding the air mixture cover in place. adjust the air mixture by moving the cover left or right letting in more air or restricting the flow of air more.
BE CAREFUL, to determine if the mixture is right you will have to turn on the oven bruner and everything will be hot. Wear protective clothing and BE CAREFUL to not burn yourself.
You can find a manual for this model by searching google for "ge xl44 manual". It was the first return when I did the search.
Here is a link if they leave it, otherwise you will have to search for it yourself. They explain how to adjust the air mixture in this pdf on pages 35 - 38.
Posted on Nov 26, 2008
  • 42 Answers
SOURCE: Viking Gas Oven VGSO-166 flame too high
make sure the hood orifice is a #52. (orifice to bake burner)you can go to the local propane gas company and see if they have one they will sell you.
Posted on Dec 20, 2008
  • 1543 Answers
SOURCE: Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Posted on Jan 06, 2009
SOURCE: LP gas conversion oven flame to big
I did all this and the flames are still huge inside the oven...
Posted on Nov 27, 2009
How do I convert a Winrich Perfecta 1800 from LP to nat gas
You need to get natural gas orifices for each burner and the oven. These are the brass metering devices connected to each burner gas valve . Same for the oven. They are removable with a wrench.
Nov 13, 2016 | Kitchen Ranges
Cecilware fms40 fryer convert to lp gas
Most NatGas devices will convert to use of LP by changing the orifice.
Oct 05, 2015 | Cecilware FMS-40 Deep Fryer
Convert from lp to ng
orifice sizes will increase since goin from lp to nat convert appliances you will need diff gas valves, nat gas and propane will have diff pressures
Dec 05, 2013 | Heating & Cooling
I have a garland h283 i want to convert to nat gas from lp what is the orrafice diameter? I would like to drill the lp oriffice out. Also do i need new pilots?
Most gas ranges that can be converted between LP and natural gas include an orifice kit usually located by the gas connection and regulator. Some ranges cannot be converted. I doubt you will be able to find any documentation that tells you the size of the required orifices. Remember that there is an orifice for each of the surface burners as well for the oven and broiler burner(s)
Oct 31, 2013 | Hotpoint RGB745 Gas Kitchen Range
Brown TM210-4 kitchen range... how do i switch from LP Gas to Nat. Gas on this model? Is it just a regulator adjustment? or do i have to change the orifices as well?
Both. If this is a sealed top range, then you will have to change out the orifices and flip the cap on the regulator. If this is an open top style range (the top lifts up around the burners) then the orifices need to be adjusted and the regulator cap flipped. The oven/broiler orifices will also need to be changed or adjusted, depending on which kind they have. Some older models also require converting the oven thermostat from LP to natural gas (and vice versa) by turning the screw to the correct marked setting. If you have your owner's manual, it explains the conversion in it. If not we may be able to find it online for you to download. Douglas
Oct 09, 2010 | Brown Stove Works TM210 Gas Kitchen Range
Mod jgp328wec2ww changed orifices from nat to lp. Burners not getting hot enough. It took 12 min to bring 1 qt to boiling and not rooling. how is this adjusted?
Please tell us everything you did to convert your stovetop/oven to LP? Beside swapping the natural gas orifices for LP orifices, did you also switch the appliance regulator over to LP? When you put in the orifices did you match up the proper size ones to each different size burner according to your owner's manual? They have #'s stamped on them to identify them and some are even color coded. Were you having any similar issues with your previous stove? If so, it may be a pressure problem. I can help you solve this problem with a little more information. Douglas
Oct 05, 2010 | GE Cooktops
How to check gas valve orifice to insure its correct for a LP install. VDSC5304bwh. It was ordered LP but box has been written over many times nat/LP/Nat.. Searched the web help..I am a HVAC...
What is the BTU rating of the dryer. If you open the dryer door, it is listed on the dryer behind the door. Most are 20,000 or 22,000 btu. The orifice # should either br 54 or 55 if it's LP.
May 16, 2010 | Viking VDSC305-4B Dual Fuel (Electric and...
Do you have instructions on how to convert a deep fryer to LP I have a Pitco 35cs I need to convert to LP
Visit and go to PITCO web, you will be able to locate there the nearest authorized parts dealer on your area and ask for the conversion kit (from nat to lp). The gas valve conversion kit consists of spring, cap and instruction manual. you also need to replace the burner and pilot orifice, Nat pilot and burner orifice have larger bore than lp.
Apr 06, 2010 | Pitco Frialator 35CS Deep Fryer
Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
Mar 14, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Converting aan LP oven to gas
In most cases the pressure regulator has to be changed or adjusted. The orfices on each burner, oven, broiler and surface burner may need to be changed also. Sometimes they can be adjusted. Sometimes the threads on the pipe are different also. This is to prevent accidental connection to the wrong fuel. The big difference is the gas pressure. LP is usually around 10 - 12 lbs and natural gas is usually around 3 lbs. Properly adjusted you will like natural gas much better than LP as it is slightly hotter. The information will be in the instruction book and also on the Jenn air web site. Whirlpool owns both Maytag and Jenn aire so check all sites. The conversion kit is usually less than $50.
Apr 20, 2008 | Equipex PZ-330 Electric Single Oven
Kitchen Ranges Logo
271 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
