Question about Acer Extensa 4620 Notebook
Overheating and shutting down..
After about an hour of using my laptop, it starts to get extremly hot and it shuts off without warning.. Does anyone know what is causing this problem???
  • chrisinatx Mar 17, 2009
    I have the Extensa 4620z and during use, it seems to overheat and shut down.
  • Anonymous May 19, 2009
    Overheats... shuts down... pooey.
Rtyhfhfgh
Posted on May 01, 2008
Re my Thinkpad T61: Last weekend it froze. Icons would not respond to mouse clicks. Could not open new programs or close the programs that were open. Pointer was still working -- it just did not work to...
There are a couple of things that can go wrong with it. The most common thing on laptops is overheating.
You will know if your laptop is overheating if it happens one ore more of the following:
-The keyboard and the bottom of your laptop are very hot when the laptop is working.
-The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
-The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
-The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Follow this steps to avoid overheating:
-Don't use your laptop in full sunlight for extended periods
-Don't leave the laptop in a closed car on a sunny day
-Don't place the laptop on or near extreme heat sources, such as radiators, hot air vents
-Turn off your laptop before putting it in your carry bag
-Turn off your laptop when not in use for a long period
-Work on an even surface as much as possible, not on your lap!
-Clean the air vents in your laptop regularly by using a can of compressed air
-Get more space under your computer by propping it up on something when it's on a desk
-Consider purchasing a laptop cooling pad
-Consider purchasing an external fan
To clean your laptop's cooling system:
-Shut down the laptop ie do not leave it suspended, sleeping or hibernating.
-Unplug all cables from the unit and remove the battery pack
-Get a can of compressed air and blow it into all vents around your computer - this should clear out any dust and hair.
-Do Not use a vacuum cleaner
If it is not overheating, then it is a hardware failure. Could be the RAM memory, processor or the motherboard. You can test the RAM with this program: http://hcidesign.com/memtest/MemTest.zip
If RAM is ok, then only replacing hardware equipment could corner the problem.
Dec 15, 2010 | Lenovo ThinkPad T61 Notebook
Tip
Fix OVERHEATING Notebook
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A135) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
on Mar 15, 2008 | Toshiba Satellite A135-S2276 Notebook
I have a Compaq NW9440 Mobile Workstation - it keeps shutting down every 15 minutes or so. At times, it will not restart right away. I thought it may have been the CMOS Battery, so I replaced it. It's...
The most common problem you get with a laptop is overheating, this can cause for it to shut down while operating to prevent more damage.
-Do Not use a vacuum cleaner.
If it is not overheating, then it is a hardware failure. Could be the RAM memory, or the motherboard. You can only corner the problem by testing with different RAM modules or motherboard.
Dec 01, 2010 | HP Compaq nw9440 Notebook
My Toshiba P35-S611 shuts down without warning a short time (2 min-45 min) after it boots up. The battery isn't hot but the heat dissipation fins in the back are very hot.
Solution:
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
May 09, 2010 | Toshiba Satellite P35-S611 Notebook
My laptop shut down after powering out with no warning and will not restart.... Toshiba L550 screen stays black but when I hit the enter key it beeps........any suggestions
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
Solution:
May 04, 2010 | Toshiba Computers & Internet
Overheating and turning off
Laptop shuts down? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Mar 30, 2010 | Acer Aspire 5315-2153 Notebook
My laptop gets heat and shutdown
Solution:
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes you have to open the laptop case all the way down.
Feb 27, 2010 | Compaq Evo N610C Notebook
My computer restarts alone ! on/off ?
Good luck
Dec 10, 2009 | Acer Aspire 5500 5570-2609 Laptop
Shuts down
Hi..
If the laptop shutdown maybe it cause overheating.
Good luck !!!
Regards
PCmania
Jul 15, 2009 | HP Compaq Presario V6000T Notebook
Installed new larger hard drive now crashing after an hour use
When you say "shuts down" do you get a BSOD (Blue Screen of Death) or does it just shut down without an error message? It definitely sounds like overheating. Try using a laptop cooler, something like this: http://www.overclockersclub.com/reviews/antec_notebook_cooler.php (I'm not saying you should buy that model necessarily, there are many such coolers). They can make a huge difference.
Apr 21, 2007 | Compaq Armada E500 Notebook
Acer Extensa 4620 Notebook Logo
176 people viewed this question
Brian Sullivan
Brian Sullivan
