Question about Symbol LS2208 Handheld
Hand held scanner LS2208
How can I configure the scanner to enter the data when we scan the barcode instead of having to hit the enter button on the keyboard manually?
  • 2 more comments
  • Anonymous May 21, 2008
    I need a tab programmed after each scan. I tried following the steps for the ENTER but substituting Sned Tab Key but this didn't work. HELP.
  • zakir1981 Aug 08, 2008
    Hi i am using the LS2208 bar code scanner with java application. i have connected it to the usb port and tried to scan it. when i am scanning its giving me a beep sound as scanned but the data is not getting into text box. what mite be the problem? can any one help me to figure it out plz.
  • ajayaradhya Aug 11, 2008
    the scanner is taking bar39code but 2 of 5 interleaved code is not getting scanned
  • gardula Sep 17, 2008
    I actually doesnt have the same problem.
    what happens now is that I need 3 scans and a tab suffix , and another ENTER scan .
    I cant need a barcode of an ENTER KEY or a sequance or 3 reads and a tab than enter at the end.
At the Symbol web site they have some instuctions for programming a 'Tab' at each scan.
Follow this link....
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=11124&sliceId=SAL_Public&dialogID=58352294&stateId=0%200%209199403
Posted on Jun 21, 2008
I think that what you want is the carriage return/enter after each barcode. See half-way down page 6 in chapter 13 in the manual (or this link: http://www.fixya.com/support/p270882-symbol_ls2208_ls22081azd0100z_handheld/manual-19284/page-250
Posted on May 08, 2008
How to program a bar code scanner to have 2 Tilde in prefix
Hi, to program two tiles before the data you must use Advanced Data Formatting bar codes from the LS2208 Product Reference Guide. You will need to print and scan the following barcodes:
Begin new rule
Send tilde
Send tilde
Send all data that remains
Send enter key (if you need an enter after the data )
Save rule
Go to the Motorola Solutiond Support Portal and search for LS2208 PRG. The guide has also been stored on Fixya.com
Sep 12, 2014 | Symbol LS2208 Handheld
When i scan a barcode why do i have to push enter?
Scan these three barcodes from the LS2208 Product Reference Guide:
Scan Options
Data Suffix
Enter
The scanner will then be programmed to send an enter after every barcode you scan.
https://atgsupportcentral.motorolasolutions.com/content/emb/docs/manuals/5880809a.pdf
Aug 11, 2014 | Symbol LS 4278 Barcode Scanner
When using the scanner to scan books in a library setting I have to push the enter button on the keyboard after I scan the book. Is there a setting so you do not have to hit the enter button; it will just...
Hallo Jason,
yes, this can be done automatically, just by scanning three programming barcodes. Please follow the steps in the attached document.
https://docs.symbol.com/attachments/ADC-01244.doc
Sep 15, 2010 | Symbol LS2208 Handheld
I use usb base ls2208 my problem is every time
Hi, to make the scanner automatically hit enter print and scan the barcodes Scan Options, Data Suffix, and Enter from Adobe pages 222 and 223 of 342 of the LS2208 Product Reference Guide.
Jan 06, 2010 | Symbol LS2208 Handheld
My Symbol scanner sits in a cradle, and the laser goes off and on, rather than remaining on full time. This is a problem, because when I pass a barcode under the unit, I have to wait until it flashes, and...
Yes Symbol LS2208 would be the best... it has an intellistand that enables presentation scanning and easy switching between hands free and hand held models..
Nov 16, 2009 | Symbol LS3478 Barcode Scanner
Symbol LS2208: Suffix with 2 x ENTER
You may need to enter two "rules", each adding an "enter" to the data. This is programmed by scanning special barcodes in the manual, which you can download here:
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
Aug 27, 2009 | Symbol LS2208
Try programming it by setting up a pair of ADF rules, each adding an "enter". This is done by scanning configuration barcodes from the manual in the correct sequence. You can get the manual here:
I would like to transmit EAN-13 bar code without check digit, but closed by ENTER.
If you would like the LS2208 to transmit only the first twelve digits of an EAN-13 barcode followed by an enter you will have to write an Advanced Data Formatting rule using barcodes from the LS2208 Product Reference Guide found here: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=114420371&stateId=1%200%20114410810
The barcodes you will print and scan in the order they are listed are:
Begin New Rule
EAN-13 (from the Critera pages of the ADF section)
Send Next 12 Characters
Send Enter key
Save Rule
If all other barcodes require an enter key make sure you scan Scan Options, Data Suffix, Enter (from the same manual or from the Quick Start Guide) before scanning the ADF rule above.
Jul 13, 2009 | Symbol LS2208 Handheld
Scanner beeps but doesn't enter data into system
Have you scanned the configuration barcodes on the manual? For example if you are using keyboard wedge cable, you will need to scan the keyboard wedge barcode from the manual. Page 20.
http://www.handheld.com/download.aspx?download=/data/ffdefe60-2c7a-423f-a204-ee2450b7c4d9.pdf&filename=IT3800PDF+Linear+Imager+PDF
Apr 02, 2009 | HHP IT3800 Handheld
I have this situations: my system don't read any code begining with 0, please need this configuration for symbol LS2208. Thank you.
Your scanner must have been delivered with a "Quick Start Guide".
All you need to do is to scan the following barcodes from thar Guide:
1.Set Defaults
2. Scan Options
3.<Data><Suffix>
4.Enter
5.The barecode for whatever type of connection you use (RS232, Keyboard, etc.)
Jan 30, 2009 | Symbol LS2208 Handheld
Symbol LS2208 Handheld Logo
2,721 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
